Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » CDO ResourceManager lifecycle
CDO ResourceManager lifecycle [message #42213] |
Fri, 28 July 2006 11:37  |
Originally posted by: yannick.lizzi.silogic.fr
Hi all,
The following piece of code causes a Unique constraint violation on the
CDO server:
// Init resource manager
ResourceManager resourceManager = ...
// Create and commit the first resource
CDOResource resource = (CDOResource) resourceManager.getResourceSet()
.createResource(URI.createURI("cdo:///uri1"));
resource.getContents().add(factory.createMyObject1());
resourceManager.commit();
// Create and commit the second resource
CDOResource resource2 = (CDOResource) resourceManager.getResourceSet()
.createResource(URI.createURI("cdo:///uri2"));
resource2.getContents().add(factory.createMyObject2());
The error is : "Unique constraint violation: in statement [INSERT IGNORE INTO
CDO_RESOURCE VALUES (?, ?)]"
It seems the problem comes from the 2 commits made on the same
ResourceManager. Indeed, when I remove the first one (just like in the
CDO example application), it works fine.
I would like to better understand the behaviour (lifecycle) and the role
of the ResourceManager, as well as the best way to use it.
For example: can I re-use a ResourceManager instance after a commit? Is
an instance linked to only one transaction?
Should I have to create a new instance each time I want to load a
resource (as it seems to be in the exampes)?
Am I wrong if I consider it at the same level as the Hibernate Session?
Thanks and congratulation for this two really promising projects.
Yannick
Re: CDO ResourceManager lifecycle [message #42316 is a reply to message #42213] |
Fri, 28 July 2006 12:18   |
Originally posted by: stepper.sympedia.de
Yannick,
A ResourceManager is intended to have the same lifecycle as the
ResourceSet it's attached to.
You can imagine as a regular ResourceSet adapter (although it's
currently not implemented as such, next version it will be).
You can apply multiple, yet subsequent transactions to a whole
ResourceSet by calling commit() on the associated ResourceManager.
The same can be achieved by calling save() on an arbitrary (CDO)Resource
within that ResourceSet:
public void save(Map options)
try
catch (Throwable t)
logger.error("Error while committing", t);
Regarding the duplicate key issue you mention, I assume that your
database is simply not empty.
The example action to create two remote Resources is very simple. It
always uses the same URIs.
So you can only use the action once to initially create some example
Resources.
If you want to recreate the Resources you will have to drop the database
prior to that.
And thanks for your kind words about CDO ;-)
I hope it can be useful for you.
Cheers
/Eike
Yannick Lizzi schrieb:
> Hi all,
> the CDO server:
> INTO CDO_RESOURCE VALUES (?, ?)]"
> role of the ResourceManager, as well as the best way to use it.
> Is an instance linked to only one transaction?
> Yannick
Re: CDO ResourceManager lifecycle [message #42514 is a reply to message #42316] |
Mon, 31 July 2006 05:46   |
Eike,
Thanks for your quick answer, it's now clear to me how to use the
ResourceManager.
Regarding the duplicate key problem, I made some tests and it seems it's
indeed a database issue. However, I don't think it's because the
database is not empty.
Actually, I made my test with HSQLDB. I used the server.properties file
provided in the CDO example and I just comment DERBY and uncomment
HSQLDB config. Here are these parameters:
jdbc.dialect=HSQLDB
jdbc.driver=org.hsqldb.jdbcDriver
jdbc.url=jdbc:hsqldb:.
jdbc.username=sa
jdbc.password=
With this configuration, the exception is raised on each execution. But
this also means that hsqldb is launched in-memory, so the database
should be empty on start.
Don't ask me why, but if I set this configuration instead:
jdbc.url=jdbc:hsqldb:testdb, my test runs without exception.
Yannick
Eike Stepper a écrit :
> Yannick,
> try
> catch (Throwable t)
> Resources.
> prior to that.
> Cheers
> /Eike
>> Hi all,
>> the CDO server:
>> Yannick
Re: CDO ResourceManager lifecycle [message #42612 is a reply to message #42514] |
Mon, 31 July 2006 08:16   |
Another important information for the error I mentioned:
I try to start the server and the client in the same jvm.
If I run my previous test with client and server in 2 separates jvm, it
works well.
Maybe I should use the embedded connector instead of the socket connector?
