about property sheet [message #415663] |
Wed, 26 December 2007 15:46 |
Originally posted by: littlesaisaisai.163.com
hi,all
I want to ask a question about property sheet. I want to implement such a
function:
when I select a object in the tree viewer, the properties of the object
can be showed in two sheet, some properties are still showed in the property
sheet,other properties are showed in another property-like sheet.What's
more, not all the object need two sheets to show the property. How can I
implement it?
Thank you!
Re: about property sheet [message #415665 is a reply to message #415663] |
Wed, 26 December 2007 16:46 |
Ed Merks Messages: 33146 Registered: July 2009 |
Jade,
You can populate any type of page you want in the properties view,
including something with tabs by specializing what's returned by
getPropertySheetPage in the generated editor.
Jade wrote:
> hi,all
> such a function:
> object can be showed in two sheet, some properties are still showed in
> the property sheet,other properties are showed in another
> property-like sheet.What's more, not all the object need two sheets to
> show the property. How can I implement it?
> Thank you!
Ed Merks
FUDForum. Page generated in 0.03209 seconds
