Home » Modeling » EMF » BasicEMap not an InternalEObject?
BasicEMap not an InternalEObject? [message #415783] |
Sun, 06 January 2008 22:05 |
Originally posted by: eclipse.efef.dk
org.eclipse.emf.common.util.BasicEMap cannot be cast to
org.eclipse.emf.ecore.InternalEObject
Can be reproduced by this small example
(using EMF ecore 2.3.1.v200709252135).
What am I doing wrong? (I suppose I should get the EMap from somewhere
else, a factory probably, but it fails me, so the BasicEMap seemed like
a nice shortcut).
/\/ikolaj
=========== BEGIN MapContainer ========================================
package test;
import org.eclipse.emf.common.util.EMap;
import org.eclipse.emf.ecore.EObject;
* @author berntsen
* @model
* <!-- begin-model-doc -->
* <!-- end-model-doc -->
public interface MapContainer extends EObject {
* @model containment="true"
* @return
EMap<String, String> getStrStrMap();
* Sets the value of the '{@link test.MapContainer#getStrStrMap <em>Str
Str Map</em>}' containment reference.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @param value the new value of the '<em>Str Str Map</em>' containment
reference.
* @see #getStrStrMap()
* @generated
void setStrStrMap(EMap<String, String> value);
=========== END MapContainer ========================================
=========== BEGIN Driver ========================================
package driver;
import org.eclipse.emf.common.util.BasicEMap;
import test.MapContainer;
import test.TestFactory;
public class Driver {
MapContainer mapContainer = TestFactory.eINSTANCE.createMapContainer();
System.out.println(mapContainer.getStrStrMap()); // null
// so we want to create an EMap:
EMap<String, String> strStrEMap = new BasicEMap<String, String>();
strStrEMap.put("1", "2");
mapContainer.setStrStrMap(strStrEMap);
System.out.println(mapContainer);
=========== END Driver ========================================
=========== BEGIN system.out ========================================
null
Exception in thread "main" java.lang.ClassCastException:
at test.impl.MapContainerImpl.setStrStrMap(MapContainerImpl.jav a:101)
at driver.Driver.main(Driver.java:19)
=========== END system.out ========================================
Re: BasicEMap not an InternalEObject? [message #415785 is a reply to message #415783] |
Sun, 06 January 2008 23:48 |
Ed Merks Messages: 33142 Registered: July 2009 |
Bernsten,
No, a basic EMap is a collection, not an EObject. The value returned
(EObject.eGet()) for a many-valued features
(EStructuralFeature.isMany()) cannot be cast to EObject. I have no
idea what kind of model could a resulted in the API you are showing.
Could you share the model that gives rise to such a thing?
> a nice shortcut).
> Cheers,
> /\/ikolaj
> package test;
> * @author berntsen
> * @model
> * @return
> reference.
> * @generated
> package driver;
> public static void main(String[] args) {
> null
Ed Merks
Re: BasicEMap not an InternalEObject? [message #415805 is a reply to message #415785] |
Mon, 07 January 2008 22:19 |
Dear Ed,
Ed Merks wrote:
> Bernsten,
Berntsen, or just /\/ikolaj ;)
Hm. never thought of that, but I would have assumed the E- was for
EObject, nevermind.
Basically, I just like to be able to annotate stuff with key-value pairs
when modelling. Nothing really deep. Guess it could be Lists og
Entry-like things instead. An intuitive motivation could that when
using, e.g. hibernate (using the really nice teneo, for example) to
persist the model to a RDBMS with cascade fetch, it probaby yields
faster sql (I must confess, I never verified this hunch) to have the key
values in a Map (possibly Map<key, List<value>>). Even without the RDBMS
mapping, it is easier to write more optimal code (accepting the
performance hit of having read almost everything in, DOM-style), when
using Maps in the model, when the purpose of the Map/List thing is to
find something using the properties, rather than doint something to the
whole collection.
If you, with your heavy modelling experience, can tell me I am astray in
my above intuitive ideas, I would appreciate advice.
Simply the interface, MapContainer, below. That is just an example, but
I would like to be able to use EMap<k,v> in my models.
Can you point to a proper way use EMap<k,v> in an EMF model? Defined in
a java interface, and a way to contstruct the EMap by hand, if the
generated java code does not initialise the get'ter with an EMap (as
does the similar construction List<MyKVEntry<K,V>> [1]).
[1] I have not actually used List<MyKVEntry<K,V>>, rather I have
resorted to a quick and dirty List<StringStringEntry> which does indeed
come initialised with a EList in the getter.
Thanks for your time,
/\/ikolaj
>> a nice shortcut).
>> Cheers,
>> /\/ikolaj
>> package test;
>> * @author berntsen
>> * @model
>> * @return
>> <em>Str
>> containment
>> reference.
>> * @generated
>> package driver;
>> String>();
>> null
Re: BasicEMap not an InternalEObject? [message #415816 is a reply to message #415805] |
Tue, 08 January 2008 13:15 |
--------------030903050607090605010208
Nokolaj,
I have a habit of just copying the name of the sender but try to
remember to look at the signature on the bottom...
More comments below.
berntsen wrote:
> Dear Ed,
> Ed Merks wrote:
>> Bernsten,
> EObject, nevermind.
