Problems occoured restoring workbench [message #42257] |
Tue, 14 August 2007 04:52  |
Hi!
I'm starting the use of Pdt.
Someone can tell me what is the cause of the error in the subject?
I get it when eclipse starts.
the detail is:
Problems occurred restoring workbench.
Unable to restore perspective: Workspace - PHP Debug.
Could not find view: org.eclipse.ui.internal.introview
I cannot find nothing about org.eclipse.ui.internal.introview :(
Re: Problems occoured restoring workbench [message #44591 is a reply to message #43599] |
Mon, 20 August 2007 04:48  |
remove the .cache folder from your project
Guy Gurfinkel,
Team Leader, Development Tools
Zend.
"Charlie Surface" <csurface@gmail.com> wrote in message
news:f9vh77$rut$1@build.eclipse.org...
>I really have no idea what that error means. You might try reporting a
>bug.
> "Fabio" <znt.fabio@virgilio.it> wrote in message
> news:f9vgdi$ns4$1@build.eclipse.org...
>> "Charlie Surface" <csurface@gmail.com> ha scritto nel messaggio
>> news:f9vblj$e43$1@build.eclipse.org...
>>> The .metadata folder is under your workspace folder in the filesystem.
>>> It's at the same level as your projects, although it's not visible from
>>> inside Eclipse.
>> Thank you, here it is:
>> !SESSION 2007-08-15
>> 20:16:22.687 -----------------------------------------------
>> eclipse.buildId=I20070517-1700
>> java.version=1.6.0_01
>> java.vendor=Sun Microsystems Inc.
>> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=it_IT
>> Framework arguments: -startup
>> F:\eclipse\plugins\org.eclipse.equinox.launcher_1.0.0.v20070 516.jar
>> Command-line arguments: -os win32 -ws win32 -arch x86 -startup
>> !ENTRY org.eclipse.osgi 2 1 2007-08-15 20:16:34.234
>> !MESSAGE NLS unused message: PHPFormatterConfigurationBlock.tabsLabel in:
>> org.eclipse.php.internal.ui.PHPUIMessages
>> !MESSAGE NLS unused message: PHPFormatterConfigurationBlock.spacesLabel
>> in: org.eclipse.php.internal.ui.PHPUIMessages
>> PHPFormatterConfigurationBlock.tabPolicyLabel in:
>> !ENTRY org.eclipse.osgi 2 1 2007-08-15 20:16:34.250
>> PHPFormatterConfigurationBlock.indentSizeLabel in:
>> PHPFormatterConfigurationBlock.indentSizeErrorMessage in:
>> !MESSAGE NLS unused message: SaveAsDialog.createNewProject in:
>> !ENTRY org.eclipse.ui 4 4 2007-08-15 20:16:37.687
>> !MESSAGE Could not create view: 'org.eclipse.ui.internal.introview'.
>> !ENTRY org.eclipse.php.core 4 10001 2007-08-15 20:17:15.234
>> !MESSAGE PHPCore plugin internal error
>> !STACK 0
>> java.io.EOFException
>> at java.io.DataInputStream.readFully(Unknown Source)
>> at java.io.DataInputStream.readUTF(Unknown Source)
>> at
>> org.eclipse.php.internal.core.util.SerializationUtil.readStr ing(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeFunctionsParameter(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeFunctionsParameterArray(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeFunctionData(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeFunctionDataArray(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeClassData(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeClassDataArray(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizePHPFileData(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizePHPFileDataArray(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.util.DefaultCacheManager.inner LoadModel(Unknown
>> Source)
>> at org.eclipse.php.internal.core.util.DefaultCacheManager.load( Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.phpModel.parser.PHPUserModelMa nager. <init>(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.phpModel.parser.PHPUserModel.i nitialize(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.phpModel.parser.PHPProjectMode l.initialize(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.phpModel.parser.PHPWorkspaceMo delManager.putModel(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.phpModel.parser.PHPWorkspaceMo delManager.getModelForProject(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.project.build.FullPhpProjectBu ildVisitor.handle(Unknown
>> Source)
>> at
>> org.eclipse.php.internal.core.project.build.FullPhpProjectBu ildVisitor.visit(Unknown
>> Source)
>> at
>> org.eclipse.core.internal.resources.Resource$2.visit(Resourc e.java:105)
>> at
>> org.eclipse.core.internal.resources.Resource$1.visitElement( Resource.java:57)
>> at
>> org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:81)
>> at
>> org.eclipse.core.internal.watson.ElementTreeIterator.iterate (ElementTreeIterator.java:126)
>> at org.eclipse.core.internal.resources.Resource.accept(Resource .java:67)
>> at org.eclipse.core.internal.resources.Resource.accept(Resource .java:103)
>> at org.eclipse.core.internal.resources.Resource.accept(Resource .java:87)
>> at
>> org.eclipse.php.internal.core.phpModel.parser.PHPWorkspaceMo delManager$3.runInWorkspace(Unknown
>> Source)
>> at
>> org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
>> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
>>> As far as deleting plugins manually, good luck with that.
>> And how I have to unistall the old version and install the newer, since
>> it passed just as newer files in a zip?
FUDForum. Page generated in 0.24359 seconds