Yannick
Yannick Lizzi a écrit :
> Eike,
> ResourceManager.
> jdbc.dialect=HSQLDB
> jdbc.username=sa
> jdbc.password=
> Yannick
>> Yannick,
>> (CDO)Resource within that ResourceSet:
>> try
>> catch (Throwable t)
>> Resources.
>> database prior to that.
>> Cheers
>> /Eike
>>> Hi all,
>>> the CDO server:
>>> the CDO example application), it works fine.
>>> Yannick
Re: CDO ResourceManager lifecycle [message #42705 is a reply to message #42612] |
Tue, 01 August 2006 00:20   |
Yannick,
I have no idea, why in-memory hsqldb doesn't work for you. It does for me:
[INFO] common.client.connector: Connected socketChannel:
java.nio.channels.SocketChannel[connected local=/127.0.0.1:1139
remote=localhost/127.0.0.1:2036]
--> TEST: Create an EMF ResourceSet and associate it with a CDO
ResourceManager
--> TEST: Create a new CDO Resource
--> TEST: Populate the resource with an example model
--> TEST: Create a second CDO Resource
--> TEST: Populate the second resource with an example model
--> TEST: Commit the changes to the database
Even if I use the create action several times, there is no exception.
The originally created resources are reused and populated with multiple
top-level objects (libraries).
Since I can't reproduce the exception I fear I can't help with this
issue. If you can trace it to somethiing I can fix, please tell me.
The embedded connector is currently not stable and there's no example
how to configure it (actually it'd be simpler than NIO).
Cheers
/Eike
> it works well.
> connector?
> Yannick
>> Eike,
>> ResourceManager.
>> it's indeed a database issue. However, I don't think it's because the
>> file provided in the CDO example and I just comment DERBY and
>> uncomment HSQLDB config. Here are these parameters:
>> jdbc.dialect=HSQLDB
>> jdbc.username=sa
>> jdbc.password=
>> But this also means that hsqldb is launched in-memory, so the
>> database should be empty on start.
>> Regards,
>> Yannick
>>> Yannick,
>>> try
>>> catch (Throwable t)
>>> Resources.
>>> Cheers
>>> /Eike
>>>> Hi all,
>>>> the CDO server:
>>>> commit? Is an instance linked to only one transaction?
>>>> Session?
>>>> Yannick
Re: CDO ResourceManager lifecycle [message #42734 is a reply to message #42705] |
Tue, 01 August 2006 08:42   |
Eike,
OK, so let's start from the cdo/net4j example, and not from my own code.
Here are the slight modifications I make to reproduce the same error I
exeperienced
In the project org.eclipse.emf.cdo.examples.library.ui/src, in
CreateResourceAction, I add the following code at line 125:
124 resource.getContents().add(library);
125 resourceManager.commit(); // my code
126
127
128 // Create a second CDO Resource.
129 System.out.println("--> TEST: Create a second CDO Resource");
In org.eclipse.emf.cdo.examples.server/META-INF, in server.properties:
I simply comment DERBY settings, and uncomment HSQLDB settings.
I start CDO Server, then start the CDO Client1. I click on Create
Library CDO Resource.
Here is the error I get on the server console:
[INFO] net4j.slave-1: Connected socketChannel:
java.nio.channels.SocketChannel[connected local=/127.0.0.1:2036
remote=/127.0.0.1:1673]
Exception in thread "pool-1-thread-2"
org.springframework.dao.DataIntegrityViolationException:
PreparedStatementCallback; SQL [INSERT IGNORE INTO CDO_RESOURCE VALUES (?, ?)];
Unique constraint violation: in statement [INSERT IGNORE INTO CDO_RESOURCE
VALUES (?, ?)]; nested exception is java.sql.SQLException: Unique
constraint violation: in statement [INSERT IGNORE INTO CDO_RESOURCE VALUES (?, ?)]
