ClassNotFoundException [message #42238] |
Fri, 18 June 2004 04:01  |
Originally posted by: ahr.esko-graphics.com
Hi all,
I have problem with VE.
I have installed:
Eclipse 3.0 RC2 SDK
EMF build I200406171028
GEF Build I20040617
VE Build 1.0.0 I20040617
But I have tested it with more versions of EMF, GEF and VE and error message
is always the same.
When I try to go to the preference panel (Window\Preferences ...
Java\Visual Editor) I give this error message:
"Unable to create the selected preference page.
Reason:
Plug-in org.eclipse.ve.java.core was unable to load class
org.eclipse.ve.internal.java.vce.VCEPreferencePage."
Log file:
!ENTRY org.eclipse.core.runtime 4 1 VI 18, 2004 09:37:55.180
!MESSAGE Plug-in org.eclipse.ve.java.core was unable to load class
!STACK 0
java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader
..java:404)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(Abstra
ctClassLoader.java:93)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
and when I try to create new Visual Class I give this message:
"The selected wizard could not be started.
Reason:
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard. "
Log file:
!ENTRY org.eclipse.core.runtime 4 1 VI 18, 2004 09:56:55.84
!STACK 0
..java:404)
In Help\Software Updates\Manage Configuration... looks everything ok. All
plug-in are installed properly.
Could you help me, please?
Thanks in advance
Ales
Re: ClassNotFoundException [message #42674 is a reply to message #42311] |
Mon, 21 June 2004 03:13   |
"Rich Kulp" <richkulp@NO.SPAM.us.ibm.com> wrote in message
news:cautlc$bqc$1@eclipse.org...
> Are there any other msgs in the log file? Those are basic classes and
> only some severe configuration error should cause them not to be found.
> Thanks, Rich Kulp
I have removed .log file, start eclipse and just try to open preference
panel.
Here is whole log file:
!SESSION VI 21, 2004
09:06:36.902 ----------------------------------------------
eclipse.buildId=I200406111814
java.version=1.4.2_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=cs_CZ
!ENTRY org.eclipse.core.resources 4 372 VI 21, 2004 09:06:36.918
!MESSAGE Resource /TaskLauncherClient is not open.
!MESSAGE Resource /GrsWrap is not open.
!ENTRY org.eclipse.core.runtime 4 2 VI 21, 2004 09:07:48.325
!MESSAGE Plug-in "org.eclipse.ve.java.core" was unable to instantiate class
"org.eclipse.ve.internal.java.core.JavaVEPlugin".
!STACK 0
java.lang.NoSuchMethodException:
org.eclipse.ve.internal.java.core.JavaVEPlugin.<init>(org.eclipse.core.runti
me.IPluginDescriptor)
at java.lang.Class.getConstructor0(Class.java:1929)
at java.lang.Class.getConstructor(Class.java:1019)
org.eclipse.core.internal.plugins.PluginDescriptor.internalD oPluginActivatio
n(PluginDescriptor.java:403)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(Plugin
Descriptor.java:359)
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescripto
r.java:328)
org.eclipse.core.internal.compatibility.PluginActivator.star t(PluginActivato
r.java:47)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleConte
xtImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(Bu
ndleContextImpl.java:954)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleConte
xtImpl.java:937)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.j
ava:421)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle
..java:293)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseCl
assLoader.java:110)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleL
oader.java:371)
..java:402)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader
..java:307)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.jav
a:336)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBu
ndle.java:1313)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExte
nsion(ConfigurationElement.java:131)
nsion(ConfigurationElement.java:124)
nsion(ConfigurationElement.java:113)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:196)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java
:193)
org.eclipse.ui.internal.dialogs.WorkbenchPreferenceNode.crea tePage(Workbench
PreferenceNode.java:60)
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java
:984)
org.eclipse.jface.preference.PreferenceDialog$8.selectionCha nged(PreferenceD
ialog.java:529)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:452)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:615)
at org.eclipse.core.runtime.Platform.run(Platform.java:758)
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(Structur
edViewer.java:450)
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer
..java:710)
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer
..java:728)
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java
:200)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:195)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 349)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2709)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2401)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java
:72)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:881 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:915)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionI
tem.java:866)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContribu
tionItem.java:785)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2732)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2398)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1362)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1333)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:252)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:334)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:272)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:128)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:638)
at org.eclipse.core.launcher.Main.main(Main.java:622)
!ENTRY org.eclipse.osgi VI 21, 2004 09:07:48.341
!MESSAGE An error occured while automatically activating bundle
org.eclipse.ve.java.core (154).
