Home » Language IDEs » AspectJ » aspects across eclipse projects?
aspects across eclipse projects? [message #42057] |
Mon, 04 October 2004 12:31  |
Hi again - and sorry for my high NG volume! I seem to keep bumping
into all kinds of problem today...
We are writing some code, that should NOT use static variables since
that may make later multi-threading or "componentization" of the code
more difficult than necessary.
Ah - "a case for AspectJ!" I thought at first but now I am running
into the problem, that AJDT seems to declare warnings only for files
within the same project. Is that so? Since when? I am pretty sure,
that I have written aspects that have worked accross project
boundaries under older AJDT versions (i.e. 1.1.10 and earlier).
I boiled that down to the following tiny example: a classes and an
aspect:
class Test: - has a static and a non-static field and fiddles a bit
with both...
package test;
public class Test
public static int a = 2;
public int b;
public Test() {
super();
methodA(a);
public void methodA(int x) {
System.out.println("methodA: " + x);
b = x;
a = x*2;
aspect FlagStatics: should flag accesses to the static field:
package test;
public aspect FlagStatics
pointcut allStaticVariableAccesses():
get(* test.*.*)
set(* test.*.*)
declare warning:
: "Warning: use of static variable";
If the above two files reside within the same project things work and
the locations where the static field is set or used are properly
flagged.
If I separate these file into TWO projects, i.e. the file Test.java in
one project, the file FlagStatics.aj in another then no warnings are
emitted, no matter whether I make the first project import the second
or vice versa.
I tried the Java Build Path-s as well as the project references
settings, but couldn't get things to work. How do I apply an aspect
within a project to (an) other project(s)?
Michael
Re: aspects across eclipse projects? [message #42185 is a reply to message #42057] |
Mon, 04 October 2004 16:58   |
Originally posted by: mchapman.uk.ibm.com
Hi Michael,
Thanks for the simple example, it makes it easier to explain. Say you have
Test.java in project A, and FlagStatics.aj in project B, one way to think
of it is as that project B contains your aspect library - aspects which
you want to weave into other code. So you create your aspect library as a
JAR file, by entering a name, say library.jar into the "output jar" field
of the "AspectJ" section of the project's properties page. Now hit the
build button and the library.jar file will be created. Back to project A.
Aspects you want to weave are provided on the aspect path, so simply go to
the "AspectJ Aspect Path" section of project A's properties page, and add
the library.jar from project B, and hit the build button. That should do
the trick - I just followed it through on 1.1.12 to make sure I didn't
miss anything. It should also work the same on 1.2.0 development
builds.
Matt.
On Mon, 04 Oct 2004 18:31:46 +0200, Michael Moser wrote:
> Hi again - and sorry for my high NG volume! I seem to keep bumping into
> Ah - "a case for AspectJ!" I thought at first but now I am running into
> the problem, that AJDT seems to declare warnings only for files within
> the same project. Is that so? Since when? I am pretty sure, that I have
> written aspects that have worked accross project boundaries under older
> aspect:
> flagged.
> emitted, no matter whether I make the first project import the second or
> vice versa.
> Michael
Re: aspects across eclipse projects? [message #42425 is a reply to message #42244] |
Tue, 05 October 2004 06:28   |
> There's been some confusion in general amongst users of AspectJ and
AJDT
> regarding the difference between classpath, inpath, aspectpath, and
what
> they all mean. Rather than replying directly in this thread, I've
written
> a short piece describing the differences and how they work, that you
can
> find at:
http://www.aspectprogrammer.org/blogs/adrian/2004/10/three_p aths_sta.html
> Hope it helps to clarify things a little.
It did indeed - I think... ;-)
Thanks!
I guess the misunderstanding was on my side. I started to create a
project that contains misc. compile time aspects to enforce or check
for adherence to misc. policies and imported a couple of existing
projects.
My idea had been that - as long as this aspect project is "active",
i.e. open - these checks get "woven into the code" of the other
currently open projects (although most advice don't actually generate
code but rather are declare statements only).
If the project containing my aspects would be closed, i.e. "inactive",
then these aspects should NOT get built nor "woven in" or dealt with
in any form. Thus by triggering a clean & rebuild after
opening/closing a project I had intended to be able to generate
different versions of misc. other projects.
But this - if I understand your writeup and Matt's response
correctly - is not really possible (and maybe not even desireable...).
Rather, one needs the aspect-project to generate some .jar or library
which is then made part of the aspectpath (or potentially inpath) of
the other projects and then gets woven into those when these projects
are (re)built.
Which means - in order to enable/disable my aspects I either have to
fiddle with a couple of aspect-/in-paths each time (or I find a
mechanism to enable/disable all my aspects in one go, e.g. generate an
empty .jar or something of that sort...).
I think my confusion stemmed from the two different possible ways of
looking at this entire "aspectization process" when spreaded over 2 or
more projects:
a.) An aspect prior needs to exist and is woven into a project during
a build (which means it has to be part of the class-/in-/aspect-path
during the build which implies that the project containing the aspect
must have been built before).
vs.
b.) an aspect is "added" to a project after it has been built (in a
kind of second "round" or re-build) in which case building a project
might (& will!) fiddle and modify imported and already existing and
built files. This is of course somewhat touchy and not very
transparent...
