Home » Archived » M2M (model-to-model transformation) » [ATL] New ATL use case: Using a UML modeler to generate metamodels
[ATL] New ATL use case: Using a UML modeler to generate metamodels [message #42168] Sun, 27 May 2007 21:05 Go to next message
Originally posted by: freddy.allilaire.univ-nantes.fr
Dear all,
A new ATL use case is available: Using a UML modeler to generate metamodels
This use case shows how to use and integrate a model transformation
service in a UML Modeler to generate metamodels conforming to KM3, MOF
1.4, and Ecore. The used UML Modeler is Papyrus (CEA LIST).
The use case is available at:
http://www.eclipse.org/m2m/atl/usecases/UML2MOF/
Freddy.
Freddy Allilaire - ATLAS Group (INRIA & LINA)
http://www.sciences.univ-nantes.fr/lina/atl/contrib/allilair e
Re: [ATL] New ATL use case: Using a UML modeler to generate metamodels [message #42621 is a reply to message #42168] Mon, 28 May 2007 12:10 Go to previous messageGo to next message
Originally posted by: rb_account.yahoo.de
Great news! Modelling the Metamodel as class diagramm is easier than
modelling it with the built-in ecore-editor.
However, with the current version 1.6.1, I don't have access to the
function "Generate metamodel" in the context-menu.
I used the RCP-Version - there should be no difference to the
eclipse-plugin Version cause it's also 1.6.1.
Where can I get a version which supports the ATL transformation?
Rainer
Am 28.05.2007, 03:05 Uhr, schrieb Freddy Allilaire
<freddy.allilaire@univ-nantes.fr>:
> Dear all,
> metamodels
> Freddy.
Erstellt mit Operas revolutionärem E-Mail-Modul: http://www.opera.com/mail/
Re: [ATL] New ATL use case: Using a UML modeler to generate metamodels [message #42682 is a reply to message #42621] Mon, 28 May 2007 12:14 Go to previous messageGo to next message
I agree. However, I personally consider that metamodeling in KM3 (with
the KM3 editor) is even more straightforward and efficient ;-).
Frédéric Jouault
Re: [ATL] New ATL use case: Using a UML modeler to generate metamodels [message #42746 is a reply to message #42621] Mon, 28 May 2007 17:54 Go to previous messageGo to next message
Hi Rainer,
Papyrus team is integrating this feature. This will be available in next
release.
Freddy.
> Rainer
>> Dear all,
>> metamodels
>> Regards,
>> Freddy.
> --Erstellt mit Operas revolutionärem E-Mail-Modul:
Re: [ATL] New ATL use case: Using a UML modeler to generate metamodels [message #44792 is a reply to message #42746] Wed, 06 June 2007 05:26 Go to previous message
This feature is now available with the last Papyrus version.
More details are available in download section of this use case:
http://www.eclipse.org/m2m/atl/usecases/UML2MOF/#download
Freddy.
Freddy Allilaire a écrit :
> Hi Rainer,
> release.
> Freddy.
>> Regards,
>> Rainer
>>> Dear all,
>>> metamodels
>>> MOF 1.4, and Ecore. The used UML Modeler is Papyrus (CEA LIST).
>>> Regards,
>>> Freddy.
Previous Topic:[ATL] XML2BPEL
Next Topic:[ATL] New ATL use case: Measuring UML models
Current Time: Fri Jul 18 00:12:14 EDT 2025
Powered by FUDForum. Page generated in 0.06490 seconds
