Home » Modeling » EMF » SDO Java - EDataGraph - serialize-transmit (RMI/IIOP)-deserialize then access via *static* SDO API?
SDO Java - EDataGraph - serialize-transmit (RMI/IIOP)-deserialize then access via *static* SDO API? [message #414988] |
Tue, 27 November 2007 15:14 |
Originally posted by: GaryRMartin.insightbb.com
By design (with any version of SDO and Tuscany Java implementation),
should it be possible to generate "static" SDO classes from an .xsd, and
then:
a) use the generated classes to create an:
org.eclipse.emf.ecore.sdo.EDataGraph
b)call a method on the remote interface of an ejb that takes that
EDataGraph as its only arguement
c)use the *static* generated SDO classes to access the SDOs in the
EDataGraph
I've done a) and b) and can use the dynamic SDO API in my EJB method,
but, I've yet to figure out how (or even if it should be possible by
design) to use the generated "static" SDO classes in my EJB method.
Re: SDO Java - EDataGraph - serialize-transmit (RMI/IIOP)-deserialize then access via *static* SDO [message #414989 is a reply to message #414988] |
Tue, 27 November 2007 15:35 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------060405040609080503050101
Gary,
Yes, that is possible:
Tutorial: Using the SDO Data Graph Editor
< http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.ecore.sdo.doc/tutorials/datagraph/datagraph.html>
> then:
> EDataGraph
<html>
<head>
</head>
Gary,<br>
<br>
Yes, that is possible:<br>
<blockquote><a
href=" http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.ecore.sdo.doc/tutorials/datagraph/datagraph.html">Tutorial:
Using the SDO Data Graph Editor</a><br>
</blockquote>
<br>
Gary Martin wrote:
<blockquote cite="mid:fihc9v$c1p$1@build.eclipse.org" type="cite">
<pre wrap="">By design (with any version of SDO and Tuscany Java implementation),
then:
EDataGraph
</pre>
</blockquote>
<br>
</body>
</html>
--------------060405040609080503050101--
Ed Merks
Re: SDO Java - EDataGraph - serialize-transmit (RMI/IIOP)-followup ? [message #414993 is a reply to message #414989] |
Tue, 27 November 2007 18:03 |
------=_NextPart_000_002A_01C830F5.D76154A0
charset="iso-8859-1"
Ed,
Thank you. I'm not connecting the dots. Are you suggesting that the =
source code of
the SDO Data Graph Editor itself illustrates c) in my problem statement?
Here's a snippet of code from the method in my EJB where I'm able to use =
the dynamic
API, but unable to use the static API.
import com.ibm.ItemType;
import com.ibm.PurchaseOrderType;
import com.ibm.DocumentRoot;
import com.ibm.util.IbmResourceFactoryImpl;
import com.ibm.util.IbmResourceUtil;
import commonj.sdo.DataObject;
import commonj.sdo.Property;
import org.eclipse.emf.ecore.impl.EReferenceImpl;
import org.eclipse.emf.ecore.sdo.EDataGraph;
import org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl;
// method defined on the remote interface=20
public void acceptEDataGraph (EDataGraph eDG) {
DataObject rootObject =3D eDG.getRootObject(); // works
DataObject purchaseOrder =3D =
rootObject.getDataObject("purchaseOrder"); // works
java.util.Date orderDate =3D purchaseOrder.getDate("orderDate"); // =
works
System.out.println("orderDate: " + orderDate); // works=20
// This doesn't work=20
DocumentRoot documentRoot =3D (DocumentRoot)eDG.getERootObject(); =20
PurchaseOrderType aPOT =3D documentRoot.getPurchaseOrder(); // what =
I'm referring to as the "static" SDO API
// I get this exception=20
java.rmi.ServerException: RemoteException occurred in server thread; =
nested exception is:=20
java.rmi.RemoteException:=20
>> SERVER (id=3D4773e3aa, host=3DIBM-0CA191A407D) TRACE START:
>> java.rmi.RemoteException: ; nested exception is:=20
java.lang.ClassCastException: =
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl incompatible with =
>> at =
sdo.exchanger.SDOExchangerBean.acceptEDataGraph(SDOExchanger Bean.java:89)=
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fihdh6$jpc$1@build.eclipse.org...
Gary,
Gary Martin wrote:=20
then:
EDataGraph
design) to use the generated "static" SDO classes in my EJB method.=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3199" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Thank you. I'm =
not connecting the=20
dots. Are you suggesting that the source code =
of</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>the SDO Data Graph Editor itself =
illustrates c) in=20
my problem statement?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Here's a snippet of code from the =
method in my EJB=20
where I'm able to use the dynamic</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>API, but unable to use the static =
API.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>import com.ibm.ItemType;<BR>import=20
com.ibm.PurchaseOrderType;<BR>import com.ibm.DocumentRoot;<BR>import=20
com.ibm.util.IbmResourceFactoryImpl;<BR>import=20
com.ibm.util.IbmResourceUtil;</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>import =
commonj.sdo.DataObject;<BR>import=20
commonj.sdo.Property;</FONT></DIV>
<DIV> </DIV><FONT face=3DArial size=3D2>
<DIV><BR>import org.eclipse.emf.ecore.impl.EReferenceImpl;<BR>import=20
org.eclipse.emf.ecore.sdo.EDataGraph;<BR>import=20
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl;</DIV >
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>// method defined on the remote interface <BR>public void =
acceptEDataGraph=20
(EDataGraph eDG) {</DIV>
<DIV> </DIV>
<DIV><BR> DataObject rootObject =3D eDG.getRootObject(); //=20
works<BR> DataObject purchaseOrder =3D=20
rootObject.getDataObject("purchaseOrder"); // works</DIV>
<DIV> </DIV>
<DIV> java.util.Date orderDate =3D =
purchaseOrder.getDate("orderDate");=20
// works<BR> System.out.println("orderDate: " + orderDate); =
// works=20
</DIV>
<DIV> </DIV>
<DIV><BR> // This doesn't work <BR> DocumentRoot=20
documentRoot =3D=20
(DocumentRoot)eDG.getERootObject(); <BR> PurchaseOr=
derType=20
aPOT =3D documentRoot.getPurchaseOrder(); // what I'm referring to as =
the "static"=20
SDO API</DIV>
<DIV> </DIV>
<DIV>// I get this exception <BR>java.rmi.ServerException: =
RemoteException=20
occurred in server thread; nested exception is:=20
<BR> java.rmi.RemoteException: <BR> >> SERVER =
(id=3D4773e3aa,=20
host=3DIBM-0CA191A407D) TRACE START:<BR> >> =
<BR> java.lang.ClassCastException:=20
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl incompatible with=20
com.ibm.DocumentRoot<BR> >> at=20
</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fihdh6$jpc$1@build.eclipse.org">news:fihdh6$jpc$1@build.ecli=
pse.org</A>...</DIV>Gary,<BR><BR>Yes,=20
that is possible:<BR>
<BLOCKQUOTE><A=20
href=3D" http://help.eclipse.org/help33/index.jsp?topic=3D/org.eclips e.emf=
..ecore.sdo.doc/tutorials/datagraph/datagraph.html">Tutorial:=20
Using the SDO Data Graph Editor</A><BR></BLOCKQUOTE><BR>Gary Martin =
wrote:=20
<BLOCKQUOTE cite=3Dmid:fihc9v$c1p$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">By design (with any version of SDO and =
then:
EDataGraph
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></FONT></DIV>
<BLOCKQUOTE=20
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: =
0px"> </BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_002A_01C830F5.D76154A0--
Re: SDO Java - EDataGraph - serialize-transmit (RMI/IIOP)-followup ? [message #414994 is a reply to message #414993] |
Tue, 27 November 2007 18:18 |
--------------090008040604030603000903
Gary,
Comments below.
Gary Martin wrote:
> Ed,
> source code of
No, I'm suggesting that the tutorial shows you the steps you need to
generate the static code for your SDO model and then the datagraph
editor shows your model being used to read and write instances or your
model using your generated code.
> use the dynamic
It looks like you've already generated the code so that makes me a bit
confused about why you asked how to generate the the code.
> DataObject rootObject = eDG.getRootObject(); // works
> java.util.Date orderDate = purchaseOrder.getDate("orderDate"); // works
> DocumentRoot documentRoot = (DocumentRoot)eDG.getERootObject();
> PurchaseOrderType aPOT = documentRoot.getPurchaseOrder(); // what
> >> SERVER (id=4773e3aa, host=IBM-0CA191A407D) TRACE START:
> with com.ibm.DocumentRoot
> >> at
Oh, I see. Maybe all that's missing is the code to ensure that your
generated package is registered with the static registry. At some point
during the initialization of the server you should access the
XyzPackage.eINSTANCE to ensure that the package is registered.
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:fihdh6$jpc$1@build.eclipse.org...
