Home » Modeling » OCL » accessing uml attributes from queries
accessing uml attributes from queries [message #42037] |
Wed, 31 October 2007 04:08  |
Originally posted by: krzysztof_kaczmarski.o2.pl
Hi All,
I have a question concerning the OCL standard.
If there is a UML class like:
class Person {
dogs : Dog[0..*];
and I want to access these attributes from OCL then
'dogs' are treated like a Collection type... but I noticed in OCL
Console example that 'name' is also treated as a collection.
Am I right?
If it is true, are the flags {ordered} and {unique} taken into
consideration when particular collection type is used resulting in
proper Set, or OrderedSet.. etc types?
Thanks in advance,
Krzysztof
Re: accessing uml attributes from queries [message #42131 is a reply to message #42037] |
Wed, 31 October 2007 08:12   |
Hi, Krzysztof,
Person::name in OCL would have a scalar type, not a collection. I think
this works OK in the MDT OCL implementation. What are you seeing in the
interactive console example that suggests it is a collection type? If you
are navigating to Person through some other association, you may be have an
implicit "collect" iterator that results in a collection. For example,
self.dog.owner.name
might be a collection if the association between the "self" type and Dog is
multivalued.
The {ordered} and {unique} flags determine the collection type for
multiplicity-many features, yes (in the MDT OCL implementation).
Christian
Krzysztof Kaczmarski wrote:
> Hi All,
> class Person {
> dogs : Dog[0..*];
> Am I right?
> Thanks in advance,
> Krzysztof
Re: accessing uml attributes from queries [message #42336 is a reply to message #42131] |
Wed, 31 October 2007 17:43   |
Hi Christian,
maybe this is just my misunderstanding of the suggestions tool.
The class is like:
class A
z : Integer[1..1];
I open it in a model, set focus to the class A,
select UML and M1.
Now I write 'z.' and I get suggestions connected to Integer type (abs,
etc).
When I write 'z->' I get suggestions as if z is a collection (collect,
sellect, isEmpty, etc.)
And when I write 'z->isEmpty()' I even get 'successfully parsed' message.
Krzysztof
Christian W. Damus wrote:
> Hi, Krzysztof,
> self.dog.owner.name
> multivalued.
> Cheers,
> Christian
>> Hi All,
>> class Person {
>> dogs : Dog[0..*];
>> Am I right?
>> Thanks in advance,
>> Krzysztof
Re: accessing uml attributes from queries [message #42602 is a reply to message #42336] |
Thu, 01 November 2007 10:38  |
Hi, Krzysztof,
The -> operator, when applied to a scalar property, coerces it to a Set
type. In the case that 'z' is undefined (null), the result is an empty
set. Otherwise, it is a Set containing the single value of 'z'.
Christian
> Hi Christian,
> The class is like:
> class A
> z : Integer[1..1];
> select UML and M1.
> etc).
> Cheers,
> Krzysztof
-----8<-----
Current Time: Mon Jul 21 22:24:07 EDT 2025
Powered by FUDForum. Page generated in 0.07384 seconds