I though E for for electronic or was that Eclipse? We certainly were in
e-crazy times as the time EMF was first developed, with all the
e-business and all... And at that time, some folks has this notion,
which seems particularly misguided in hindsight that all other
metamodels (I rather dislike that word because I think a model is a
model and it's hard to argue that some particular thing makes it meta
instead) should extend Ecore and hence we should give the Ecore mode
yucky names so that other models could use the nice names. How lovely
is that?
> when modelling.
Kind of like EAnnotation and its getDetails map...
An EMap really is just a EList with the extra ability to view and treat
it like map.
It's awesome hey! We have such a good community and folks like Martin
are exemplary of that.
> , for example) to
Such a think can be directly modeled. The map entries are actually
instances of EClass and the key and value features can be any arbitrary
type of feature; and the EMap itself is just a containment list of such
entries.
> whole collection.
The value could even be another contained EObject...
It sounds okay to me. You just have to remember that an EMap is a
collection not a single EObject and that in the modeling since, it's in
fact a containment list of EObject's that implement java.util.Map.Entry.
EAnnotation.getDetails is an example.
> Defined in
Basically you need to create a multi-valued containment reference to
some EClass, and that EClass needs to have a feature called "key" and a
feature called "value" and must set the instanceClassName to
java.util.Map$Entry. That's about it. If you construct such a thing
and generated the Java, you can see how it's defined using @model
annotations.
With Java 5.0 we support things like this on the getter:
* @model
mapType="org.eclipse.emf.ecore.EStringToStringMapEntry<org.eclipse.emf.ecore.EString,
org.eclipse.emf.ecore.EString>"
To do more fancy things, like containment references or multi-valued
features, you'd need to specify such details in the XyzPackage's
accessor the EClass:
* @see java.util.Map.Entry
* @model keyDataType="org.eclipse.emf.ecore.EString"
* valueDataType="org.eclipse.emf.ecore.EString"
* @generated
EClass getEStringToStringMapEntry();
> /\/ikolaj
>>> a nice shortcut).
>>> Cheers,
>>> /\/ikolaj
>>> package test;
>>> * @author berntsen
>>> * @model
>>> * @return
>>> <em>Str
>>> containment
>>> reference.
>>> * @generated
>>> package driver;
>>> String>();
>>> null
<html>
<head>
</head>
Nokolaj,<br>
<br>
remember to look at the signature on the bottom...<br>
<br>
More comments below.<br>
<br>
<br>
berntsen wrote:
<blockquote cite="mid:4782A584.3070402@efef.dk" type="cite">
<pre wrap="">Dear Ed,
Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Bernsten,
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
<pre wrap="">No, a basic EMap is a collection, not an EObject. The value returned
</pre>
</blockquote>
EObject, nevermind.
</pre>
</blockquote>
in e-crazy times as the time EMF was first developed, with all the
is that?<br>
<pre wrap="">
</pre>
<pre wrap="">(EObject.eGet()) for a many-valued features
</pre>
</blockquote>
when modelling. </pre>
</blockquote>
Kind of like EAnnotation and its getDetails map...<br>
<pre wrap="">Nothing really deep. Guess it could be Lists og
Entry-like things instead. </pre>
</blockquote>
it like map.<br>
<pre wrap="">An intuitive motivation could that when
using, e.g. hibernate (using the really nice teneo</pre>
</blockquote>
are exemplary of that.<br>
<pre wrap="">, for example) to
values in a Map (possibly Map<key, List<value>>). </pre>
</blockquote>
entries.<br>
<pre wrap="">Even without the RDBMS
whole collection.
</pre>
</blockquote>
The value could even be another contained EObject...<br>
<pre wrap="">
</pre>
</blockquote>
fact a containment list of EObject's that implement java.util.Map.Entry.<br>
<pre wrap="">
</pre>
<pre wrap="">Could you share the model that gives rise to such a thing?
</pre>
</blockquote>
Can you point to a proper way use EMap<k,v> in an EMF model?</pre>
</blockquote>
EAnnotation.getDetails is an example.<br>
<pre wrap=""> Defined in
</pre>
</blockquote>
annotations.<br>
<pre wrap="">
</pre>
</blockquote>
With Java 5.0 we support things like this on the getter:<br>
<br>
* @model
mapType=" org.eclipse.emf.ecore.EStringToStringMapEntry<org.ecl ipse.emf.ecore.EString,
org.eclipse.emf.ecore.EString>"<br>
<br>
accessor the EClass:<br>
<br>
* @see java.util.Map.Entry<br>
* @model keyDataType="org.eclipse.emf.ecore.EString"<br>
*   ; valueDataType="org.eclipse.emf.ecore.EString"<br>
* @generated<br>
*/<br>
EClass getEStringToStringMapEntry();<br>
<br>
<pre wrap="">
/\/ikolaj
</pre>
<pre wrap="">
berntsen wrote:
</pre>
<pre wrap="">org.eclipse.emf.common.util.BasicEMap cannot be cast to
a nice shortcut).
/\/ikolaj
package test;
* @author berntsen
* @model
* @return
<em>Str
containment
reference.
* @generated
package driver;
String>();
null
</pre>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------030903050607090605010208--
Ed Merks
Current Time: Fri Apr 26 23:26:40 GMT 2024
Powered by FUDForum. Page generated in 0.03711 seconds