For some reason I had assumed things to work like in b.) while
actually they seem to work like in a.)
Sorry for this rambling but maybe it can at least serve to give you an
idea how far off people can be in understanding your stuff... :-)
Michael
Re: aspects across eclipse projects? [message #42576 is a reply to message #42546] |
Wed, 06 October 2004 03:47   |
> Hi Helen,
> > It's a bit concerning that you sometimes have to do a build all
> several
> > times - can you give more details about your set up?
> What exactly would you like to know? When it happens I suddenly have
> like 200+ error messages re. non-resolvable imports after a
> clean-build. I then do a clean-build again and they are all gone.
> I am using Eclipse 3.0.1 with AJDT 1.2M1 (1.2.0.20041002192124). Let
> me know what else could be of help.
> The effect isn't very frequent and , alas, not really reproducible (at
> least I haven't observed any pattern, yet, that allows me to reproduce
> it). It has become much less frequent though since I am using the
> include/exclude from build feature that I just learned about today.
> Before I had more often fiddled with the build-settings, maybe that is
> one of the reasons.
> It hasn't fully disappeared though and I still had such a case right
> now, which is why I am responding. Sorry, that I can't be more
> specific and helpful...
> Michael
Hi Michael,
Sorry I wasn't more specific :-(
What I meant to ask was about your setup with project dependencies - are
all your projects AJ projects, or do you have Java projects depending on
AJ projects (and do they have project dependencies rather than something
like class folder dependencies --> the build path section in the project
properties and then either the projects or libraries tab)?
Hopefully, when the bug about automatically triggering a rebuild in these
circumstances has been fixed, you will no longer see this problem. If you
do continue to see it please raise a bug.
Thanks, Helen
Re: aspects across eclipse projects? [message #42665 is a reply to message #42185] |
Tue, 12 October 2004 06:43   |
Originally posted by: geirAoves.online.no
Your solution works in the sense that I can compile my projects, and the
aspects are woven properly. HOWEVER, in Eclipse 3.01 using AJDT 1.1.12, the
places Advices is NOT marked in the editor in the Java code. The affected
methods are also NOT marked in the Method / Outline view in the Java code,
and the Outline for the Aspect does NOT show which methods in the Java code
that are advised.
I have in vain tried to report this many times now: Is there a solution? Use
another version of AJDT ???
Geir Ove
"Matt Chapman" <mchapman@uk.ibm.com> wrote in message
news:pan.2004.10.04.20.58.19.298074@uk.ibm.com...
> Hi Michael,
> builds.
> Matt.
> > aspect:
> > flagged.
> > vice versa.
> > Michael
Re: aspects across eclipse projects? [message #42697 is a reply to message #42665] |
Tue, 12 October 2004 08:41   |
> the places Advices is NOT marked in the editor in the Java code. The
> affected methods are also NOT marked in the Method / Outline view in the
> Java code, and the Outline for the Aspect does NOT show which methods in
> the Java code that are advised.
> Use another version of AJDT ???
Hi Geir,
This should work fully with Eclipse 3.0.1 and AJDT 1.1.12. We're trying to
work out what is different about your setup or environment that prevents
this from working for you. You raised bug 75594 for this issue, and I made
some requests for further information there. You should have received
email notification about this. Please help us get to the bottom of this
problem by responding there. Here is a link to the bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=75594
Matt.
Re: aspects across eclipse projects? [message #45462 is a reply to message #45403] |
Tue, 04 January 2005 07:33  |
Ivan Dubrov wrote:
> In the current situation I do not know how to setup build process for
> dependent plugin projects. One plugin project contains aspects, other plugin
> project depends on it. Aspects from first project should be weaved into
classes
> of second project. The solution with the "output jar" is not good, because
it
> messes plugin build process.
By the way, I found the acceptable solution. Just add a new ANT builder to
the
project providing the aspect classes. The ANT script should just jar
classes
from output directory into jar. Then feed this jar to the dependent
projects
that require aspects from the first project.
This is different from setting "output jar" in the configuration in the
following
way: weaved classes are left in the output folder and could be used by
plugin
build/export process. Setting "output jar" makes weaved classes put
directly
into jar and not in output directory.
Re: aspects across eclipse projects? [message #583839 is a reply to message #42057] |
Hi Michael,
builds.
Matt.
> aspect:
> flagged.
> vice versa.
> Michael
Re: aspects across eclipse projects? [message #583853 is a reply to message #42185] |
Tue, 05 October 2004 04:58  |
Hi Matt,
thanks for your help. Your described solution worked!
I am only a bit puzzled why one needs to build a .jar file first. In
the described case, the advice doesn't generate any code (it only
contains a "declare warning") so why or what goes into that .jar???
