Home » Modeling » EMF » fastest way of accessing position, predecessor, successor of EMf list elements
fastest way of accessing position, predecessor, successor of EMf list elements [message #415008] |
Wed, 28 November 2007 10:58 |
Philipp Kutter Messages: 306 Registered: July 2009 |
Hi, Everybody.
I tried several ways to derive position, predecessor, and successor of
lists in earlier projects.
What is the best way doing this?
I remember starting with the EObject, finding its containing feature,
geting the EList like this, and then looking it through.
Is there a faster, easier way?
Best, Philipp
Re: fastest way of accessing position, predecessor, successor of EMf list elements [message #415018 is a reply to message #415008] |
Wed, 28 November 2007 12:34 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------050802060707060002050308
Philipp,
So you're doing something like this?
List<?> values =
(List<?>)eObject.eContainer().eGet(eObject.eContainmentFeature());
int index = values.indexOf(eObject);
And then incrementing or decrementing index and checking it abounds the
0 or value.size()?
Philipp W. Kutter wrote:
> Hi, Everybody.
> Best, Philipp
<html>
<head>
</head>
Philipp,<br>
<br>
So you're doing something like this?<br>
<blockquote>List<?> values =
(List<?>)eObject.eContainer().eGet(eObject.eCo ntainmentFeature()); <br>
int index = values.indexOf(eObject);<br>
</blockquote>
0 or value.size()?<br>
<br>
<br>
<blockquote cite="mid:fijhi2$evv$1@build.eclipse.org" type="cite">Hi,
Everybody.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Best, Philipp
<br>
</blockquote>
<br>
</body>
</html>
--------------050802060707060002050308--
Ed Merks
Re: fastest way of accessing position, predecessor, successor of EMf list elements [message #415039 is a reply to message #415018] |
Wed, 28 November 2007 14:58 |
Yes, exactly. I use OCL for it:
parent.elements->indexOf(self)
I somehow feel, this is not the optimal way...
Best, Philipp
Ed Merks wrote:
> Philipp,
> List<?> values =
> 0 or value.size()?
>> Hi, Everybody.
>> Best, Philipp
Re: fastest way of accessing position, predecessor, successor of EMf list elements [message #415040 is a reply to message #415039] |
Wed, 28 November 2007 15:06 |
Philipp,
This sounds little more like
eObject.eContainer().eContents().indexOf(eObject) but I don't know OCL...
> Best, Philipp
> Ed Merks wrote:
>> Philipp,
>> List<?> values =
>> the 0 or value.size()?
>>> Hi, Everybody.
>>> feature, geting the EList like this, and then looking it through.
>>> Best, Philipp
Ed Merks
Re: fastest way of accessing position, predecessor, successor of EMf list elements [message #415051 is a reply to message #415040] |
Wed, 28 November 2007 16:50 |
Would your version really work? Once you are at the eContainer, you
first need to select the correct many feature, and then get the indexOf.
eObject in my example is accessible as "self" and can be ommitted,
"parent" in my example is an opposite of a containment, thus it replaces
your eContainer(). Then, elements is my many-feature, of which I know I
am one of the elements in the list. The "->" is needed for all
collection operations, like indexOf(..), instead of the ".".
BUT my real question is, whether we can do it quicker. As I do it now,
it sounds very inefficient.
Best, Philipp
>> Best, Philipp
>> Ed Merks wrote:
>>> Philipp,
>>> List<?> values =
>>>> Hi, Everybody.
>>>> Best, Philipp
Re: fastest way of accessing position, predecessor, successor of EMf list elements [message #415054 is a reply to message #415051] |
Wed, 28 November 2007 16:56 |
Philipp,
Comments below.
>> OCL...
You never stated explicitly you want to get other objects only in the
same feature, but certainly this approach would let you get a contained
sibling from a different feature. I just don't know what
parent.elements does and thought it might be like eObject.eContents().
It might be more like parent.getElements().
> replaces your eContainer(). Then, elements is my many-feature, of
> which I know I am one of the elements in the list. The "->" is needed
> for all collection operations, like indexOf(..), instead of the ".".
A contained child doesn't now the index at which it's contained (and it
would be kind of costly to maintain that), so indexOf is the best way to
find that. I can't think of a faster way...
> Best, Philipp
>>> Best, Philipp
>>> Ed Merks wrote:
>>>> Philipp,
>>>> List<?> values =
>>>>> Hi, Everybody.
>>>>> successor of
>>>>> Best, Philipp
Ed Merks
Re: fastest way of accessing position, predecessor, successor of EMf list elements [message #415076 is a reply to message #415054] |
Wed, 28 November 2007 21:23 |
>>> OCL...
No no, my version runs perfectly. In Ocl you use "elements", not the
getter. At least Christian Damus did so in his examples.
By the way, the eContainer(), e.t.c. stuff is only available in OCL, if
you are explicitly inheriting from EObject in your models.
Ok, thanks.
Best, Philipp
>> Best, Philipp
>>>> Best, Philipp
>>>> Ed Merks wrote:
>>>>> Philipp,
>>>>> List<?> values =
>>>>>> Hi, Everybody.
>>>>>> successor of
>>>>>> Best, Philipp
Current Time: Fri Apr 26 07:57:09 GMT 2024
Powered by FUDForum. Page generated in 0.02900 seconds
