Home » Modeling » TMF (Xtext) » [Xtext] Workflow invocation yields "Incompatible Classes" error
[Xtext] Workflow invocation yields "Incompatible Classes" error [message #42138] Tue, 28 April 2009 07:25 Go to next message
Hi all,
I'm trying to call workflow B from workflow A and then to invoke the
XtendComponent like so:
<component class="org.eclipse.xtend.XtendComponent">
<metaModel
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel "/>
<invoke value="${topFunctionCallExpression}" />
<outputSlot value="otherModel" />
</component>
It get the following error message when running workflow A:
SEVERE: [ERROR]: Incompatible Classes:
'org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel' is not a
subclass of the expected class
'org.eclipse.xtend.typesystem.MetaModel'.(Element: bean metaModel
class='org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel ' in
org/example/test/model2model.mwe:12; Reported by: -UNKNOWN-)
The error traces back to the VisitorAnalyzer class (visitComponentAST()
method). I get a bit confused by the error message.. is that correct?
Johan
Re: [Xtext] Workflow invocation yields "Incompatible Classes" error [message #42371 is a reply to message #42138] Wed, 29 April 2009 04:40 Go to previous message
Hi Johan,
are you running the workflow within OSGi?
Is it possible to provide a stripped down example?
If it contains information you don't want to share publicly, you can
send it to me directly.
Sven
Johan Wannheden schrieb:
> Hi all,
> <metaModel
> </component>
> Johan
Previous Topic:[Announce] TMF XTEXT 0.7.0 I200904271049 is available
Next Topic:DSL2Model
Current Time: Tue Jul 22 01:49:06 EDT 2025
Powered by FUDForum. Page generated in 0.03015 seconds