Michael
Re: aspects across eclipse projects? [message #583871 is a reply to message #42212] |
Tue, 05 October 2004 05:15  |
> Hi Matt,
> Michael
There's been some confusion in general amongst users of AspectJ and AJDT
regarding the difference between classpath, inpath, aspectpath, and what
they all mean. Rather than replying directly in this thread, I've written
a short piece describing the differences and how they work, that you can
find at:
Regards, Adrian.
Re: aspects across eclipse projects? [message #583891 is a reply to message #42212] |
Tue, 05 October 2004 05:46  |
Another observation in that context:
It seems that the automatic build doesn't work at all in such
situations. And even the manual build occasionally fails to rebuild
things properly. Often I suddenly get hundreds of "<xyz> can't be
resolved" errors. I practically always have to do a Clean All and
Rebuild All (sometimes even twice!) to get all things properly
rebuilt.
But I guess that's known and you are working on this, isn't it? This
is on 1.2.0.20041002192124
Michael
Re: aspects across eclipse projects? [message #583928 is a reply to message #42265] |
Tue, 05 October 2004 06:11  |
> rebuilt.
> Michael
Hi Micahel,
There is a bug open looking at when rebuilds should be triggered if
"automatic rebuilding" is enabled:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=73859
An extension to this is that an AJ build should be triggered when the
classpath changes (which it currently isn't).
https://bugs.eclipse.org/bugs/show_bug.cgi?id=74174
Both are being worked on at the moment and will hopefully be fixed soon.
It's a bit concerning that you sometimes have to do a build all several
Thanks, Helen
Re: aspects across eclipse projects? [message #583942 is a reply to message #42265] |
> rebuilt.
> Michael
Hi Micahel,
Thanks, Helen
Re: aspects across eclipse projects? [message #583972 is a reply to message #42212] |
Tue, 05 October 2004 06:31  |
On Tue, 05 Oct 2004 10:58:42 +0200, Michael Moser wrote:
> Hi Matt,
> I am only a bit puzzled why one needs to build a .jar file first. In the
> described case, the advice doesn't generate any code (it only contains a
The bytecodes for the aspect go into the jar file. I think the reason for
needing to build the jar file stems from the -aspectpath option to
the AspectJ compiler, which accepts only jar files. The inpath and
classpath also accept directories. Maybe -aspectpath could accept
directories too? If it did AJDT could add support for specifying an aspect
path entry as the output directory of another project. Feel free to submit
an enhancement request if you think this would be useful.
Matt.
Re: aspects across eclipse projects? [message #583985 is a reply to message #42244] |
AJDT
what
written
can
> find at:
Thanks!
projects.
are (re)built.
more projects:
vs.
transparent...
Michael
Re: aspects across eclipse projects? [message #584009 is a reply to message #42425] |
Tue, 05 October 2004 09:07  |
> fiddle with a couple of aspect-/in-paths each time (or I find a mechanism
> to enable/disable all my aspects in one go, e.g. generate an empty .jar or
Hi Michael,
The mechanism to enable and disable aspects is known as "build
configurations". Please see the docs on this topic for more info, but in
summary you can just right-click on one or more aspects (or classes or
packages, or a combination) and include or exclude them from the current
build configuration. So in your example you could right-click and exclude
FlagStatics.aj in project B. You then need to rebuild project A, and the
warnings will disappear. You can also store a set of includes and excludes
in a .ajproperties file for later use.
Matt.
Re: aspects across eclipse projects? [message #584033 is a reply to message #42456] |
Tue, 05 October 2004 11:16  |
Hey - this is brilliant! EXACTLY what I need!
Chapeau - You guys really think ahead!
Michael
news:pan.2004.10.05.13.07.37.75304@uk.ibm.com...
but in
or
current
Re: aspects across eclipse projects? [message #584045 is a reply to message #42313] |
Tue, 05 October 2004 16:51  |
Hi Helen,
several
one of the reasons.
Michael
Re: aspects across eclipse projects? [message #584060 is a reply to message #42546] |
> Hi Helen,
> several
> one of the reasons.
> Michael
Hi Michael,
Thanks, Helen
Re: aspects across eclipse projects? [message #584110 is a reply to message #42185] |
that are advised.
Geir Ove
> Hi Michael,
> builds.
> Matt.
> > aspect:
> > flagged.
> > vice versa.
> > Michael
Re: aspects across eclipse projects? [message #584129 is a reply to message #42665] |
Hi Geir,
Matt.
Re: aspects across eclipse projects? [message #585490 is a reply to message #42390] |
Sun, 02 January 2005 13:03  |
Yes, seems like this would be very useful feature.
dependent
plugin projects. One plugin project contains aspects, other plugin project
depends on it. Aspects from first project should be weaved into classes of
second
project. The solution with the "output jar" is not good, because it messes
plugin
build process.
Re: aspects across eclipse projects? [message #585511 is a reply to message #45403] |
classes
it
the
classes
projects
following
plugin
directly
Current Time: Mon Jul 21 21:59:10 EDT 2025
Powered by FUDForum. Page generated in 0.09818 seconds