> Gary,
> < http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf..ecore.sdo.doc/tutorials/datagraph/datagraph.html>
>> then:
>> EDataGraph
<html>
<head>
</head>
Gary,<br>
<br>
Comments below.<br>
<br>
Gary Martin wrote:
<blockquote cite="mid:fihm57$brk$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.3199" name="GENERATOR">
<style></style>
<div><font face="Arial" size="2">
<div><font face="Arial" size="2">Ed,</font></div>
<div> </div>
<div><font face="Arial" size="2">Thank you. I'm not connecting the
dots. Are you suggesting that the source code of</font></div>
<div><font face="Arial" size="2">the SDO Data Graph Editor itself
illustrates c) in my problem statement?</font></div>
</font></div>
</blockquote>
model using your generated code.<br>
<div> </div>
<div><font face="Arial" size="2">Here's a snippet of code from the
method in my EJB where I'm able to use the dynamic</font></div>
<div><font face="Arial" size="2">API, but unable to use the static
API.</font></div>
<div> </div>
<div><font face="Arial" size="2">import com.ibm.ItemType;<br>
import com.ibm.PurchaseOrderType;<br>
import com.ibm.DocumentRoot;<br>
</font></div>
</font></div>
</blockquote>
confused about why you asked how to generate the the code.<br>
com.ibm.util.IbmResourceFactoryImpl;<br>
import com.ibm.util.IbmResourceUtil;</font></div>
<div> </div>
<div><font face="Arial" size="2">import commonj.sdo.DataObject;<br>
import commonj.sdo.Property;</font></div>
<div> </div>
<font face="Arial" size="2"></font>
<div><font face="Arial" size="2"><br>
import org.eclipse.emf.ecore.impl.EReferenceImpl;<br>
import org.eclipse.emf.ecore.sdo.EDataGraph;<br>
import org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl;</font ></div>
<div><font face="Arial" size="2"> </font></div>
<div><font face="Arial" size="2">// method defined on the remote
interface <br>
public void acceptEDataGraph (EDataGraph eDG) {</font></div>
DataObject rootObject = eDG.getRootObject(); // works<br>
DataObject purchaseOrder = rootObject.getDataObject("purchaseOrder");
// works</font></div>
<div><font face="Arial" size="2"> java.util.Date orderDate =
purchaseOrder.getDate("orderDate"); // works<br>
System.out.println("orderDate: " + orderDate); // works </font></div>
// This doesn't work <br>
DocumentRoot documentRoot = (DocumentRoot)eDG.getERootObject(); <br>
PurchaseOrderType aPOT = documentRoot.getPurchaseOrder(); // what I'm
referring to as the "static" SDO API</font></div>
<div><font face="Arial" size="2">// I get this exception <br>
nested exception is: <br>
java.rmi.RemoteException: <br>
>> SERVER (id=4773e3aa, host=IBM-0CA191A407D) TRACE START:<br>
>> java.rmi.RemoteException: ; nested exception is: <br>
com.ibm.DocumentRoot<br>
>> at
sdo.exchanger.SDOExchangerBean.acceptEDataGraph(SDOExchanger Bean.java:89) </font></div>
</font></div>
</blockquote>
XyzPackage.eINSTANCE to ensure that the package is registered.<br>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;">
<div>"Ed Merks" <<a moz-do-not-send="true"
href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>> wrote in
message <a moz-do-not-send="true"
href="news:fihdh6$jpc$1@build.eclipse.org">news:fihdh6$jpc$1@build.eclipse.org</a>...</div>
Gary,<br>
<br>
<blockquote><a moz-do-not-send="true"
href=" http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf..ecore.sdo.doc/tutorials/datagraph/datagraph.html">Tutorial:
</blockquote>
<br>
then:
EDataGraph
</pre>
</blockquote>
<br>
</blockquote>
</font></div>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;"> </blockquote>
</blockquote>
<br>
</body>
</html>
--------------090008040604030603000903--
Ed Merks
Re: SDO Java -serialization/deserialization of EDataGraph - deliberate replacement of each EDataObj [message #415190 is a reply to message #414994] |
Tue, 04 December 2007 16:39 |
------=_NextPart_000_0019_01C8366A.535EBC90
Upon further investigation:
Note: I'm using whatever implementation of SDO 1.0 spec IBM included in
WebSphere App Server v6.1.0.11 - =
...\plugins\org.eclipse.emf.ecore.sdo_2.2.0.v200609210005.ja r
In a previous append - Tuesday, November 27, 2007 1:03 PM Eastern - I =
included a snippet of source code from a=20
method - acceptEDataGraph(EDataGraph) defined by a Stateless Session EJB =
and on the EJB's remote interface.
Based on your append - Tuesday, November 27, 2007 1:18 PM Eastern - I =
added:
IbmPackage anIbmPackage =3D IbmPackageImpl.init();
as the 1st statement in that method (This didn't appear to change the =
behavior about which I comment below.)
Snippet from EJB client (with comments on which I ask your feedback):
// create org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl and populate =
root Object and contained objects using
// generated IBMFactoryImpl and "static" SDOs (inherit from =
EDataObjectImpl
Object anObject =3D ((EDataGraphImpl) eDG).getWriteReplacement(); // =
org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl$EDataGraphExte rnalizable
// just =
curious what Object was returned
aSDOExchanger.acceptEDataGraph(eDG); // defined on remote interface of =
// eDG's ERootObject was set earlier to instance of: =
com.ibm.impl.DocumentRootImpl (generated "static" SDO - inherits from =
EDataObjectImpl)
// DocumentRootImpl.setPurchaseOrder was set to instance of =
com.ibm.impl.PurchaseOrderTypeImpl (generated "static" SDO)
=20
// When accessed (after serialization / deserialization) in EJB, =
EDataGraph's rootObject is a: =
// When accessed in EJB, DocumentRootImpl.getPurchaseOrder is instance =
of: org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl
=20
// I've concluded that this "replacement" (during serialization / =
deserialization) of instances of generated "static" SDOs
// (that inherit from EDataObjectImpl)
// with instances of DynamicEDataObjectImpl has to be a conscious design =
choice - not a bug.
// As a result, I can't use the generated "static" SDOs in the =
implementation of method acceptEDataGraph(EDataGraph)
Ed:
a) Do you agree / disagree with that conclusion?
b) Do you know if this behavior is different (by design) in newer =
Tuscany implementations of SDO 1.0 or 2.0?
news:fihn1g$e1e$1@build.eclipse.org...
Gary,
Comments below.
Ed,
Thank you. I'm not connecting the dots. Are you suggesting that =
the source code of
the SDO Data Graph Editor itself illustrates c) in my problem =
statement?
No, I'm suggesting that the tutorial shows you the steps you need to =
generate the static code for your SDO model and then the datagraph =
editor shows your model being used to read and write instances or your =
Here's a snippet of code from the method in my EJB where I'm able to =
use the dynamic
It looks like you've already generated the code so that makes me a bit =
java.util.Date orderDate =3D purchaseOrder.getDate("orderDate"); =
// works
PurchaseOrderType aPOT =3D documentRoot.getPurchaseOrder(); // =
what I'm referring to as the "static" SDO API
>> at =
Oh, I see. Maybe all that's missing is the code to ensure that your =
generated package is registered with the static registry. At some point =
during the initialization of the server you should access the =
Gary,
then:
EDataGraph
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3199" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2>Upon further =
investigation:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Note: I'm using whatever implementation =
of SDO 1.0=20
spec IBM included in<BR>WebSphere App Server v6.1.0.11 -=20
...\plugins\org.eclipse.emf.ecore.sdo_2.2.0.v200609210005.ja r </FONT></DIV>=
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>In a previous append - Tuesday, =
November 27, 2007=20
1:03 PM Eastern - I included a snippet of source code from a <BR>method =
-=20
acceptEDataGraph(EDataGraph) defined by a Stateless Session EJB and on =
the EJB's=20
remote interface.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Based on your append - Tuesday, =
1:18 PM Eastern - I added:<BR>IbmPackage anIbmPackage =3D=20
IbmPackageImpl.init();<BR>as the 1st statement in that method =
(This didn't=20
appear to change the behavior about which I comment below.)</FONT></DIV>
<DIV><BR>Snippet from EJB client (with comments on which I ask your=20
feedback):</DIV>
<DIV> </DIV>
<DIV>// create org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl and =
populate root=20
Object and contained objects using<BR>// generated IBMFactoryImpl and =
"static"=20
SDOs (inherit from EDataObjectImpl</DIV>
<DIV> </DIV>
<DIV>...</DIV>
<DIV> </DIV>
<DIV>Object anObject =3D ((EDataGraphImpl) eDG).getWriteReplacement(); =
//=20
org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl$EDataGraphExte rnalizable <BR=
nbsp; & nbsp; & n=
bsp; &n bsp; &n b=
sp; &nb sp; &nb s=
p; =20
// just curious what Object was returned</DIV>
<DIV> </DIV>
<DIV>aSDOExchanger.acceptEDataGraph(eDG); // defined on remote interface =
of=20
Stateless Session EJB</DIV>
<DIV> </DIV>
<DIV>// eDG's ERootObject was set earlier to instance of:=20
com.ibm.impl.DocumentRootImpl (generated "static" SDO - inherits from=20
EDataObjectImpl)<BR>// DocumentRootImpl.setPurchaseOrder was set to =
instance of=20
com.ibm.impl.PurchaseOrderTypeImpl (generated "static"=20
SDO)<BR> <BR>// When accessed (after serialization /=20
deserialization) in EJB, EDataGraph's rootObject is a:=20
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl<BR>// When =
accessed in=20
EJB, DocumentRootImpl.getPurchaseOrder is instance of:=20
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl<BR> &nbs=
p;<BR>//=20
deserialization)=20
of instances of generated "static" SDOs<BR>// (that inherit from=20
EDataObjectImpl)<BR>// with instances of DynamicEDataObjectImpl has to =
be a=20
conscious design choice - not a bug.<BR>// As a result, I can't use the=20
generated "static" SDOs in the implementation of method=20
acceptEDataGraph(EDataGraph)</DIV>
<DIV> </DIV>
<DIV>Ed:</DIV>
<DIV> </DIV>
<DIV>a) Do you agree / disagree with that conclusion?<BR>b) Do you know =
if this=20
behavior is different (by design) in newer Tuscany implementations of =
SDO 1.0 or=20
2.0?</FONT></DIV>
<BLOCKQUOTE=20
href=3D"news:fihn1g$e1e$1@build.eclipse.org">news:fihn1g$e1e$1@build.ecli=
pse.org</A>...</DIV>Gary,<BR><BR>Comments=20
below.<BR><BR>Gary Martin wrote:=20
<BLOCKQUOTE cite=3Dmid:fihm57$brk$1@build.eclipse.org type=3D"cite">
<STYLE></STYLE>
<DIV> </DIV>
of</FONT></DIV>
illustrates c)=20
in my problem statement?</FONT></DIV></FONT></DIV></BLOCKQUOTE>No, =
I'm=20
suggesting that the tutorial shows you the steps you need to generate =
the=20
static code for your SDO model and then the datagraph editor shows =
your model=20
being used to read and write instances or your model using your =
generated=20
code.<BR>
<DIV> </DIV>
method in my=20
EJB where I'm able to use the dynamic</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>API, but unable to use the static=20
API.</FONT></DIV>
<DIV> </DIV>
com.ibm.PurchaseOrderType;<BR>import=20
com.ibm.DocumentRoot;<BR></FONT></DIV></FONT></DIV></BLOCKQUOTE >It =
looks like=20
you've already generated the code so that makes me a bit confused =
about why=20
you asked how to generate the the code.<BR>
<DIV><FONT face=3DArial size=3D2>import=20
<DIV> </DIV>
<DIV> </DIV><FONT face=3DArial size=3D2></FONT>
<DIV><FONT face=3DArial size=3D2><BR>import=20
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl;</FONT ></DIV>
<DIV><FONT face=3DArial size=3D2>// method defined on the remote =
interface=20
<BR>public void acceptEDataGraph (EDataGraph eDG) =
{</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><BR> DataObject =
rootObject =3D=20
eDG.getRootObject(); // works<BR> DataObject =
rootObject.getDataObject("purchaseOrder"); // works</FONT></DIV>
<DIV><FONT face=3DArial size=3D2> java.util.Date =
orderDate =3D=20
purchaseOrder.getDate("orderDate"); //=20
// works=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><BR> // This doesn't =
work=20
<BR> DocumentRoot documentRoot =3D=20
derType=20
aPOT =3D documentRoot.getPurchaseOrder(); // what I'm referring to =
as the=20
"static" SDO API</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>// I get this exception=20
<BR>java.rmi.ServerException: RemoteException occurred in server =
thread;=20
nested exception is: <BR> java.rmi.RemoteException: =
<BR> >>=20
SERVER (id=3D4773e3aa, host=3DIBM-0CA191A407D) TRACE=20
START:<BR> >> java.rmi.RemoteException: =
;=20
nested exception is: <BR> java.lang.ClassCastException:=20
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl incompatible =
with=20
</FONT></DIV></FONT></DIV></BLOCKQUOTE>Oh,=20
I see. Maybe all that's missing is the code to ensure that your=20
generated package is registered with the static registry. At some =
point during=20
XyzPackage.eINSTANCE to=20
ensure that the package is registered.<BR>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Ed Merks" <<A href=3D"mailto:merks@ca.ibm.com"=20
moz-do-not-send=3D"true">merks@ca.ibm.com</A>> wrote in message =
<A=20
href=3D"news:fihdh6$jpc$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:fihdh6$jpc$1@build.eclipse.org</A>...</DIV>=
<BLOCKQUOTE><A=20
...ecore.sdo.doc/tutorials/datagraph/datagraph.html"=20
moz-do-not-send=3D"true">Tutorial: Using the SDO Data Graph=20
Editor</A><BR></BLOCKQUOTE><BR>Gary Martin wrote:=20
then:
EDataGraph
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: =
0px"> </BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE ></BODY></HTML>
------=_NextPart_000_0019_01C8366A.535EBC90--
Re: SDO Java -serialization/deserialization of EDataGraph - deliberate replacement of each EDataObj [message #415191 is a reply to message #415190] |
Tue, 04 December 2007 17:07 |
--------------080900060404060408060703
Gary,
Comments below.
