Home » Archived » M2M (model-to-model transformation) » [ATL] problems with helpers
[ATL] problems with helpers [message #42291] Mon, 28 May 2007 10:05 Go to next message
Originally posted by: angelsaneg.yahoo.es
hello,
We have some problems with Atl transformations.
We use this helper and rule:
helper context String def: firstToLower() : String =
self.substring(1, 1).toLower() + self.substring(2, self.size());
rule Route2Menu {
from
a : ExtendedSlicesMetamodel!Route_Type
to
b : ExtendedNavigationMetamodel!Menu_Type (
Forward <- a.Name_Route.firstToLower()
Name_Route is an attribute of the class Menu_Type (this attribute is
inherit from an abstract father class) . When we use this helper(
firstToLower) in the rule, this error occurs:
****** BEGIN Stack Trace
message: ERROR: could not find operation firstToLower on Sequence(OclAny)
having supertypes: [Collection(OclAny)]
A.main() : ??#24 null
local variables = {self=tres2cuatro : ASMModule}
local stack = []
A.__exec__() : ??#8 null
local variables = {e=TransientLink {rule = 'Route2Menu', sourceElements =
{a = IN!<unnamed>}, targetElements = {b = OUT!<unnamed>}, variables = {}},
local stack = []
A.__applyRoute2Menu(1 : NTransientLink;) : ??#13 59:36-59:63
local variables = {b=OUT!<unnamed>, a=IN!<unnamed>, link=TransientLink
{rule = 'Route2Menu', sourceElements = {a = IN!<unnamed>}, targetElements
= {b = OUT!<unnamed>}, variables = {}}, self=tres2cuatro : ASMModule}
local stack = [OUT!<unnamed>, OUT!<unnamed>, tres2cuatro : ASMModule]
****** END Stack Trace
Execution terminated due to error (see launch configuration to allow
continuation after errors).
thanks.
best regards,
Angel Sanchez, David Redondo
Re: [ATL] problems with helpers [message #42328 is a reply to message #42291] Mon, 28 May 2007 10:32 Go to previous messageGo to next message
It seems that the upper bound of the multiplicity of attribute
Name_Route is greater than 1 (i.e., that Name_Route is multi-valued),
which means that its value is a Collection of Strings.
If Forward is also multi-valued, you might want to write:
Forward <- a.Name_Route->collect(e | e.firstToLower())
If Forward is not multi-valued, you might want to:
- get the first element of the Collection (if it is ordered):
Forward <- a.Name_Route->first().firstToLower()
- get any element of the Collection:
Forward <- a.Name_Route->any(e | true).firstToLower()
- concatenate the values of the Collection:
Forward <- a.Name_Route->including('')->sum().firstToLower())
->including('') makes sure the Collection is not empty, in which case
->sum() would fail to return a String.
Frédéric Jouault
Angel Sanchez wrote:
> hello,
> rule Route2Menu {
> from
> to
> Sequence(OclAny) having supertypes: [Collection(OclAny)]
> local stack = []
> sourceElements = {a = IN!<unnamed>}, targetElements = {b =
> local stack = []
> link=TransientLink {rule = 'Route2Menu', sourceElements = {a =
> thanks.
> best regards,
Re: [ATL] problems with helpers [message #42400 is a reply to message #42291] Mon, 28 May 2007 10:33 Go to previous message
Hi Angel,
> hello,
> rule Route2Menu {
> from
> to
According to the error message, the attribute Name_Route is not a String
but a Sequence (of String ?).
What is the multiplicity of this attribute (reference ?) in your KM3
metamodel ?
If you really want a Sequence, you can applied your helper on the first
element (a.Name_Route->first().firstToLower()). You may ensure that the
sequence can not be empty (using a if statement) or the first() function
will return an error.
Éric Vépa
SODIUS
6, rue de Cornouaille - BP 91941
44319 Nantes, France
Email: evepa@sodius.com
www.mdworkbench.com
Draw more value from your models
Previous Topic:[ATL] How to install ANT Tasks?
Next Topic:[ATL] rules library
Current Time: Tue Jul 22 12:53:50 EDT 2025
Powered by FUDForum. Page generated in 0.03177 seconds
