Home » Eclipse Projects » Equinox » Problem wirh OSGI system
Problem wirh OSGI system [message #42226] Mon, 10 May 2004 16:12 Go to next message
I have a RCP application based on Eclipse 3M8. I have a plugin and a
fragment, which only contains a JDBC driver ( so a update does not force
the user to load the JDBC again ). Everything worked fine until I began
to work with the Eclipse update system.
1.) Everytime I update my primary plugin Eclipse doesn't restart
correctly. It seems that the primary plugins classloader cannot access
the fragments JAR file during the first startup.
2.) I cannot overwrite the plugin.xml of my primary plugin, the OSGI
system seems to buffer parts of the old plugin.xml ( I have context
menus I removed from the plugin.xml with the update ). The problem can
only be "solved" by removing the ./configuration/org.eclipse.osgi folder.
Does anyone know what is happening ?
Henning Rogge.
Re: Problem wirh OSGI system [message #42330 is a reply to message #42226] Thu, 20 May 2004 14:26 Go to previous messageGo to next message
Originally posted by: diament.torahweb.org
I had a different update problem with 3M8/RCP, and switching over to
last Friday's integration buidl solved it.
hope that helps,
Judah
> force the user to load the JDBC again ). Everything worked fine until
> I began to work with the Eclipse update system.
> Henning Rogge.
Re: Problem wirh OSGI system [message #43878 is a reply to message #42330] Mon, 28 June 2004 15:24 Go to previous message
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
The problem relates to the configuratoin directory. Eclipse caches various
bits of information since in the normal/product case the data never changes
on disk without Eclipse being told. Consider using -clean or -dev on the
command line.
Jeff
"Judah Diament" <diament@torahweb.org> wrote in message
news:c8isrk$svi$1@eclipse.org...
> hope that helps,
> Judah
folder.
> > Henning Rogge.
Previous Topic:standalone osgi
Next Topic:Starting Fresh - Do I Use OSGI?
Current Time: Thu Jul 17 20:26:46 EDT 2025
Powered by FUDForum. Page generated in 0.07451 seconds