> EJB and on the EJB's remote interface.
> added:
> IbmPackage anIbmPackage = IbmPackageImpl.init();
IbmPackage.eINSTANCE would be the preferred way.
IbmPackage.eINSTANCE.eClass() is the idiom we typically use if we only
want to force initialize but don't really need the package.
Is this done on both the client and the server?
> EDataObjectImpl
> Object anObject = ((EDataGraphImpl) eDG).getWriteReplacement(); //
You might want to try code like this (which we have in our JUnit tests):
eDataGraph.getDataGraphResource().save(System.out, null);
ByteArrayOutputStream outputStream = new ByteArrayOutputStream();
ObjectOutputStream objectOutputStream = new
ObjectOutputStream(outputStream);
objectOutputStream.writeObject(eDataGraph);
objectOutputStream.close();
InputStream inputStream = new
ByteArrayInputStream(outputStream.toByteArray());
ObjectInputStream objectInputStream = new
ObjectInputStream(inputStream);
EDataGraph otherEDataGraph = (EDataGraph)objectInputStream.readObject();
otherEDataGraph.getDataGraphResource().save(System.out, null);
This should help demonstrate that the datagraph is properly serializable
and can be recovered from the serialization. Try this on the client.
If the server were configured the same way, it should be able to
deserialize the result.
> EDataObjectImpl)
No, it really depends on what type of models you have registered and
whether you are transmitting the model from the client to the server or
just assuming the server knows the model already.
> Ed:
No. If you can get serialization and deserialization to work locally on
the client end, set a breakpoint in the constructor for your generated
DocumentRoot and see how the code gets there. Similarly, set a
breakpoint in the DynamicEDataObject constructor and look at how the
code path that gets you there is different in that case...
I think Tuscany started out with EMF's SDO implementation, so I imagine
the issues will be very similar or the same.
> message news:fihn1g$e1e$1@build.eclipse.org...
> Gary,
> Comments below.
> Gary Martin wrote:
>> Ed,
>> statement?
> to generate the static code for your SDO model and then the
> datagraph editor shows your model being used to read and write
> instances or your model using your generated code.
>> to use the dynamic
> bit confused about why you asked how to generate the the code.
>> // works
>> incompatible with com.ibm.DocumentRoot
>> >> at
> your generated package is registered with the static registry. At
> some point during the initialization of the server you should
> access the XyzPackage.eINSTANCE to ensure that the package is
> registered.
>> in message news:fihdh6$jpc$1@build.eclipse.org...
>> Gary,
>> < http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf...ecore.sdo.doc/tutorials/datagraph/datagraph.html>
>>> then:
>>> EDataGraph
<html>
<head>
</head>
Gary,<br>
<br>
Comments below.<br>
<br>
Gary Martin wrote:
<blockquote cite="mid:fj3vsh$82p$1@build.eclipse.org" type="cite">
<div><font face="Arial" size="2">Upon further investigation:</font></div>
<div> </div>
<div><font face="Arial" size="2">Note: I'm using whatever
implementation of SDO 1.0 spec IBM included in<br>
....\plugins\org.eclipse.emf.ecore.sdo_2.2.0.v200609210005.j ar </font></div>
<div> </div>
<div><font face="Arial" size="2">In a previous append - Tuesday,
November 27, 2007 1:03 PM Eastern - I included a snippet of source code
from a <br>
EJB and on the EJB's remote interface.</font></div>
<div> </div>
<div><font face="Arial" size="2">Based on your append - Tuesday,
November 27, 2007 1:18 PM Eastern - I added:<br>
IbmPackage anIbmPackage = IbmPackageImpl.init();<br>
</font></div>
</blockquote>
want to force initialize but don't really need the package.<br>
<div><font face="Arial" size="2">as the 1st statement in that method
(This didn't appear to change the behavior about which I comment below.)</font></div>
</blockquote>
Is this done on both the client and the server?<br>
<div> </div>
Snippet from EJB client (with comments on which I ask your feedback):</font></div>
<div><font face="Arial" size="2">// create
org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl and populate root Object
and contained objects using<br>
EDataObjectImpl</font></div>
<div><font face="Arial" size="2">...</font></div>
<div><font face="Arial" size="2">Object anObject = ((EDataGraphImpl)
org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl$EDataGraphExte rnalizable <br>
// just
curious what Object was returned</font></div>
<div><font face="Arial" size="2">aSDOExchanger.acceptEDataGraph(eDG);
// defined on remote interface of Stateless Session EJB</font></div>
</blockquote>
You might want to try code like this (which we have in our JUnit tests):<br>
<br>
<small> eDataGraph.getDataGraphResource().save(System.out, null);<br>
ByteArrayOutputStream outputStream = new ByteArrayOutputStream();<br>
ObjectOutputStream(outputStream);<br>
objectOutputStream.writeObject(eDataGraph);<br>
objectOutputStream.close();<br>
ByteArrayInputStream(outputStream.toByteArray());<br>
ObjectInputStream(inputStream);<br>
(EDataGraph)objectInputStream.readObject();<br>
otherEDataGraph.getDataGraphResource().save(System.out, null);<br>
</small><br>
serializable and can be recovered from the serialization. Try this on
the client. If the server were configured the same way, it should be
able to deserialize the result.<br>
<div><font face="Arial" size="2">// eDG's ERootObject was set earlier
to instance of: com.ibm.impl.DocumentRootImpl (generated "static" SDO -
inherits from EDataObjectImpl)<br>
com.ibm.impl.PurchaseOrderTypeImpl (generated "static" SDO)<br>
<br>
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl<br>
of: org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl<br>
<br>
deserialization) of instances of generated "static" SDOs<br>
// (that inherit from EDataObjectImpl)<br>
design choice - not a bug.<br>
</font></div>
</blockquote>
just assuming the server knows the model already.<br>
<div><font face="Arial" size="2">// As a result, I can't use the
acceptEDataGraph(EDataGraph)</font></div>
<div><font face="Arial" size="2">Ed:</font></div>
<div><font face="Arial" size="2">a) Do you agree / disagree with that
conclusion?<br>
</font></div>
</blockquote>
on the client end, set a breakpoint in the constructor for your
generated DocumentRoot and see how the code gets there. Similarly, set
a breakpoint in the DynamicEDataObject constructor and look at how the
code path that gets you there is different in that case...<br>
<div><font face="Arial" size="2">b) Do you know if this behavior is
different (by design) in newer Tuscany implementations of SDO 1.0 or
2.0?</font></div>
</blockquote>
the issues will be very similar or the same.<br>
<blockquote
href="news:fihn1g$e1e$1@build.eclipse.org">news:fihn1g$e1e$1@build.eclipse.org</a>...</div>
Gary,<br>
<br>
Comments below.<br>
<br>
<style></style>
<div> </div>
the dots. Are you suggesting that the source code of</font></div>
</font></div>
</blockquote>
<div> </div>
the method in my EJB where I'm able to use the dynamic</font></div>
static API.</font></div>
<div> </div>
</font></div>
</font></div>
</blockquote>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
interface <br>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
>> at
</font></div>
</blockquote>
<blockquote
<div>"Ed Merks" <<a href="mailto:merks@ca.ibm.com"
moz-do-not-send="true">merks@ca.ibm.com</a>> wrote in message <a
href="news:fihdh6$jpc$1@build.eclipse.org" moz-do-not-send="true">news:fihdh6$jpc$1@build.eclipse.org</a>...</div>
Gary,<br>
<br>
<blockquote><a
href=" http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf...ecore.sdo.doc/tutorials/datagraph/datagraph.html"
moz-do-not-send="true">Tutorial: Using the SDO Data Graph Editor</a><br>
</blockquote>
<br>
type="cite">
then:
EDataGraph
</pre>
</blockquote>
<br>
</blockquote>
</font></div>
<blockquote
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------080900060404060408060703--
Ed Merks
Re: SDO Java -serialization/deserialization of EDataGraph *on client* - deliberate replacement of e [message #415193 is a reply to message #415191] |
Tue, 04 December 2007 20:29 |
------=_NextPart_000_004C_01C8368A.894F9520
Ed,
Thanks yet again.
