XsdValidation [message #42223] |
Tue, 27 April 2004 16:03  |
Ed,
In the process of doing some other work, we doing a lot of modifications
to an XsdResourceImpl. We seem to be running into performance problems
where everytime a value is changed or new items are added or removed, the
entire schema tries to validate. Is there any way to turn off the auto
validation and then turn it on when the entire effort is complete so as to
only perform the validation once at the end of the major operation?
thanks,
lp
Re: XsdValidation [message #42292 is a reply to message #42261] |
Tue, 27 April 2004 16:52  |
Lance,
Nothing should set it back to true on its own. When it's false, QNames aren't
resolved and no type analysis is done. Each schema instance has a separate
setting for this, so maybe you have a multiple schema scenario? Setting it to
true doesn't change the syntactic structure so doing that before save isn't
necessary.
Lance Phillips wrote:
> I had just found it! What kind of things would trigger that value getting
> set back to true on it's own? My test seemed to FLY right along after I set
> this to false. But somewhere in the middle it started bogging down. Not
> sure if it is XSD related or not yet.
> What are the implications of leaving it to false and only setting it to true
> when you save and then setting it right back to false after saving?
> thanks,
> lp
> "Ed Merks" <merks@ca.ibm.com> wrote in message
> news:408EBF41.4ACB9E0F@ca.ibm.com...
> > Lance,
> > There's XSDSchema.setIncrementalUpdate. You can turn it back on when
> you're
> > done your edits...
> > > Ed,
> modifications
> the
> to
> > > thanks,
> > > lp
Re: XsdValidation [message #586035 is a reply to message #42223] |
Tue, 27 April 2004 16:14  |
Lance,
There's XSDSchema.setIncrementalUpdate. You can turn it back on when you're
done your edits...
> Ed,
> thanks,
> lp
Re: XsdValidation [message #586052 is a reply to message #42252] |
Tue, 27 April 2004 16:35  |
thanks,
lp
> Lance,
you're
> done your edits...
> > Ed,
modifications
the
to
> > thanks,
> > lp
Re: XsdValidation [message #586065 is a reply to message #42261] |
Lance,
necessary.
> thanks,
> lp
> > Lance,
> you're
> > done your edits...
> > > Ed,
> modifications
> the
> to
> > > thanks,
> > > lp
FUDForum. Page generated in 0.10123 seconds
