No "Show grid" item in Popup [message #41981] |
Thu, 17 June 2004 02:27  |
Originally posted by: sorry.notavailable.com
Hi all,
I'm using VE under Eclipse 3.0 M8. It works fine until I try to make a panel
with Gridbaglayout/GridLayout.
The "Show grid" item was not display in the popup menu (that's what should
be shown according to the Test Scenarios) when I right-click on the JPanel.
Is there any special settings required to get it work?
My installation of VE is strictly follows the instruction of official VE, so
I hope the cause doesn't come from this...
Any idea to overcome this little but important problem?
Submarine
Re: No "Show grid" item in Popup [message #42344 is a reply to message #42105] |
Fri, 18 June 2004 12:10  |
Hi Jeff,
Oh yes, I though i've got the old version. After installation of the latest
stable version, it works now. Thanks!!
Submarine
"Jeff Myers" <myersj@nospam.us.ibm.com> wrote in message
news:carvhf$vpo$1@eclipse.org...
> Submarine,
> Are you using VE 0.5.0 or VE 1.0 M1? The GridBag support was introduced
> in M1, and was not available in 0.5. Are you switching the JPanel to
> GridBag Layout from the property sheet before looking for the Show Grid
> item on the context menu and the alignment window?
> - Jeff
> Submarine wrote:
> > Also, in Alignment settings, the tab "GridBag" isn't shown....
> > Submarine
> > "Submarine" <sorry@notavailable.com> wrote in message
> > news:card59$a7g$1@eclipse.org...
> >>Hi all,
> > panel
should
> > JPanel.
VE,
> > so
> >>Best regards,
> >>Submarine
Re: No "Show grid" item in Popup [message #591939 is a reply to message #41981] |
Thu, 17 June 2004 02:51  |
Submarine
> Hi all,
panel
JPanel.
so
> Best regards,
> Submarine
Re: No "Show grid" item in Popup [message #591985 is a reply to message #42012] |
Thu, 17 June 2004 07:33  |
Submarine,
- Jeff
> Submarine
>>Hi all,
> panel
> JPanel.
> so
>>Best regards,
>>Submarine
Re: No "Show grid" item in Popup [message #592052 is a reply to message #42105] |
Hi Jeff,
Submarine
> Submarine,
> - Jeff
> > Submarine
> >>Hi all,
> > panel
should
> > JPanel.
VE,
> > so
> >>Best regards,
> >>Submarine
FUDForum. Page generated in 0.07117 seconds