I ran this code on my *client* (please note my comments //):
IbmPackage purchaseOrderPackage =3D IbmPackageImpl.eINSTANCE;
ResourceSet resourceSet =3D eDG.getResourceSet();
Resource packageResource =3D =
resourceSet.createResource(URI.createURI(purchaseOrderPackag e.getNsURI())=
packageResource.getContents().add(purchaseOrderPackage);
resourceSet.getPackageRegistry().put(purchaseOrderPackage.ge tNsURI(), =
System.out.println("eDG.getDataGraphResource().save(System.out, null); =
before serialization ****************************************");
System.out.println("eDG.getERootObject: " + eDG.getERootObject());
// eDG.getERootObject: com.ibm.impl.DocumentRootImpl@52565256 (mixed: =
[ibm:purchaseOrder=3Dcom.ibm.impl.PurchaseOrderTypeImpl@7a987a98 =
(comment: Overnight shipping, orderDate: 2007-03-10)])
ByteArrayOutputStream outputStream =3D new ByteArrayOutputStream();
ObjectOutputStream objectOutputStream =3D new =
objectOutputStream.writeObject(eDG);
InputStream inputStream =3D new =
ObjectInputStream objectInputStream =3D new =
EDataGraph otherEDataGraph =3D =
System.out.println("otherEDataGraph.getDataGraphResource().save(System.ou=
t, null); after deserialization =
System.out.println("otherEDataGraph.getERootObject: " + =
otherEDataGraph.getERootObject());
// otherEDataGraph.getERootObject: =
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl@3ae63ae6 (eClass: =
org.eclipse.emf.ecore.impl.EClassImpl@42f242f2 (name: DocumentRoot) =
(instanceClassName: null) (abstract: false, interface: false))
So..somehow I need to "fix" the problem (EDataObjectImpl(s) replaced =
with DynamicEDataObjectImpl(s) during serialization / deserialization) =
** on my client **.
I saved the System.out output if it might be useful?
news:fj41hq$s5v$1@build.eclipse.org...
Gary,
Comments below.
Note: I'm using whatever implementation of SDO 1.0 spec IBM included =
in
In a previous append - Tuesday, November 27, 2007 1:03 PM Eastern - =
I included a snippet of source code from a=20
method - acceptEDataGraph(EDataGraph) defined by a Stateless Session =
Based on your append - Tuesday, November 27, 2007 1:18 PM Eastern - =
I added:
IbmPackage.eINSTANCE would be the preferred way. =
IbmPackage.eINSTANCE.eClass() is the idiom we typically use if we only =
as the 1st statement in that method (This didn't appear to change =
Snippet from EJB client (with comments on which I ask your =
feedback):
EDataObjectImpl
You might want to try code like this (which we have in our JUnit =
tests):
ByteArrayOutputStream outputStream =3D new =
This should help demonstrate that the datagraph is properly =
serializable and can be recovered from the serialization. Try this on =
the client. If the server were configured the same way, it should be =
EDataObjectImpl)
=20
// When accessed in EJB, DocumentRootImpl.getPurchaseOrder is =
instance of: org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl
=20
// with instances of DynamicEDataObjectImpl has to be a conscious =
No, it really depends on what type of models you have registered and =
whether you are transmitting the model from the client to the server or =
Ed:
No. If you can get serialization and deserialization to work locally =
on the client end, set a breakpoint in the constructor for your =
generated DocumentRoot and see how the code gets there. Similarly, set =
a breakpoint in the DynamicEDataObject constructor and look at how the =
I think Tuscany started out with EMF's SDO implementation, so I =
imagine the issues will be very similar or the same.
Gary,
Comments below.
Ed,
Thank you. I'm not connecting the dots. Are you suggesting =
statement?
No, I'm suggesting that the tutorial shows you the steps you need =
to generate the static code for your SDO model and then the datagraph =
Here's a snippet of code from the method in my EJB where I'm =
It looks like you've already generated the code so that makes me a =
DocumentRoot documentRoot =3D =
>> at =
Oh, I see. Maybe all that's missing is the code to ensure that =
your generated package is registered with the static registry. At some =
point during the initialization of the server you should access the =
Gary,
then:
EDataGraph
=20
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>Thanks yet again.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I ran this code on my *client* (please =
note my=20
comments //):</FONT></DIV>
<DIV><FONT size=3D2>
<P align=3Dleft>IbmPackage purchaseOrderPackage =3D =
IbmPackageImpl.</FONT><I><FONT=20
color=3D#0000c0 size=3D2>eINSTANCE</I></FONT><FONT size=3D2>;</P>
<P align=3Dleft>ResourceSet resourceSet =3D eDG.getResourceSet();</P>
<P align=3Dleft>Resource packageResource =3D=20
resourceSet.createResource(URI.<I>createURI</I>(purchaseOrderPackage.getN=
sURI()));</P>
<P =
align=3Dleft>packageResource.getContents().add(purchaseOrderPackage); </P>=
<P> resourceSet.getPackageRegistry().put(purchaseOrderPackage.ge tNsURI(), =
purchaseOrderPackage);</P></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><STRONG>...</STRONG></FONT></DIV>
<DIV><FONT size=3D2><FONT size=3D2>
<P align=3Dleft>System.</FONT><I><FONT color=3D#0000c0 =
size=3D2>out</I></FONT><FONT=20
size=3D2>.println(</FONT><FONT color=3D#2a00ff=20
size=3D2>"eDG.getDataGraphResource().save(System.out, null); before =
serialization=20
****************************************"</FONT><FONT size=3D2>);</P>
size=3D2>.println(</FONT><FONT color=3D#2a00ff =
size=3D2>"eDG.getERootObject:=20
"</FONT><FONT size=3D2> + eDG.getERootObject());</FONT></P>
<P align=3Dleft>// <FONT size=3D2>eDG.getERootObject:=20
<STRONG>com.ibm.impl.DocumentRootImpl</STRONG>@52565256 (mixed:=20
(comment:=20
Overnight shipping, </FONT><U><FONT color=3D#000080=20
size=3D2>orderDate</U></FONT><FONT size=3D2>: 2007-03-10)])</P>
<P align=3Dleft></FONT><FONT=20
size=3D2>eDG.getDataGraphResource().save(System.</FONT><I ><FONT =
color=3D#0000c0=20
size=3D2>out</I></FONT><FONT size=3D2>, </FONT><B><FONT color=3D#7f0055=20
size=3D2>null</B></FONT><FONT size=3D2>);</FONT></P>
<P align=3Dleft><FONT size=3D2>ByteArrayOutputStream outputStream =3D =
</FONT><B><FONT=20
color=3D#7f0055 size=3D2>new</B></FONT><FONT size=3D2> =
ByteArrayOutputStream();</P>
<P align=3Dleft>ObjectOutputStream objectOutputStream =3D =
</FONT><B><FONT=20
color=3D#7f0055 size=3D2>new</B></FONT><FONT size=3D2>=20
ObjectOutputStream(outputStream);</P>
<P align=3Dleft>objectOutputStream.writeObject(eDG);</P>
<P align=3Dleft>objectOutputStream.close();</P>
<P align=3Dleft>InputStream inputStream =3D </FONT><B><FONT =
color=3D#7f0055=20
ByteArrayInputStream(outputStream.toByteArray());</P>
<P align=3Dleft>ObjectInputStream objectInputStream =3D </FONT><B><FONT=20
ObjectInputStream(inputStream);</P>
<P align=3Dleft>EDataGraph otherEDataGraph =3D=20
(EDataGraph)objectInputStream.readObject();</P>
size=3D2>"otherEDataGraph.getDataGraphResource().save(System.out, null); =
after=20
deserialization ***************************************"</FONT><FONT=20
size=3D2>);</P>
size=3D2>"otherEDataGraph.getERootObject: "</FONT><FONT size=3D2> +=20
otherEDataGraph.getERootObject());</FONT></P>
<P align=3Dleft><FONT size=3D2>// <FONT =
size=3D2>otherEDataGraph.getERootObject:=20
<STRONG>org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl </STRONG>@3a=
e63ae6=20
(eClass: org.eclipse.emf.ecore.impl.EClassImpl@42f242f2 (name: =
DocumentRoot)=20
(instanceClassName: null) (abstract: false, </FONT><U><FONT =
color=3D#000080=20
size=3D2>interface</U></FONT><FONT size=3D2>: false))</P></FONT><FONT =
size=3D2></FONT>
<P>otherEDataGraph.getDataGraphResource().save(System.</FONT ><I><FONT=20
color=3D#0000c0 size=3D2>out</I></FONT><FONT size=3D2>, </FONT><B><FONT =
color=3D#7f0055=20
<P><FONT face=3DArial size=3D2>So..somehow I need to "fix" the problem=20
(EDataObjectImpl(s) replaced with DynamicEDataObjectImpl(s) during =
serialization=20
/ deserialization) ** on my client **.</FONT></P>
<P><FONT face=3DArial>I saved the System.out output if it might be=20
useful?</FONT></P>
<P><FONT size=3D2><FONT =
face=3DArial></FONT> </P></FONT></FONT></DIV>
<DIV><FONT size=3D2></FONT> </DIV>
<DIV><BR></DIV>
<BLOCKQUOTE=20
href=3D"news:fj41hq$s5v$1@build.eclipse.org">news:fj41hq$s5v$1@build.ecli=
<BLOCKQUOTE cite=3Dmid:fj3vsh$82p$1@build.eclipse.org type=3D"cite">
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Note: I'm using whatever =
implementation of SDO=20
1.0 spec IBM included in<BR>WebSphere App Server v6.1.0.11 -=20
....\plugins\org.eclipse.emf.ecore.sdo_2.2.0.v200609210005.j ar </FONT></DIV=
<DIV> </DIV>
November 27,=20
2007 1:03 PM Eastern - I included a snippet of source code from a =
<BR>method=20
and on the=20
EJB's remote interface.</FONT></DIV>
<DIV> </DIV>
November 27,=20
2007 1:18 PM Eastern - I added:<BR>IbmPackage anIbmPackage =3D=20
IbmPackageImpl.init();<BR></FONT></DIV></BLOCKQUOTE>IbmPackage.eINSTANCE =
would=20
be the preferred way. IbmPackage.eINSTANCE.eClass() is the idiom =
we=20
typically use if we only want to force initialize but don't really =
need the=20
package.<BR>
<DIV><FONT face=3DArial size=3D2>as the 1st statement in that =
method (This=20
didn't appear to change the behavior about which I comment=20
below.)</FONT></DIV></BLOCKQUOTE>Is this done on both the client and =
the=20
server?<BR>
<DIV><FONT face=3DArial size=3D2><BR>Snippet from EJB client (with =
