Home » Eclipse Projects » Plugin Development Environment (PDE) » headless build trying to build a plugin from eclipse-sdk
headless build trying to build a plugin from eclipse-sdk [message #3634] Fri, 23 May 2008 06:11 Go to next message
I've got a weird problem here, using the headless build stuff. I have the
eclipse sdk thats used to build and package my RCP app extended to include
a python support plugin. However as soon as my RCP app requires that plugin
the build goes completely wrong, for some reason the generated scripts for
the headless builds pick up that support plugin as something that they also
need to build instead of a "binary" plugin just like all the other plugins
in the SDK.
Does somebody have an idea why this might happen? If anybody needs logs or
the assemble.* files I can post them as well.
Andreas
Re: headless build trying to build a plugin from eclipse-sdk [message #3730 is a reply to message #3634] Fri, 23 May 2008 17:09 Go to previous messageGo to next message
Andreas,
The headless build decides that a plugin is "binary" if it is a folder
and has a "build.properties" file in its root.
If this bundle is binary but has a build.properties file for some other
reason then you are going to have problems. You would likely need to
add pde.build properties to the file get it assembled without trying to
compile it.
-Andrew
Andreas Pakulat wrote:
> in the SDK.
> Andreas
Re: headless build trying to build a plugin from eclipse-sdk [message #4083 is a reply to message #3730] Fri, 23 May 2008 19:14 Go to previous message
Hi Andrew,
thanks, removing the build.properties solved my building problem.
Andreas
Andrew Niefer wrote:
> Andreas,
> compile it.
> -Andrew
>> include a python support plugin. However as soon as my RCP app requires
>> that plugin the build goes completely wrong, for some reason the
>> generated scripts for the headless builds pick up that support plugin as
>> something that they also need to build instead of a "binary" plugin just
>> like all the other plugins in the SDK.
>> or the assemble.* files I can post them as well.
>> Andreas
Re: headless build trying to build a plugin from eclipse-sdk [message #567207 is a reply to message #3634] Fri, 23 May 2008 17:09 Go to previous message
Andreas,
compile it.
-Andrew
> in the SDK.
> Andreas
Re: headless build trying to build a plugin from eclipse-sdk [message #567242 is a reply to message #3730] Fri, 23 May 2008 19:14 Go to previous message
Hi Andrew,
Andreas
> Andreas,
> compile it.
> -Andrew
>> Andreas
Previous Topic:plugin fragment extensions not loaded
Next Topic:Showing two editors (Horizontal or vertical split) programmatically
Current Time: Tue Jul 22 08:57:43 EDT 2025
Powered by FUDForum. Page generated in 0.05231 seconds
