Home » Modeling » EMF » Import from Annotated Java into a different project
Re: Import from Annotated Java into a different project [message #415737 is a reply to message #415729] |
Fri, 04 January 2008 16:07 |
Philipp Kutter Messages: 306 Registered: July 2009 |
Hi, Ian, hi, Ed.
I added Ian's comment to bug 210405, and I tried to change the topic of
the bug into
reload/load from Java not possible if code with model tags is in a
separate plugin
I think Ian's worflow is very realistic, especially if consultants come
into a new environment. One of my favorite scenarios with EMF would
still be to annotate legacy with EMF tags, extract the model in a
separate project, generate there the standard EMF code just to allow the
construction of test cases and MOCK objects.
For the clients I work, this would be a great progress, since it gives
them two things:
- up to date models of their (nightmare) code
- a testing scenario, which works as well if the 3 IBM hosts and 4 DB
servers are not up (which they are normally never....)
Best, Philipp
PS: Ian, you might vote for the bug...
Ed Merks wrote:
> Ian,
> This sounds similar to
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=210405 but I don't think
> that bug will cover it this type of flow. I suppose you could move the
> .genmodel and .ecore afterwards and then rely on reload working or you
> could open a feature request and hope for the best. :-P
> Ian Bull wrote:
>> Is it possible to import from Annotated Java into a different project
>> than the source is in?
>> I have some source (which was actually generated from EMF) filled with
>> all the @model tags. If I "import from annotated java" and select the
>> same project to put my .genmodel in, it works fine. However, if I
>> create a new "empty emf project" and create an EMF Model from
>> annotated java (setting this project as the place I want my genmodel
>> to be saved), I get an error:
>> "No Java source was found".
>> Is this workflow possible?
>> Cheers,
>> Ian
Re: Import from Annotated Java into a different project [message #415748 is a reply to message #415737] |
Fri, 04 January 2008 19:17 |
Ed Merks Messages: 33142 Registered: July 2009 |
Philipp,
This is trickier now since now the wizard itself has to specify two
separate things, so that will hold up completing it...
Philipp W. Kutter wrote:
> Hi, Ian, hi, Ed.
> of the bug into
> separate plugin
> come into a new environment. One of my favorite scenarios with EMF
> would still be to annotate legacy with EMF tags, extract the model in
> a separate project, generate there the standard EMF code just to allow
> the
> them two things:
> Best, Philipp
> Ed Merks wrote:
>> Ian,
>> think that bug will cover it this type of flow. I suppose you could
>> move the .genmodel and .ecore afterwards and then rely on reload
>> working or you could open a feature request and hope for the best. :-P
>>> project than the source is in?
>>> with all the @model tags. If I "import from annotated java" and
>>> select the same project to put my .genmodel in, it works fine.
>>> However, if I create a new "empty emf project" and create an EMF
>>> Model from annotated java (setting this project as the place I want
>>> my genmodel to be saved), I get an error:
>>> Cheers,
>>> Ian
Ed Merks
Re: Import from Annotated Java into a different project [message #415758 is a reply to message #415748] |
Fri, 04 January 2008 21:03 |
We don't die if it takes longer. Our aim for the moment is to generate
everything from the model.
The reload and load is only needed in large development projects, and
I try to avoid them for the moment.
As a work around, one can put the Ecore in the project of the generated
source, and reload it there. Then one can merge it in the local Ecore.
It's good enough for me to know that this is comming some time, and for
the moment I will not propose people to load from code that is in
different projects.
Best and thanks for caring about the timing,
Philipp
Ed Merks wrote:
> Philipp,
>> Hi, Ian, hi, Ed.
>> of the bug into
>> separate plugin
>> the
>> them two things:
>> Best, Philipp
>> Ed Merks wrote:
>>> Ian,
>>>> Cheers,
>>>> Ian
Current Time: Fri Apr 26 06:54:13 GMT 2024
Powered by FUDForum. Page generated in 0.03526 seconds