comments on=20
which I ask your feedback):</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>// create=20
org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl and populate root =
Object and=20
contained objects using<BR>// generated IBMFactoryImpl and "static" =
SDOs=20
(inherit from EDataObjectImpl</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Object anObject =3D =
((EDataGraphImpl)=20
eDG).getWriteReplacement(); //=20
nbsp; & nbsp; & n=
bsp; &n bsp; &n b=
sp; &nb sp; &nb s=
p; =20
// just curious what Object was returned</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2>aSDOExchanger.acceptEDataGraph(eDG); // defined=20
on remote interface of Stateless Session =
EJB</FONT></DIV></BLOCKQUOTE>You=20
might want to try code like this (which we have in our JUnit=20
tests):<BR><BR><SMALL> =20
eDataGraph.getDataGraphResource().save(System.out,=20
null);<BR> ByteArrayOutputStream outputStream =3D =
new=20
ByteArrayOutputStream();<BR> ObjectOutputStream=20
objectOutputStream =3D new=20
ObjectOutputStream(outputStream);<BR> =20
objectOutputStream.writeObject(eDataGraph);<BR> =20
objectOutputStream.close();<BR> InputStream =
inputStream =3D=20
new =
ByteArrayInputStream(outputStream.toByteArray());<BR> =20
ObjectInputStream objectInputStream =3D new=20
ObjectInputStream(inputStream);<BR> EDataGraph=20
(EDataGraph)objectInputStream.readObject();<BR> =20
otherEDataGraph.getDataGraphResource().save(System.out,=20
null);<BR></SMALL><BR>This should help demonstrate that the datagraph =
is=20
properly serializable and can be recovered from the =
serialization. Try=20
this on the client. If the server were configured the same way, =
it=20
should be able to deserialize the result.<BR>
<DIV><FONT face=3DArial size=3D2>// eDG's ERootObject was set =
earlier to=20
instance of: com.ibm.impl.DocumentRootImpl (generated "static" SDO - =
inherits from EDataObjectImpl)<BR>// =
DocumentRootImpl.setPurchaseOrder was=20
set to instance of com.ibm.impl.PurchaseOrderTypeImpl (generated =
"static"=20
SDO)<BR> <BR>// When accessed (after serialization =
/=20
accessed in=20
p;<BR>//=20
I've concluded that this "replacement" (during serialization /=20
deserialization) of instances of generated "static" SDOs<BR>// (that =
inherit=20
from EDataObjectImpl)<BR>// with instances of DynamicEDataObjectImpl =
has to=20
be a conscious design choice - not a =
bug.<BR></FONT></DIV></BLOCKQUOTE>No, it=20
really depends on what type of models you have registered and whether =
you are=20
transmitting the model from the client to the server or just assuming =
the=20
server knows the model already.<BR>
<DIV><FONT face=3DArial size=3D2>// As a result, I can't use the =
generated=20
acceptEDataGraph(EDataGraph)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Ed:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>a) Do you agree / disagree with =
that=20
conclusion?<BR></FONT></DIV></BLOCKQUOTE>No. If you can get=20
serialization and deserialization to work locally on the client end, =
set a=20
breakpoint in the constructor for your generated DocumentRoot and see =
how the=20
code gets there. Similarly, set a breakpoint in the =
DynamicEDataObject=20
constructor and look at how the code path that gets you there is =
different in=20
that case...<BR>
<DIV><FONT face=3DArial size=3D2>b) Do you know if this behavior is =
different=20
(by design) in newer Tuscany implementations of SDO 1.0 or=20
2.0?</FONT></DIV></BLOCKQUOTE>I think Tuscany started out with EMF's =
SDO=20
implementation, so I imagine the issues will be very similar or the =
same.<BR>
<BLOCKQUOTE=20
<A=20
href=3D"news:fihn1g$e1e$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:fihn1g$e1e$1@build.eclipse.org</A>...</DIV>=
<BLOCKQUOTE cite=3Dmid:fihm57$brk$1@build.eclipse.org =
type=3D"cite">
<STYLE></STYLE>
<DIV> </DIV>
not connecting=20
the dots. Are you suggesting that the source code=20
of</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>the SDO Data Graph Editor =
itself=20
illustrates c) in my problem=20
statement?</FONT></DIV></FONT></DIV></BLOCKQUOTE>No, I'm =
suggesting that=20
the tutorial shows you the steps you need to generate the static =
code for=20
your SDO model and then the datagraph editor shows your model =
being used=20
to read and write instances or your model using your generated =
code.<BR>
type=3D"cite">
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Here's a snippet of code from =
the method in=20
my EJB where I'm able to use the dynamic</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>API, but unable to use the =
static=20
API.</FONT></DIV>
<DIV> </DIV>
com.ibm.DocumentRoot;<BR></FONT></DIV></FONT></DIV></BLOCKQUOTE >It looks =
confused=20
about why you asked how to generate the the code.<BR>
type=3D"cite">
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
interface=20
{</FONT></DIV>
<DIV> </DIV>
rootObject =3D=20
<DIV> </DIV>
orderDate =3D=20
works<BR> System.out.println("orderDate: " + =
orderDate); //=20
works </FONT></DIV>
<DIV> </DIV>
work=20
derType=20
aPOT =3D documentRoot.getPurchaseOrder(); // what I'm referring =
to as the=20
<DIV> </DIV>
thread;=20
nested exception is: <BR> java.rmi.RemoteException:=20
<BR> >> SERVER (id=3D4773e3aa, =
START:<BR> >> =
java.rmi.RemoteException: ;=20
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl =
your=20
point=20
during the initialization of the server you should access the=20
XyzPackage.eINSTANCE to ensure that the package is registered.<BR>
type=3D"cite">
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: =
5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
moz-do-not-send=3D"true">merks@ca.ibm.com</A>> wrote in =
message <A=20
<BLOCKQUOTE><A=20
....ecore.sdo.doc/tutorials/datagraph/datagraph.html"=20
then:
EDataGraph
<BLOCKQUOTE=20
5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: =
0px"> </BLOCKQUOTE></BLOCKQUOTE><BR></BLOCKQUOTE ></BLOCKQUOTE><BR></=
------=_NextPart_000_004C_01C8368A.894F9520--
Re: SDO Java -serialization/deserialization of EDataGraph *on client* - deliberate replacement of e [message #415195 is a reply to message #415193] |
Tue, 04 December 2007 22:40 |
--------------000603090604090501050508
Gary,
Comments below.
Gary Martin wrote:
> Ed,
> Thanks yet again.
> IbmPackage purchaseOrderPackage = IbmPackageImpl./eINSTANCE/;
> ResourceSet resourceSet = eDG.getResourceSet();
> resourceSet.createResource(URI./createURI/(purchaseOrderPack age.getNsURI()));
So you are registering this package locally and sending it with your
data graph. That why the receiver will always use the dynamic package
that you sent it and told it do use. Can you omit this entirely? You
shouldn't need it and it's the cause of the problem.
> System./out/.println("eDG.getDataGraphResource().save(System.out,
> null); before serialization ****************************************");
> System./out/.println("eDG.getERootObject: " + eDG.getERootObject());
> // eDG.getERootObject: *com.ibm.impl.DocumentRootImpl*@52565256
> (mixed: [ibm:purchaseOrder=com.ibm.impl.PurchaseOrderTypeImpl@7a987a98
> (comment: Overnight shipping, _orderDate_: 2007-03-10)])
> eDG.getDataGraphResource().save(System./out/, *null*);
> ByteArrayOutputStream outputStream = *new* ByteArrayOutputStream();
> ObjectOutputStream objectOutputStream = *new*
> InputStream inputStream = *new*
> ObjectInputStream objectInputStream = *new*
> System./out/.println("otherEDataGraph.getDataGraphResource().save(System.out,
> null); after deserialization ***************************************");
> System./out/.println("otherEDataGraph.getERootObject: " +
> *org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl*@3ae6 3ae6
> DocumentRoot) (instanceClassName: null) (abstract: false, _interface_:
> false))
> otherEDataGraph.getDataGraphResource().save(System./out/, *null*);
> ** on my client **.
> message news:fj41hq$s5v$1@build.eclipse.org...
> Gary,
> Comments below.
>> included in
>> Session EJB and on the EJB's remote interface.
>> - I added:
> only want to force initialize but don't really need the package.
>> populate root Object and contained objects using
>> EDataObjectImpl
> tests):
> it should be able to deserialize the result.
> and whether you are transmitting the model from the client to the
> server or just assuming the server knows the model already.
>> Ed:
> locally on the client end, set a breakpoint in the constructor for
> your generated DocumentRoot and see how the code gets there.
> Similarly, set a breakpoint in the DynamicEDataObject constructor
> and look at how the code path that gets you there is different in
> that case...
>> in message news:fihn1g$e1e$1@build.eclipse.org...
>> Gary,
>> Comments below.
>> Gary Martin wrote:
>>> Ed,
>>> problem statement?
>> need to generate the static code for your SDO model and then
>> the datagraph editor shows your model being used to read and
>> write instances or your model using your generated code.
>> me a bit confused about why you asked how to generate the the
>> code.
>>> // what I'm referring to as the "static" SDO API
>>> >> at
>> that your generated package is registered with the static
>> registry. At some point during the initialization of the
>> server you should access the XyzPackage.eINSTANCE to ensure
>>> wrote in message news:fihdh6$jpc$1@build.eclipse.org...
