Home » Eclipse Projects » Subversive » external compare editor failed
external compare editor failed [message #42032] Sun, 22 February 2009 06:24 Go to next message
I'm getting an error when trying to compare two versions of a file. I'm
not actually trying to use an external editor. I was assuming it would use
the internal one.
"External compare was failed.
Cannot run program "C:/Program": CreateProcess error=2, The system cannot
find the file specified"
I guess it can't find the executable compare editor. Can it be set to use
the default eclipse compare editor?
more info
Just as test, if I install tortoiseSVN it finds the tortoise compare
editor.
org.eclipse.team.svn.core.operation.local.RunExternalCompare Operation$ExternalCompareOperationHelper.execute(RunExternal CompareOperation.java:218)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot
Re: external compare editor failed [message #42065 is a reply to message #42032] Wed, 25 February 2009 05:00 Go to previous messageGo to next message
Originally posted by: b_apolci.libero.it
The same just happened to me.
It seems that with the last update a new configuration appeared in the
preferences (Team->SVN->Diff Viewer) and the default values for the File
Associations tabs reflect a particular configuration (may be the one of
the developer) that requires TortoiseSVN.
I just unchecked the two file associtation active and the problem
disappeared.
Andrea
> use the internal one.
> "External compare was failed. Cannot run program "C:/Program":
> CreateProcess error=2, The system cannot find the file specified"
> use the default eclipse compare editor?
> more info
> editor.
Re: external compare editor failed [message #42718 is a reply to message #42065] Fri, 27 February 2009 10:15 Go to previous messageGo to next message
By mistake, build contained part of new functionality(related to external
compare editor). Please, update to latest version, it's fixed now
> disappeared.
> Andrea
>> more info
>> editor.
Re: external compare editor failed [message #43174 is a reply to message #42718] Thu, 12 March 2009 12:01 Go to previous message
thanks, it fixed it.
Previous Topic:Different results using compare view and svn diff
Next Topic:js files not being numbered/decorated?
Current Time: Mon Jul 21 21:44:34 EDT 2025
Powered by FUDForum. Page generated in 0.05982 seconds
