Memory-saving strategies (e.g. Partial XMI loading)? [message #415994] |
Tue, 15 January 2008 16:00 |
Stefan Winkler Messages: 307 Registered: July 2009 Location: Germany |
Hi all,
what are best practices to keep the memory consumption of models as
small as possible? Any pointers or hints concerning this topic are welcome.
I did some memory profiling tests this week and found out that a simple
EObject containing one String attribute (100 chars) can be created about
3,500,000 times with 1GB of Java heap space. While this may seem enough
for most people, I am not able to predict, if this is enough for my project.
So I am looking for ways to deal with more than 3,500,000 objects.
One idea that came to me was to only keep parts of the models in memory
while loading needed EObjects lazyly. Is there a simple way to achieve
this?
Do I always have to load an XMI entirely? If yes, could I store each
EObject in a separate XMI and use inter-file-references?
Any other ideas on this subject?
Stefan
Re: Memory-saving strategies (e.g. Partial XMI loading)? [message #415997 is a reply to message #415994] |
Tue, 15 January 2008 16:23 |
Ed Merks Messages: 33142 Registered: July 2009 |
Stefan,
Splitting your instance across multiple resources can help a lot since
resources themselves are loaded on demand. But the contents of a single
resource are processed in their entirety so having one huge resource is
not a great approach. Technologies like Teneo and CDO in the EMFT
project support more lazy forms of loading, but are backed by a
database, not XMI files. SDO exploits EMF's EStore API which
essentially allows you to treat your EObjects as wrappers that delegate
to a store where the real data lives and then the store itself can be
managed using whatever smart technique make sense.
Stefan Winkler wrote:
> Hi all,
> welcome.
> simple EObject containing one String attribute (100 chars) can be
> created about 3,500,000 times with 1GB of Java heap space. While this
> may seem enough for most people, I am not able to predict, if this is
> memory while loading needed EObjects lazyly. Is there a simple way to
> achieve this?
> Cheers,
> Stefan
Ed Merks
FUDForum. Page generated in 0.04317 seconds