>>> Gary,
>>> < http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf....ecore.sdo.doc/tutorials/datagraph/datagraph.html>
>>>> then:
>>>> EDataGraph
<html>
<head>
</head>
Gary,<br>
<br>
Comments below.<br>
<br>
Gary Martin wrote:
<blockquote cite="mid:fj4dcs$pb1$1@build.eclipse.org" type="cite">
<div> </div>
<div><font face="Arial" size="2">Thanks yet again.</font></div>
<div> </div>
<div><font face="Arial" size="2">I ran this code on my *client*
(please note my comments //):</font></div>
<div> </div>
<div><font size="2">
</font>
<p align="left"><font size="2">IbmPackage purchaseOrderPackage =
IbmPackageImpl.</font><i><font color="#0000c0" size="2">eINSTANCE</font></i><font
size="2">;</font></p>
<p align="left"><font size="2">ResourceSet resourceSet =
eDG.getResourceSet();</font></p>
<p align="left"><font size="2">Resource packageResource =
resourceSet.createResource(URI.<i>createURI</i>(purchaseOrderPackage.getNsURI())); </font></p>
<p align="left"><font size="2">packageResource.getContents().add(purchaseOrderPackage); </font></p>
<p><font size="2"> resourceSet.getPackageRegistry().put(purchaseOrderPackage.ge tNsURI(),
purchaseOrderPackage);</font></p>
</div>
</blockquote>
shouldn't need it and it's the cause of the problem.<br>
<div><font face="Arial" size="2"><strong>...</strong></font></div>
<div><font size="2"><font size="2">
</font>
<p align="left"><font size="2">System.</font><i><font color="#0000c0"
size="2">out</font></i><font color="#0000c0" size="2"><font size="2">.println(</font><font
color="#2a00ff" size="2">"eDG.getDataGraphResource().save(System.out,
null); before serialization ****************************************"</font><font
size="2">);</font></font></p>
<p align="left"><font color="#0000c0" size="2"><font size="2">System.</font><i><font
color="#0000c0" size="2">out</font></i><font size="2">.println(</font><font
color="#2a00ff" size="2">"eDG.getERootObject: "</font><font size="2">
+ eDG.getERootObject());</font></font></p>
<p align="left"><font color="#0000c0" size="2">// <font size="2">eDG.getERootObject:
<strong>com.ibm.impl.DocumentRootImpl</strong>@52565256 (mixed:
(comment: Overnight shipping, </font><u><font color="#000080" size="2">orderDate</font></u><font
size="2">: 2007-03-10)])</font></font></p>
<p align="left"><font color="#0000c0" size="2"><font size="2"><font
size="2">eDG.getDataGraphResource().save(System.</font><i ><font
color="#0000c0" size="2">out</font></i><font size="2">, </font><b><font
color="#7f0055" size="2">null</font></b><font size="2">);</font></font></font></p>
size="2">ByteArrayOutputStream outputStream = </font><b><font
color="#7f0055" size="2">new</font></b><font size="2">
ByteArrayOutputStream();</font></font></font></p>
size="2">ObjectOutputStream objectOutputStream = </font><b><font
ObjectOutputStream(outputStream);</font></font></font></p >
size="2">objectOutputStream.writeObject(eDG);</font></font ></font></p>
size="2">objectOutputStream.close();</font></font></font ></p>
size="2">InputStream inputStream = </font><b><font color="#7f0055"
ByteArrayInputStream(outputStream.toByteArray());</font></font ></font></p>
size="2">ObjectInputStream objectInputStream = </font><b><font
ObjectInputStream(inputStream);</font></font></font></p>
size="2">EDataGraph otherEDataGraph =
(EDataGraph)objectInputStream.readObject();</font></font></font ></p>
size="2">System.</font><i><font color="#0000c0" size="2">out</font></i><font
size="2">.println(</font><font color="#2a00ff" size="2">"otherEDataGraph.getDataGraphResource().save(System.out,
null); after deserialization ***************************************"</font><font
size="2">.println(</font><font color="#2a00ff" size="2">"otherEDataGraph.getERootObject:
"</font><font size="2"> + otherEDataGraph.getERootObject());</font></font></font></p >
size="2">// <font size="2">otherEDataGraph.getERootObject: <strong>org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl </strong>@3ae63ae6
DocumentRoot) (instanceClassName: null) (abstract: false, </font><u><font
color="#000080" size="2">interface</font></u><font size="2">: false))</font></font></font></font></p>
<font color="#0000c0" size="2"><font size="2"><font size="2"></font></font></font>
<p><font color="#0000c0" size="2"><font size="2"><font size="2">otherEDataGraph.getDataGraphResource().save(System. </font><i><font
<p><font color="#0000c0" size="2"><font size="2"><font face="Arial"
size="2">So..somehow I need to "fix" the problem (EDataObjectImpl(s)
replaced with DynamicEDataObjectImpl(s) during serialization /
deserialization) ** on my client **.</font></font></font></p>
<p><font color="#0000c0" size="2"><font size="2"><font face="Arial">I
saved the System.out output if it might be useful?</font></font></font></p>
<p><font color="#0000c0" size="2"><font size="2"><font size="2"> </font></font></font></p>
</font></div>
<div><font size="2"><font color="#0000c0" size="2"> </font></font></div>
<div><font size="2"><font color="#0000c0" size="2"><br>
<blockquote
<div><font color="#0000c0" size="2">"Ed Merks" <<a
moz-do-not-send="true" href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>>
wrote in message <a moz-do-not-send="true"
href="news:fj41hq$s5v$1@build.eclipse.org">news:fj41hq$s5v$1@build.eclipse.org</a>...</font></div>
<font color="#0000c0" size="2">Gary,<br>
<br>
Comments below.<br>
<br>
Gary Martin wrote: </font>
<blockquote cite="mid:fj3vsh$82p$1@build.eclipse.org" type="cite"><font
</font>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">Upon
further investigation:</font></font></div>
<div><font color="#0000c0" size="2"> </font></div>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">Note:
I'm using whatever implementation of SDO 1.0 spec IBM included in<br>
.....\plugins\org.eclipse.emf.ecore.sdo_2.2.0.v200609210005. jar </font></font></div>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">In
included a snippet of source code from a <br>
EJB and on the EJB's remote interface.</font></font></div>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">Based
on your append - Tuesday, November 27, 2007 1:18 PM Eastern - I added:<br>
</blockquote>
<font color="#0000c0" size="2">IbmPackage.eINSTANCE would be the
preferred way. IbmPackage.eINSTANCE.eClass() is the idiom we typically
use if we only want to force initialize but don't really need the
package.<br>
</font>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">as
behavior about which I comment below.)</font></font></div>
</blockquote>
<font color="#0000c0" size="2">Is this done on both the client and
the server?<br>
</font>
<div><font color="#0000c0" size="2"><font face="Arial" size="2"><br>
Snippet from EJB client (with comments on which I ask your feedback):</font></font></div>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">//
create org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl and populate root
Object and contained objects using<br>
EDataObjectImpl</font></font></div>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">...</font></font></div>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">Object
// just
curious what Object was returned</font></font></div>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">aSDOExchanger.acceptEDataGraph(eDG);
// defined on remote interface of Stateless Session EJB</font></font></div>
</blockquote>
<font color="#0000c0" size="2">You might want to try code like this
<br>
</small><br>
</font>
<br>
<br>
</blockquote>
<font color="#0000c0" size="2">No, it really depends on what type
of models you have registered and whether you are transmitting the
model from the client to the server or just assuming the server knows
</font>
implementation of method acceptEDataGraph(EDataGraph)</font></font></div>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">Ed:</font></font></div>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">a)
Do you agree / disagree with that conclusion?<br>
</blockquote>
<font color="#0000c0" size="2">No. If you can get serialization
and deserialization to work locally on the client end, set a breakpoint
in the constructor for your generated DocumentRoot and see how the code
gets there. Similarly, set a breakpoint in the DynamicEDataObject
</font>
<div><font color="#0000c0" size="2"><font face="Arial" size="2">b)
Do you know if this behavior is different (by design) in newer Tuscany
implementations of SDO 1.0 or 2.0?</font></font></div>
</blockquote>
<font color="#0000c0" size="2">I think Tuscany started out with
EMF's SDO implementation, so I imagine the issues will be very similar
or the same.<br>
</font>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;"><font
href="mailto:merks@ca.ibm.com" moz-do-not-send="true">merks@ca.ibm.com</a>>
wrote in message <a href="news:fihn1g$e1e$1@build.eclipse.org"
moz-do-not-send="true">news:fihn1g$e1e$1@build.eclipse.org</a>...</font></div>
<br>
Comments below.<br>
<br>
type="cite"><font color="#0000c0" size="2">
<style></style> </font>
size="2">
<div> </div>
not connecting the dots. Are you suggesting that the source code of</font></div>
itself illustrates c) in my problem statement?</font></div>
</blockquote>
<font color="#0000c0" size="2">No, I'm suggesting that the
tutorial shows you the steps you need to generate the static code for
your SDO model and then the datagraph editor shows your model being
used to read and write instances or your model using your generated
code.<br>
</font>
type="cite"><font color="#0000c0" size="2"> </font>
size="2">
<div> </div>
from the method in my EJB where I'm able to use the dynamic</font></div>
<div> </div>
</font></div>
</blockquote>
<font color="#0000c0" size="2">It looks like you've already
generated the code so that makes me a bit confused about why you asked
</font>
size="2">
<div> </div>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
remote interface <br>
<div> </div>
<div> </div>
<div> </div>
<div> </div>
>> at
</blockquote>
<font color="#0000c0" size="2">Oh, I see. Maybe all that's
missing is the code to ensure that your generated package is registered
with the static registry. At some point during the initialization of
the server you should access the XyzPackage.eINSTANCE to ensure that
</font>
size="2">
<blockquote
Gary,<br>
<br>
<blockquote><a
href=" http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf....ecore.sdo.doc/tutorials/datagraph/datagraph.html"
</blockquote>
<br>
type="cite">
should it be possible to generate "static" SDO classes from an .xsd, and
then:
a) use the generated classes to create an:
b)call a method on the remote interface of an ejb that takes that
EDataGraph as its only arguement
c)use the *static* generated SDO classes to access the SDOs in the
EDataGraph
I've done a) and b) and can use the dynamic SDO API in my EJB method,
but, I've yet to figure out how (or even if it should be possible by
</pre>
</blockquote>
<br>
</blockquote>
<blockquote
color="#0000c0" size="2"> </font></blockquote>
</blockquote>
</blockquote>
</font></font></blockquote>
</blockquote>
<br>
</body>
</html>
--------------000603090604090501050508--
Ed Merks
Re: SDO Java -serialization/deserialization of EDataGraph - use Static SDO API after deserializatio [message #415210 is a reply to message #415195] |
Wed, 05 December 2007 14:09 |
Originally posted by: GaryRMartin.insightbb.com
------=_NextPart_000_005E_01C8371E.9A4970F0
Content-Type: text/plain;
Ed,
Success! Thanks again for all your help.
