Home » Eclipse Projects » Subversive » Software Update problems
Software Update problems [message #41999] Thu, 19 February 2009 17:44 Go to next message
Originally posted by: bob.finch.wwu.edu
I ran Software Updates today which installed new versions of the
Subversive SVN Team Provider and connectors. Now when I try to install
Eclipse BIRT Report Designer Framework and Eclipse BIRT Report Designer
Framework SDK I get the following error:
Cannot complete the request. See the details.
Cannot find a solution satisfying the following requirements
Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.polarion.eclipse.team.svn.conn ector.feature.jar/[2.1.0.I20090213-1500,2.1.0.I20090213-1500 ]].
How can I fix this?
-- Bob
Re: Software Update problems [message #42275 is a reply to message #41999] Thu, 26 February 2009 06:08 Go to previous message
Hello Bob,
Most likely this problem relates to p2. Probably when installing Birt,
Subversive was also selected. Did you manage to install Birt when Subversive
isn't installed?
>I ran Software Updates today which installed new versions of the Subversive
>SVN Team Provider and connectors. Now when I try to install Eclipse BIRT
>Report Designer Framework and Eclipse BIRT Report Designer Framework SDK I
> How can I fix this?
> -- Bob
Previous Topic:Hide Subversive contextual menu items
Next Topic:retrieving the exact revision number of the "SVNRevision#BASE" revision
Current Time: Mon Jul 21 21:51:55 EDT 2025
Powered by FUDForum. Page generated in 0.06674 seconds
