Home » Modeling » EMF » derived multi line attributes: support to view value
Re: derived multi line attributes: support to view value [message #415618 is a reply to message #415611] |
Sat, 22 December 2007 09:28 |
Philipp Kutter Messages: 306 Registered: July 2009 |
Hi, Ed.
Yes, but only if the property is not read-only. For derived features,
this dialog is not opened, and derived multi-line values can therefore
not be displayed.
Best, Philipp
Ed Merks wrote:
> Philipp,
> There is a GenFeature property to indicate that a value is mulit-line
> and hence should opened in a dialog with a small text editor.
> Philipp W. Kutter wrote:
>> Hi.
>> I've seen, that if a String attribute which is multi-line, the
>> generated editor does not allow me to open the multi-line value
>> in a window viewer, similar to the one generated for editing.
>> Ed: Could this be added as feature request?
>> Best, Philipp
Re: derived multi line attributes: support to view value [message #415624 is a reply to message #415618] |
Sat, 22 December 2007 12:37 |
Ed Merks Messages: 33142 Registered: July 2009 |
Philipp,
So you want read-only cell editors for read-only properties to act like
viewers. That's certainly possible but contributions rather than a
growing list of feature requests would sure go a long way towards
dealing with such issues.
> Hi, Ed.
> not be displayed.
> Best, Philipp
> Ed Merks wrote:
>> Philipp,
>>> Hi.
>>> Best, Philipp
Ed Merks
Re: derived multi line attributes: support to view value [message #415629 is a reply to message #415624] |
Sat, 22 December 2007 19:38 |
I somehow agree with you.
But for multi-line values, they can just not be shown as it is now.
Could it be useful to add a feature request, that read-only cells can
span multiple lines in the properties view?
You would then have multi-line for read and write. The read option could
display multi line text, and lists of values by one value per line.
Best, Philipp
Ed Merks wrote:
> Philipp,
>> Hi, Ed.
>> not be displayed.
>> Best, Philipp
>> Ed Merks wrote:
>>> Philipp,
>>>> Hi.
>>>> Best, Philipp
Re: derived multi line attributes: support to view value [message #415630 is a reply to message #415629] |
Sat, 22 December 2007 19:49 |
Philipp,
What happens now? I thought we displayed them with like "\n" in them.
The properties view isn't flexible enough to allow on property to span
multiple lines. They'd have to be multiple different (but related)
properties and that's too tricky...
> Best, Philipp
> Ed Merks wrote:
>> Philipp,
>> like viewers. That's certainly possible but contributions rather than
>> a growing list of feature requests would sure go a long way towards
>>> Hi, Ed.
>>> features, this dialog is not opened, and derived multi-line values
>>> can therefore not be displayed.
>>> Best, Philipp
>>> Ed Merks wrote:
>>>> Philipp,
>>>> mulit-line and hence should opened in a dialog with a small text
>>>> editor.
>>>>> Hi.
>>>>> Best, Philipp
Ed Merks
Re: derived multi line attributes: support to view value [message #415633 is a reply to message #415630] |
Sat, 22 December 2007 21:02 |
I understand. A pitty.
Best, Philipp
Ed Merks wrote:
> Philipp,
>> Best, Philipp
>> Ed Merks wrote:
>>> Philipp,
>>>> Hi, Ed.
>>>> Best, Philipp
>>>> Ed Merks wrote:
>>>>> Philipp,
>>>>> editor.
>>>>>> Hi.
>>>>>> Best, Philipp
Current Time: Fri Apr 26 13:08:33 GMT 2024
Powered by FUDForum. Page generated in 0.04068 seconds
