Home » Eclipse Projects » GEF » Determining bounds for Label text
Determining bounds for Label text [message #42308] Thu, 14 November 2002 16:59 Go to next message
I'm trying to create a composite Figure that is composed of a couple Images
as well as a text Label. I've subclassed Figure for my edit part figure and
in my constructor, I add all of the images as child Figures as well as the
label. I am using an XYLayout for my figure and when I add each, I add the
figure w/ a constraint Rectangle.
Currently, it seems that i have to set a static constraint for the text;
however if the text extends beyond the bounds, the label shows the text
truncated with an elipisis. Is there anyway to make the bounds of the text
dynamic (thus making my figure size dynamic)??
Erik
Re: Determining bounds for Label text [message #42679 is a reply to message #42308] Fri, 15 November 2002 13:20 Go to previous messageGo to next message
Hi Erik,
I had a similar problem, I think the problem is that there is a clipping to
the size of the parent. You have to resize the parent figure or you make a
new transparent parent which automaticaly resize to the children size.
Dieter
"Erik Johnson" <ejohnson@avaya.com> schrieb im Newsbeitrag
news:ar1478$e9k$1@rogue.oti.com...
Images
and
the
text
> Erik
Re: Determining bounds for Label text [message #42744 is a reply to message #42679] Fri, 15 November 2002 16:23 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
"Dieter Moroff" <Dieter.Moroff@web.de> wrote in message
news:ar3bnm$k49$1@rogue.oti.com...
> Hi Erik,
to
I didn't understand this. You should rarely use LayerFigure outside of its
intended purpose, which is to be one of the top-level figures in the
diagram.
> Dieter
> Images
> and
the
> the
> text
> > Thanks,
> > Erik
Re: Determining bounds for Label text [message #42771 is a reply to message #42308] Fri, 15 November 2002 16:25 Go to previous messageGo to next message
"Erik Johnson" <ejohnson@avaya.com> wrote in message
Images
and
the
Can you post a picture of what you are trying to achieve? XYLayout is not
the best layout for this type of stuff. But, if you set your label's
constraint to have width=-1, height=-1, it will be sized to its "preferred"
size, which will not need an ellipsis.
Your figure's size will not be dynamic unless it similarly is give (-1, -1)
width height in an XYLayout, or it is in some other layout that asks it its
preferred size.
text
> Erik
Re: Determining bounds for Label text [message #43047 is a reply to message #42771] Fri, 15 November 2002 21:13 Go to previous messageGo to next message
I was able to get it to partially work using DelegatingLayout and using a
RelativeLocator; however it still isn't quite right. I just can't spend
anymore time on trying to get it to draw properly right now.
I was trying to get this to work (see exampleNode.gif).
The figure is composed of:
0-4 connector/terminal items (where connectors anchor)
1 image icon
1 title
The title is dynamic and will be based on user input from the properties
view.
The input/output anchors are dynamic based on the edit part type which is
controlled via. the palette.
What I would like to do is have the composite image bounds be based on the
height of the image icon + text (and north/south anchor figures if the are
part of the figure) and the Max( text.width, (east/west anchor figure if
there) + image width.
The Delegating layout & Relative locator got me close to where I want to be,
but not quite as there are still some minor glitches with sizing--you can
see that the bounding box is not quite right also.
Any ideas/recommendations on what I should be using??
Erik
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:ar3mm8$qbs$1@rogue.oti.com...
> Images
> and
the
> the
"preferred"
(-1, -1)
its
> preferred size.
> text
> > Thanks,
> > Erik
Re: Determining bounds for Label text [message #43084 is a reply to message #43047] Fri, 15 November 2002 23:08 Go to previous messageGo to next message
I would use a figure in vertical FlowLayout(), with 4 children:
1) the top terminal (a Label with just an Icon)
2) a row described below
3) a Label figure (just text, no Icon)
4) the bottom terminal (a Label with just an Icon)
The second child above would be another Figure in a horizontal FlowLayout(),
with 3 children:
a) label for the left terminal
b) label for the Primary Icon
c) label for the right terminal
news:ar47g5$16i$1@rogue.oti.com...
> 1 image icon
> 1 title
> view.
be,
> Erik
> > Images
figure
> > and
> the
add
> > the
not
> "preferred"
> (-1, -1)
> its
> > preferred size.
text;
text
> > text
> > > Thanks,
> > > Erik
Re: Determining bounds for Label text [message #43616 is a reply to message #43084] Tue, 19 November 2002 15:13 Go to previous message
That helped. Thanks!
news:ar4eap$2rt$1@rogue.oti.com...
FlowLayout(),
> with 3 children:
a
> > 1 image icon
> > 1 title
> > view.
is
the
are
> be,
can
> > Thanks,
> > Erik
> > > Images
> figure
> > > and
as
> > the
> add
> > > the
> not
> > "preferred"
> > (-1, -1)
it
> > its
> > > preferred size.
> text;
> text
the
> > > text
> > > > Thanks,
> > > > Erik
Previous Topic:How to turn-off the automatically refocusing support for editpart
Next Topic:how do i listen for mouse actions?
Current Time: Sun Jul 27 06:23:36 EDT 2025
Powered by FUDForum. Page generated in 0.05322 seconds