For those following this thread, what finally worked was:
Snippet from client:
// packageResource.getContents().add(purchaseOrderPackage); =20
// resourceSet.getPackageRegistry().put(purchaseOrderPackage.ge tNsURI(), =
purchaseOrderPackage);=20
=20
// ************************************************** eye catcher ******
// news://news.eclipse.org/eclipse.tools.emf - Tuesday, December 04, =
2007 5:40 PM Eastern
// So you are registering this package locally and sending it with your =
data graph.
// That why the receiver will always use the dynamic package that you =
// Can you omit this entirely? You shouldn't need it and it's the cause =
of the problem.
// ************************************************** eye catcher ****** =
news:fj4l1s$ttp$1@build.eclipse.org...
Gary,
Comments below.
Ed,
Thanks yet again.
data graph. That why the receiver will always use the dynamic package =
that you sent it and told it do use. Can you omit this entirely? You =
System.out.println("eDG.getDataGraphResource().save(System.out, =
// eDG.getERootObject: com.ibm.impl.DocumentRootImpl@52565256 =
(mixed: [ibm:purchaseOrder=3Dcom.ibm.impl.PurchaseOrderTypeImpl@7a987a98 =
** on my client **.
Gary,
Comments below.
Note: I'm using whatever implementation of SDO 1.0 spec IBM =
included in
In a previous append - Tuesday, November 27, 2007 1:03 PM =
Eastern - I included a snippet of source code from a=20
method - acceptEDataGraph(EDataGraph) defined by a Stateless =
Based on your append - Tuesday, November 27, 2007 1:18 PM =
Eastern - I added:
as the 1st statement in that method (This didn't appear to =
feedback):
EDataObjectImpl
Object anObject =3D ((EDataGraphImpl) =
aSDOExchanger.acceptEDataGraph(eDG); // defined on remote =
tests):
EDataObjectImpl)
=20
=20
// I've concluded that this "replacement" (during serialization =
/ deserialization) of instances of generated "static" SDOs
// with instances of DynamicEDataObjectImpl has to be a =
No, it really depends on what type of models you have registered =
and whether you are transmitting the model from the client to the server =
Ed:
No. If you can get serialization and deserialization to work =
locally on the client end, set a breakpoint in the constructor for your =
b) Do you know if this behavior is different (by design) in =
newer Tuscany implementations of SDO 1.0 or 2.0?
Gary,
Comments below.
Ed,
Thank you. I'm not connecting the dots. Are you =
the SDO Data Graph Editor itself illustrates c) in my =
problem statement?
No, I'm suggesting that the tutorial shows you the steps you =
need to generate the static code for your SDO model and then the =
datagraph editor shows your model being used to read and write instances =
API, but unable to use the static API.
It looks like you've already generated the code so that makes =
me a bit confused about why you asked how to generate the the code.
import com.ibm.util.IbmResourceFactoryImpl;
import =
// method defined on the remote interface=20
DataObject rootObject =3D eDG.getRootObject(); // works
DataObject purchaseOrder =3D =
System.out.println("orderDate: " + orderDate); // works=20
// This doesn't work=20
(DocumentRoot)eDG.getERootObject(); =20
PurchaseOrderType aPOT =3D =
documentRoot.getPurchaseOrder(); // what I'm referring to as the =
"static" SDO API
>> SERVER (id=3D4773e3aa, host=3DIBM-0CA191A407D) TRACE =
START:
>> java.rmi.RemoteException: ; nested exception is:=20
java.lang.ClassCastException: =
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl incompatible with =
>> at =
sdo.exchanger.SDOExchangerBean.acceptEDataGraph(SDOExchanger Bean.java:89)=
Oh, I see. Maybe all that's missing is the code to ensure =
that your generated package is registered with the static registry. At =
some point during the initialization of the server you should access the =
"Ed Merks" <merks@ca.ibm.com> wrote in message =
Gary,
Yes, that is possible:
By design (with any version of SDO and Tuscany Java implementation),
then:
EDataGraph
design) to use the generated "static" SDO classes in my EJB method.=20
=20
Content-Type: text/html;
charset="iso-8859-1"
<HTML><HEAD>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Success! Thanks again for all =
your=20
help.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>For those following this thread, what =
finally=20
worked was:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Snippet from client:</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>IbmPackage purchaseOrderPackage =3D=20
IbmPackageImpl.eINSTANCE;<BR>ResourceSet resourceSet =3D=20
eDG.getResourceSet();<BR>Resource packageResource =3D=20
);<BR>//=20
packageResource.getContents().add(purchaseOrderPackage);& ;nbsp; <BR>/=
/=20
resourceSet.getPackageRegistry().put(purchaseOrderPackage.ge tNsURI(),=20
purchaseOrderPackage); <BR> <BR>//=20
************************************************** eye catcher =
******<BR>// <A=20
href=3D"news://news.eclipse.org/eclipse.tools.emf">news://news.eclipse.or=
g/eclipse.tools.emf</A>=20
- Tuesday, December 04, 2007 5:40 PM Eastern<BR>// So you are =
registering this=20
package locally and sending it with your data graph.<BR>// That why the =
receiver=20
will always use the dynamic package that you sent it and told it do =
use.<BR>//=20
Can you omit this entirely? You shouldn't need it and it's the =
cause of=20
the problem.<BR>// ************************************************** =
eye=20
catcher ****** <BR></FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fj4l1s$ttp$1@build.eclipse.org">news:fj4l1s$ttp$1@build.ecli=
<BLOCKQUOTE cite=3Dmid:fj4dcs$pb1$1@build.eclipse.org type=3D"cite">
<DIV> </DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>I ran this code on my *client* =
(please note my=20
<DIV> </DIV>
<P align=3Dleft><FONT size=3D2>IbmPackage purchaseOrderPackage =3D=20
IbmPackageImpl.</FONT><I><FONT color=3D#0000c0=20
size=3D2>eINSTANCE</FONT></I><FONT size=3D2>;</FONT></P>
<P align=3Dleft><FONT size=3D2>ResourceSet resourceSet =3D=20
eDG.getResourceSet();</FONT></P>
<P align=3Dleft><FONT size=3D2>Resource packageResource =3D=20
sURI()));</FONT></P>
<P align=3Dleft><FONT=20
size=3D2>packageResource.getContents().add(purchaseOrderPackage); </FONT><=
/P>
<P><FONT=20
size=3D2> resourceSet.getPackageRegistry().put(purchaseOrderPackage.ge tNsU=
RI(),=20
purchaseOrderPackage);</FONT></P></DIV></BLOCKQUOTE>So you are =
registering=20
this package locally and sending it with your data graph. That =
why the=20
receiver will always use the dynamic package that you sent it and told =
it do=20
use. Can you omit this entirely? You shouldn't need it and =
it's=20
the cause of the problem.<BR>
<DIV><FONT size=3D2><FONT size=3D2></FONT>
<P align=3Dleft><FONT size=3D2>System.</FONT><I><FONT =
color=3D#0000c0=20
size=3D2>out</FONT></I><FONT color=3D#0000c0 size=3D2><FONT=20
size=3D2>"eDG.getDataGraphResource().save(System.out, null); before=20
serialization ****************************************"</FONT><FONT=20
size=3D2>);</FONT></FONT></P>
<P align=3Dleft><FONT color=3D#0000c0 size=3D2><FONT =
size=3D2>System.</FONT><I><FONT=20
color=3D#0000c0 size=3D2>out</FONT></I><FONT =
size=3D2>.println(</FONT><FONT=20
color=3D#2a00ff size=3D2>"eDG.getERootObject: "</FONT><FONT =
size=3D2> +=20
eDG.getERootObject());</FONT></FONT></P>
<P align=3Dleft><FONT color=3D#0000c0 size=3D2>// <FONT =
(comment:=20
size=3D2>orderDate</FONT></U><FONT size=3D2>: =
2007-03-10)])</FONT></FONT></P>
<P align=3Dleft><FONT color=3D#0000c0 size=3D2><FONT size=3D2><FONT=20
color=3D#0000c0=20
size=3D2>out</FONT></I><FONT size=3D2>, </FONT><B><FONT =
color=3D#7f0055=20
size=3D2>null</FONT></B><FONT size=3D2>);</FONT></FONT></FONT></P>
size=3D2>ByteArrayOutputStream outputStream =3D </FONT><B><FONT =
color=3D#7f0055=20
size=3D2>new</FONT></B><FONT size=3D2>=20
ByteArrayOutputStream();</FONT></FONT></FONT></P>
size=3D2>ObjectOutputStream objectOutputStream =3D </FONT><B><FONT =
color=3D#7f0055=20
ObjectOutputStream(outputStream);</FONT></FONT></FONT></P >
size=3D2>objectOutputStream.writeObject(eDG);</FONT></FONT ></FONT></P>
size=3D2>objectOutputStream.close();</FONT></FONT></FONT ></P>
size=3D2>InputStream inputStream =3D </FONT><B><FONT color=3D#7f0055 =
ByteArrayInputStream(outputStream.toByteArray());</FONT></FONT ></FONT></P=
size=3D2>ObjectInputStream objectInputStream =3D </FONT><B><FONT =
color=3D#7f0055=20
ObjectInputStream(inputStream);</FONT></FONT></FONT></P>
size=3D2>EDataGraph otherEDataGraph =3D=20
