Home » Archived » BIRT » Preview Problems in Design Perspective
Preview Problems in Design Perspective [message #42304] Thu, 02 June 2005 11:01 Go to next message
Originally posted by: berni_hofer.aon.at
hello,
i have a problem with my birt installation. i have made a report and want
to test this report in the report design perspective, but the only thing i
see is the ERROR 500 ... internal error page?? does somebody know what's
up with my birt installation?? yours, bernhard
Re: Preview Problems in Design Perspective [message #42730 is a reply to message #42304] Fri, 03 June 2005 11:33 Go to previous messageGo to next message
Bernhard,
If you're getting that when you use the preview function from the top menu
(as opposed to the preview tab in the design area), it may be that you
haven't included the Java bin directory in your path. BIRT includes an
embedded version of Apache Jakarta Tomcat for previewing reports and
Tomcat's JSP engine requires a Java compiler.
For my (default) installation of version 1.4.2_08 of the Java SDK on
windows, here's what I added to get things working:
C:\j2sdk1.4.2_08\bin
Of course, you also need to have installed the JDK in the first place as
noted in the install instructions.
regards,
Mark
"bernhard" <berni_hofer@aon.at> wrote in message
news:67d680b8676f2c9a74ff27c7267e1138$1@www.eclipse.org...
> hello,
Re: Preview Problems in Design Perspective [message #43268 is a reply to message #42730] Mon, 06 June 2005 05:57 Go to previous messageGo to next message
dear mark,
thank you for your answer, but i have the same problem with the preview
tab in the design area! the path is correctly set into the bin directory
of my java installation. i have no idea what goes wrong :(
bernhard
Re: Preview Problems in Design Perspective [message #43458 is a reply to message #43268] Mon, 06 June 2005 21:37 Go to previous messageGo to next message
bernhard,
Can you please let us know the error msg from the Tomcat. The error log
locates at "Elcipse Home\workspace\.metadata\.plugins\org.eclipse.tomcat\"
Jun Zhai
Re: Preview Problems in Design Perspective [message #43645 is a reply to message #43458] Tue, 07 June 2005 05:18 Go to previous message
Jun,
i have found the problem, my workspace was on a remote network directory
and there the error from tomcat occured. i tried to put the workspace on
my local drive - and now it works ;-) thank you for your help ...
yours bernhard
Previous Topic:Cannot compile sample RunReport.java
Next Topic:BIRT development system
Current Time: Sun Jul 27 08:35:27 EDT 2025
Powered by FUDForum. Page generated in 0.03453 seconds