!STACK 0
org.osgi.framework.BundleException: Exception in
org.eclipse.core.internal.compatibility.PluginActivator.star t() of bundle
org.eclipse.ve.java.core.
ndleContextImpl.java:975)
xtImpl.java:937)
ava:421)
..java:293)
assLoader.java:110)
oader.java:371)
..java:402)
..java:307)
a:336)
ndle.java:1313)
:193)
:984)
ialog.java:529)
:615)
edViewer.java:450)
..java:710)
..java:728)
:200)
:72)
tem.java:866)
tionItem.java:785)
java:334)
..java:25)
Caused by: org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.core.internal.plugins.PluginDescriptor.throwExce ption(PluginDesc
riptor.java:284)
n(PluginDescriptor.java:406)
r.java:328)
r.java:47)
xtImpl.java:958)
... 59 more
Root exception:
org.eclipse.core.runtime.CoreException[2]: java.lang.NoSuchMethodException:
r.java:328)
r.java:47)
xtImpl.java:958)
xtImpl.java:937)
ava:421)
..java:293)
assLoader.java:110)
oader.java:371)
..java:402)
..java:307)
a:336)
ndle.java:1313)
:193)
:984)
ialog.java:529)
:615)
edViewer.java:450)
..java:710)
..java:728)
:200)
:72)
tem.java:866)
tionItem.java:785)
java:334)
..java:25)
!ENTRY org.eclipse.core.runtime 4 1 VI 21, 2004 09:07:48.356
!STACK 0
..java:404)
..java:307)
a:336)
ndle.java:1313)
:193)
:984)
ialog.java:529)
:615)
edViewer.java:450)
..java:710)
..java:728)
:200)
:72)
tem.java:866)
tionItem.java:785)
java:334)
..java:25)
Re: ClassNotFoundException [message #43965 is a reply to message #42737] |
Fri, 25 June 2004 03:24  |
When I have deleted configuration folder from eclipse, it start to work.
Thanks for your help.
A.
news:cb6umu$q7v$1@eclipse.org...
> Did you install into a clean install, or was this an older install and
> just dropped over top of it?
> The error symptom would be from dropping onto of an older installation.
> It is is looking for an older version of the plugin. That would happen
> because registry information has been cached and it doesn't see that the
> plugin has been updated. Try deleting the configuration directory out of
> your eclipse installation.
> Thanks, Rich Kulp
Re: ClassNotFoundException [message #592045 is a reply to message #42238] |
Fri, 18 June 2004 10:19  |
Thanks, Rich Kulp
Re: ClassNotFoundException [message #592174 is a reply to message #42311] |
> Thanks, Rich Kulp
panel.
!STACK 0
r.java:328)
r.java:47)
xtImpl.java:958)
xtImpl.java:937)
ava:421)
..java:293)
assLoader.java:110)
oader.java:371)
..java:402)
..java:307)
a:336)
ndle.java:1313)
:193)
:984)
ialog.java:529)
:615)
edViewer.java:450)
..java:710)
..java:728)
:200)
:72)
tem.java:866)
tionItem.java:785)
java:334)
..java:25)
!STACK 0
xtImpl.java:937)
ava:421)
..java:293)
assLoader.java:110)
oader.java:371)
..java:402)
..java:307)
a:336)
ndle.java:1313)
:193)
:984)
ialog.java:529)
:615)
edViewer.java:450)
..java:710)
..java:728)
:200)
:72)
tem.java:866)
tionItem.java:785)
java:334)
..java:25)
riptor.java:284)
r.java:328)
r.java:47)
xtImpl.java:958)
... 59 more
Root exception:
r.java:328)
r.java:47)
xtImpl.java:958)
xtImpl.java:937)
ava:421)
..java:293)
assLoader.java:110)
oader.java:371)
..java:402)
..java:307)
a:336)
ndle.java:1313)
:193)
:984)
ialog.java:529)
:615)
edViewer.java:450)
..java:710)
..java:728)
:200)
:72)
tem.java:866)
tionItem.java:785)
java:334)
..java:25)
!STACK 0
..java:404)
..java:307)
a:336)
ndle.java:1313)
:193)
:984)
ialog.java:529)
:615)
edViewer.java:450)
..java:710)
..java:728)
:200)
:72)
tem.java:866)
tionItem.java:785)
java:334)
..java:25)
Re: ClassNotFoundException [message #592196 is a reply to message #42674] |
Mon, 21 June 2004 11:26  |
Thanks, Rich Kulp
Re: ClassNotFoundException [message #592687 is a reply to message #42737] |
A.
> Thanks, Rich Kulp
FUDForum. Page generated in 0.04984 seconds