java.sql.SQLException: Unique constraint violation: in statement
at org.hsqldb.jdbc.jdbcUtil.throwError(Unknown Source)
at org.hsqldb.jdbc.jdbcPreparedStatement.executeUpdate(Unknown Source)
org.springframework.jdbc.core.JdbcTemplate$2.doInPreparedSta tement(JdbcTemplate.java:697)
org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTempl ate.java:476)
at org.springframework.jdbc.core.JdbcTemplate.update(JdbcTempla te.java:691)
at org.springframework.jdbc.core.JdbcTemplate.update(JdbcTempla te.java:753)
at org.springframework.jdbc.core.JdbcTemplate.update(JdbcTempla te.java:761)
at org.eclipse.emf.cdo.server.impl.MapperImpl.sql(MapperImpl.ja va:653)
org.eclipse.emf.cdo.server.impl.MapperImpl.insertResource(Ma pperImpl.java:530)
org.eclipse.emf.cdo.server.protocol.CommitTransactionIndicat ion.receiveNewResources(CommitTransactionIndication.java:133 )
org.eclipse.emf.cdo.server.protocol.CommitTransactionIndicat ion.access$3(CommitTransactionIndication.java:127)
org.eclipse.emf.cdo.server.protocol.CommitTransactionIndicat ion$1.doInTransactionWithoutResult(CommitTransactionIndicati on.java:82)
org.springframework.transaction.support.TransactionCallbackW ithoutResult.doInTransaction(TransactionCallbackWithoutResul t.java:33)
org.springframework.transaction.support.TransactionTemplate. execute(TransactionTemplate.java:114)
org.eclipse.emf.cdo.server.protocol.CommitTransactionIndicat ion.indicate(CommitTransactionIndication.java:74)
org.eclipse.net4j.core.impl.ChannelImpl$SignalTask.processSi gnal(ChannelImpl.java:853)
org.eclipse.net4j.core.impl.ChannelImpl$SignalTask.run(Chann elImpl.java:789)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unkno wn Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
I'm sorry but I was wrong, the problem is probably not related to the
in-memory database, as if I change the settings to a file database, the
error is still there.
This is probably related to this second resourceManager.commit()
statement, though I don't really understand why.
Yannick
> Yannick,
> ResourceManager
> Cheers
> /Eike
>> it works well.
>> connector?
>> Yannick
>>> Eike,
>>> ResourceManager.
>>> jdbc.dialect=HSQLDB
>>> jdbc.username=sa
>>> jdbc.password=
>>> Regards,
>>> Yannick
>>>> Yannick,
>>>> try
>>>> catch (Throwable t)
>>>> Resources.
>>>> Cheers
>>>> /Eike
>>>>> Hi all,
>>>>> the CDO server:
>>>>> Session?
>>>>> Yannick
Re: CDO ResourceManager lifecycle [message #43065 is a reply to message #42734] |
Tue, 01 August 2006 17:54   |
Yannick,
Indeed, that is a bug with new resources not being marked existent after
commit.
I fixed it and committed to HEAD. You should only need to update
org.eclipse.emf.cdo.client.
If you run again into issues, please set the logging priority to debug
in the /org.eclipse.net4j.util/config/log4j.xml
<root>
<priority value="debug"/>
<appender-ref ref="CONSOLE"/>
</root>
Cheers
/Eike
> Eike,
> exeperienced
> 126
> 127
> ?)]; Unique constraint violation: in statement [INSERT IGNORE INTO
> CDO_RESOURCE VALUES (?, ?)]; nested exception is
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> the error is still there.
> Yannick
>> Yannick,
>> for me:
>> ResourceManager
>> multiple top-level objects (libraries).
>> Cheers
>> /Eike
>>> it works well.
>>> connector?
>>> Yannick
>>>> Eike,
>>>> ResourceManager.
>>>> the database is not empty.
>>>> jdbc.dialect=HSQLDB
>>>> jdbc.username=sa
>>>> jdbc.password=
>>>> Regards,
>>>> Yannick
>>>>> Yannick,
>>>>> try
>>>>> catch (Throwable t)
>>>>> It always uses the same URIs.
>>>>> example Resources.
>>>>> Cheers
>>>>> /Eike
>>>>>> Hi all,
>>>>>> on the CDO server:
>>>>>> [INSERT IGNORE INTO CDO_RESOURCE VALUES (?, ?)]"
>>>>>> in the CDO example application), it works fine.
>>>>>> the role of the ResourceManager, as well as the best way to use it.
>>>>>> a resource (as it seems to be in the exampes)?
>>>>>> Session?
>>>>>> Yannick
Re: CDO ResourceManager lifecycle [message #43163 is a reply to message #43065] |
Wed, 02 August 2006 04:44   |
OK, now it works fine !
Yannick
> Yannick,
> commit.
> <root>
> </root>
> Cheers
> /Eike
>> Eike,
>> exeperienced
>> 126
>> 127
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> Regards,
>> Yannick
>>> Yannick,
>>> for me:
>>> ResourceManager
>>> Cheers
>>> /Eike
>>>> it works well.
>>>> connector?
>>>> Yannick
>>>>> Eike,
>>>>> ResourceManager.
>>>>> jdbc.dialect=HSQLDB
>>>>> jdbc.username=sa
>>>>> jdbc.password=
>>>>> Regards,
>>>>> Yannick
>>>>>> Yannick,
>>>>>> try
>>>>>> catch (Throwable t)
>>>>>> example Resources.
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> Hi all,
>>>>>>> on the CDO server:
>>>>>>> Session?
>>>>>>> Yannick
Re: CDO ResourceManager lifecycle [message #43242 is a reply to message #43163] |
Wed, 02 August 2006 07:51  |
Yannick,
I assume you are just playing around a bit with own client code.
That's ok, but I'd like to mention that you don't need two transactions
(commits) in order to add two resources.
Cheers
/Eike
> Thanks
> Yannick
>> Yannick,
>> after commit.
>> debug in the /org.eclipse.net4j.util/config/log4j.xml
>> <root>
>> </root>
>> Cheers
>> /Eike
>>> Eike,
>>> code.
>>> I exeperienced
>>> 126
>>> 127
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source)
>>> the in-memory database, as if I change the settings to a file
>>> database, the error is still there.
>>> Regards,
>>> Yannick
>>>> Yannick,
>>>> for me:
>>>> ResourceManager
>>>> exception. The originally created resources are reused and
>>>> populated with multiple top-level objects (libraries).
>>>> example how to configure it (actually it'd be simpler than NIO).
>>>> Cheers
>>>> /Eike
>>>>> jvm, it works well.
>>>>> connector?
>>>>> Yannick
>>>>>> Eike,
>>>>>> ResourceManager.
>>>>>> seems it's indeed a database issue. However, I don't think it's
>>>>>> because the database is not empty.
>>>>>> server.properties file provided in the CDO example and I just
>>>>>> comment DERBY and uncomment HSQLDB config. Here are these
>>>>>> parameters:
>>>>>> jdbc.dialect=HSQLDB
>>>>>> jdbc.username=sa
>>>>>> jdbc.password=
>>>>>> execution. But this also means that hsqldb is launched in-memory,
>>>>>> so the database should be empty on start.
>>>>>> Regards,
>>>>>> Yannick
>>>>>>> Yannick,
>>>>>>> try
>>>>>>> catch (Throwable t)
>>>>>>> your database is simply not empty.
>>>>>>> simple. It always uses the same URIs.
>>>>>>> example Resources.
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> Hi all,
>>>>>>>> violation on the CDO server:
>>>>>>>> it.
>>>>>>>> load a resource (as it seems to be in the exampes)?
>>>>>>>> Session?
>>>>>>>> Yannick
Re: CDO ResourceManager lifecycle [message #583841 is a reply to message #42213] |
Yannick,
try
catch (Throwable t)
Resources.
prior to that.
Cheers
/Eike
> Hi all,
> the CDO server:
> Yannick
Re: CDO ResourceManager lifecycle [message #583965 is a reply to message #42316] |
Eike,
ResourceManager.
jdbc.dialect=HSQLDB
jdbc.username=sa
jdbc.password=
Yannick
> Yannick,
> try
> catch (Throwable t)
> Resources.
> prior to that.
> Cheers
> /Eike
>> Hi all,
>> the CDO server:
>> Yannick
Re: CDO ResourceManager lifecycle [message #584016 is a reply to message #42514] |
works well.
Yannick
> Eike,
> ResourceManager.
> jdbc.dialect=HSQLDB
> jdbc.username=sa
> jdbc.password=
> Yannick
>> Yannick,
>> try
>> catch (Throwable t)
>> Resources.
>> Cheers
>> /Eike
>>> Hi all,
>>> the CDO server:
>>> Yannick
Re: CDO ResourceManager lifecycle [message #584059 is a reply to message #42612] |
Yannick,
ResourceManager
Cheers
/Eike
> it works well.
> connector?
> Yannick
>> Eike,
>> ResourceManager.
>> jdbc.dialect=HSQLDB
>> jdbc.username=sa
>> jdbc.password=
>> Regards,
>> Yannick
>>> Yannick,
>>> try
>>> catch (Throwable t)
>>> Resources.
>>> Cheers
>>> /Eike
>>>> Hi all,
>>>> the CDO server:
>>>> Session?
>>>> Yannick
Re: CDO ResourceManager lifecycle [message #584084 is a reply to message #42705] |
Eike,
exeperienced
126
127
Yannick
> Yannick,
> ResourceManager
> Cheers
> /Eike
>> it works well.
>> connector?
>> Yannick
>>> Eike,
>>> ResourceManager.
>>> jdbc.dialect=HSQLDB
>>> jdbc.username=sa
>>> jdbc.password=
>>> Regards,
>>> Yannick
>>>> Yannick,
>>>> try
>>>> catch (Throwable t)
>>>> Resources.
>>>> Cheers
>>>> /Eike
>>>>> Hi all,
>>>>> the CDO server:
>>>>> Session?
>>>>> Yannick
Re: CDO ResourceManager lifecycle [message #584229 is a reply to message #42734] |
Yannick,
commit.
<root>
</root>
Cheers
/Eike
> Eike,
> exeperienced
> 126
> 127
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> Yannick
>> Yannick,
>> for me:
>> ResourceManager
>> Cheers
>> /Eike
>>> it works well.
>>> connector?
>>> Yannick
>>>> Eike,
>>>> ResourceManager.
>>>> jdbc.dialect=HSQLDB
>>>> jdbc.username=sa
>>>> jdbc.password=
>>>> Regards,
>>>> Yannick
>>>>> Yannick,
>>>>> try
>>>>> catch (Throwable t)
>>>>> example Resources.
>>>>> Cheers
>>>>> /Eike
>>>>>> Hi all,
>>>>>> on the CDO server:
>>>>>> Session?
>>>>>> Yannick
Re: CDO ResourceManager lifecycle [message #584285 is a reply to message #43065] |
Yannick
> Yannick,
> commit.
> <root>
> </root>
> Cheers
> /Eike
>> Eike,
>> exeperienced
>> 126
>> 127
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> Regards,
>> Yannick
>>> Yannick,
>>> for me:
>>> ResourceManager
>>> Cheers
>>> /Eike
>>>> it works well.
>>>> connector?
>>>> Yannick
>>>>> Eike,
>>>>> ResourceManager.
>>>>> jdbc.dialect=HSQLDB
>>>>> jdbc.username=sa
>>>>> jdbc.password=
>>>>> Regards,
>>>>> Yannick
>>>>>> Yannick,
>>>>>> try
>>>>>> catch (Throwable t)
>>>>>> example Resources.
>>>>>> Cheers
>>>>>> /Eike
>>>>>>> Hi all,
>>>>>>> on the CDO server:
>>>>>>> Session?
>>>>>>> Yannick
Re: CDO ResourceManager lifecycle [message #584340 is a reply to message #43163] |
Yannick,
Cheers
/Eike
> Thanks
> Yannick
>> Yannick,
>> after commit.
>> <root>
>> </root>
>> Cheers
>> /Eike
>>> Eike,
>>> code.
>>> I exeperienced
>>> 126
>>> 127
>>> Source)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source)
>>> Regards,
>>> Yannick
>>>> Yannick,
>>>> for me:
>>>> ResourceManager
>>>> Cheers
>>>> /Eike
>>>>> jvm, it works well.
>>>>> connector?
>>>>> Yannick
>>>>>> Eike,
>>>>>> ResourceManager.
>>>>>> parameters:
>>>>>> jdbc.dialect=HSQLDB
>>>>>> jdbc.username=sa
>>>>>> jdbc.password=
>>>>>> Regards,
>>>>>> Yannick
>>>>>>> Yannick,
>>>>>>> try
>>>>>>> catch (Throwable t)
>>>>>>> example Resources.
>>>>>>> Cheers
>>>>>>> /Eike
>>>>>>>> Hi all,
>>>>>>>> it.
>>>>>>>> Session?
>>>>>>>> Yannick
Current Time: Fri Jul 18 22:30:26 EDT 2025
Powered by FUDForum. Page generated in 0.08293 seconds