(EDataGraph)objectInputStream.readObject();</FONT></FONT></FONT ></P>
size=3D2>System.</FONT><I><FONT color=3D#0000c0 =
size=3D2>out</FONT></I><FONT=20
size=3D2>"otherEDataGraph.getDataGraphResource().save(System.out, =
null); after=20
deserialization ***************************************"</FONT><FONT =
otherEDataGraph.getERootObject());</FONT></FONT></FONT></P >
<P align=3Dleft><FONT color=3D#0000c0 size=3D2><FONT size=3D2><FONT =
size=3D2>// <FONT=20
e63ae6=20
DocumentRoot)=20
color=3D#000080=20
size=3D2>interface</FONT></U><FONT size=3D2>:=20
false))</FONT></FONT></FONT></FONT></P><FONT color=3D#0000c0 =
size=3D2><FONT=20
size=3D2><FONT size=3D2></FONT></FONT></FONT>
<P><FONT color=3D#0000c0 size=3D2><FONT size=3D2><FONT=20
size=3D2>otherEDataGraph.getDataGraphResource().save(System. </FONT><I><FO=
NT=20
color=3D#0000c0 size=3D2>out</FONT></I><FONT size=3D2>, =
</FONT><B><FONT=20
color=3D#7f0055 size=3D2>null</FONT></B><FONT =
<P><FONT color=3D#0000c0 size=3D2><FONT size=3D2><FONT face=3DArial=20
size=3D2>So..somehow I need to "fix" the problem (EDataObjectImpl(s) =
replaced=20
with DynamicEDataObjectImpl(s) during serialization / =
deserialization) ** on=20
my client **.</FONT></FONT></FONT></P>
<P><FONT color=3D#0000c0 size=3D2><FONT size=3D2><FONT =
face=3DArial>I saved the=20
System.out output if it might be useful?</FONT></FONT></FONT></P>
size=3D2></FONT></FONT></FONT> </P></FONT></DIV >
<DIV><FONT size=3D2><FONT color=3D#0000c0 =
size=3D2></FONT></FONT> </DIV>
size=3D2><BR></FONT></FONT></DIV>
<BLOCKQUOTE=20
BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px"><FONT=20
size=3D2><FONT color=3D#0000c0 size=3D2></FONT>
<DIV><FONT color=3D#0000c0 size=3D2>"Ed Merks" <<A=20
<A=20
href=3D"news:fj41hq$s5v$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:fj41hq$s5v$1@build.eclipse.org</A>...</FONT=
></DIV><FONT=20
color=3D#0000c0 size=3D2>Gary,<BR><BR>Comments below.<BR><BR>Gary =
Martin=20
wrote: </FONT>
<BLOCKQUOTE cite=3Dmid:fj3vsh$82p$1@build.eclipse.org =
type=3D"cite"><FONT=20
<META content=3D"MSHTML 6.00.2900.3199" name=3DGENERATOR></FONT>
<DIV><FONT color=3D#0000c0 size=3D2><FONT face=3DArial =
size=3D2>Upon further=20
investigation:</FONT></FONT></DIV><FONT color=3D#0000c0 =
size=3D2></FONT>
<DIV><FONT color=3D#0000c0 size=3D2></FONT> </DIV><FONT =
color=3D#0000c0=20
size=3D2></FONT>
size=3D2>Note: I'm using=20
in<BR>WebSphere App=20
.....\plugins\org.eclipse.emf.ecore.sdo_2.2.0.v200609210005. jar </FONT></FO=
NT></DIV><FONT=20
color=3D#0000c0=20
size=3D2></FONT>
size=3D2>In a previous=20
append - Tuesday, November 27, 2007 1:03 PM Eastern - I included =
a=20
snippet of source code from a <BR>method - =
acceptEDataGraph(EDataGraph)=20
defined by a Stateless Session EJB and on the EJB's remote=20
interface.</FONT></FONT></DIV><FONT color=3D#0000c0 =
size=3D2></FONT>
color=3D#0000c0=20
size=3D2></FONT>
size=3D2>Based on your=20
append - Tuesday, November 27, 2007 1:18 PM Eastern - I=20
IbmPackageImpl.init();<BR></FONT></FONT></DIV></BLOCKQUOTE ><FONT =
color=3D#0000c0 size=3D2>IbmPackage.eINSTANCE would be the =
preferred=20
way. IbmPackage.eINSTANCE.eClass() is the idiom we typically =
use if=20
we only want to force initialize but don't really need the=20
package.<BR></FONT>
size=3D2>as the 1st=20
below.)</FONT></FONT></DIV></BLOCKQUOTE><FONT color=3D#0000c0 =
size=3D2>Is this=20
done on both the client and the server?<BR></FONT>
color=3D#0000c0=20
size=3D2></FONT>
size=3D2><BR>Snippet from=20
feedback):</FONT></FONT></DIV><FONT color=3D#0000c0 =
size=3D2></FONT>
color=3D#0000c0=20
size=3D2></FONT>
Object=20
"static"=20
SDOs (inherit from EDataObjectImpl</FONT></FONT></DIV><FONT=20
color=3D#0000c0=20
size=3D2></FONT>
<DIV><FONT color=3D#0000c0 size=3D2><FONT face=3DArial=20
size=3D2>...</FONT></FONT></DIV><FONT color=3D#0000c0 =
size=3D2></FONT>
color=3D#0000c0=20
size=3D2></FONT>
size=3D2>Object anObject=20
=3D ((EDataGraphImpl) eDG).getWriteReplacement(); //=20
nbsp; & nbsp; & n=
bsp; &n bsp; &n b=
sp; &nb sp; &nb s=
p; =20
// just curious what Object was =
returned</FONT></FONT></DIV><FONT=20
color=3D#0000c0=20
size=3D2></FONT>
size=3D2>aSDOExchanger.acceptEDataGraph(eDG); // defined on =
remote=20
EJB</FONT></FONT></DIV></BLOCKQUOTE><FONT=20
color=3D#0000c0 size=3D2>You might want to try code like this =
(which we have=20
in our JUnit tests):<BR><BR><SMALL> =20
=3D new=20
inputStream=20
=3D new=20
null);<BR></SMALL><BR>This should help demonstrate that the =
datagraph is=20
serialization. =20
Try this on the client. If the server were configured the =
same way,=20
it should be able to deserialize the result.<BR></FONT>
color=3D#0000c0=20
size=3D2></FONT>
size=3D2>// eDG's=20
com.ibm.impl.DocumentRootImpl (generated "static" SDO - inherits =
from=20
EDataObjectImpl)<BR>// DocumentRootImpl.setPurchaseOrder was set =
to=20
"static"=20
SDO)<BR> <BR>// When accessed (after =
serialization /=20
accessed in EJB, DocumentRootImpl.getPurchaseOrder is instance =
of:=20
p;<BR>//=20
deserialization) of instances of generated "static" SDOs<BR>// =
(that=20
inherit from EDataObjectImpl)<BR>// with instances of=20
DynamicEDataObjectImpl has to be a conscious design choice - not =
a=20
bug.<BR></FONT></FONT></DIV></BLOCKQUOTE><FONT color=3D#0000c0 =
size=3D2>No, it=20
whether you=20
are transmitting the model from the client to the server or just =
assuming=20
the server knows the model already.<BR></FONT>
size=3D2>// As a result,=20
I can't use the generated "static" SDOs in the implementation of =
method=20
acceptEDataGraph(EDataGraph)</FONT></FONT></DIV><FONT =
color=3D#0000c0=20
size=3D2></FONT>
color=3D#0000c0=20
size=3D2></FONT>
size=3D2>Ed:</FONT></FONT></DIV><FONT color=3D#0000c0 =
size=3D2></FONT>
color=3D#0000c0=20
size=3D2></FONT>
size=3D2>a) Do you agree=20
/ disagree with that =
conclusion?<BR></FONT></FONT></DIV></BLOCKQUOTE><FONT=20
color=3D#0000c0 size=3D2>No. If you can get serialization =
and=20
deserialization to work locally on the client end, set a =
breakpoint in the=20
constructor for your generated DocumentRoot and see how the code =
gets=20
there. Similarly, set a breakpoint in the DynamicEDataObject =
different=20
in that case...<BR></FONT>
size=3D2>b) Do you know=20
if this behavior is different (by design) in newer Tuscany=20
implementations of SDO 1.0 or =
2.0?</FONT></FONT></DIV></BLOCKQUOTE><FONT=20
color=3D#0000c0 size=3D2>I think Tuscany started out with EMF's =
SDO=20
implementation, so I imagine the issues will be very similar or =
the=20
same.<BR></FONT>
<BLOCKQUOTE=20
5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px"><FONT=20
message <A=20
moz-do-not-send=3D"true">news:fihn1g$e1e$1@build.eclipse.org</A>...</FONT=
></DIV><FONT=20
color=3D#0000c0 size=3D2>Gary,<BR><BR>Comments =
below.<BR><BR>Gary Martin=20
wrote: </FONT>
<BLOCKQUOTE cite=3Dmid:fihm57$brk$1@build.eclipse.org=20
type=3D"cite"><FONT color=3D#0000c0 size=3D2>
<STYLE></STYLE>
</FONT>
size=3D2>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Thank you. I'm=20
that=20
the source code of</FONT></DIV>
itself=20
statement?</FONT></DIV></FONT></FONT></DIV></BLOCKQUOTE ><FONT=20
color=3D#0000c0 size=3D2>No, I'm suggesting that the tutorial =
shows you=20
the steps you need to generate the static code for your SDO =
model and=20
then the datagraph editor shows your model being used to read =
and=20
code.<BR></FONT>
type=3D"cite"><FONT color=3D#0000c0 size=3D2></FONT>
size=3D2>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Here's a snippet of code =
from the=20
method in my EJB where I'm able to use the =
static=20
API.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>import =
com.ibm.ItemType;<BR>import=20
com.ibm.DocumentRoot;<BR></FONT></DIV></FONT></FONT></DIV ></BLOCKQUOTE><F=
ONT=20
color=3D#0000c0 size=3D2>It looks like you've already =
generated the code=20
so that makes me a bit confused about why you asked how to =
generate=20
the the code.<BR></FONT>
size=3D2>
com.ibm.util.IbmResourceFactoryImpl;<BR>import=20
com.ibm.util.IbmResourceUtil;</FONT></DIV>
<DIV> </DIV>
commonj.sdo.DataObject;<BR>import =
commonj.sdo.Property;</FONT></DIV>
<DIV> </DIV>
org.eclipse.emf.ecore.impl.EReferenceImpl;<BR>import=20
org.eclipse.emf.ecore.sdo.EDataGraph;<BR>import=20
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>// method defined on the =
remote=20
interface <BR>public void acceptEDataGraph (EDataGraph =
eDG) =20
{</FONT></DIV>
<DIV> </DIV>
rootObject =3D=20
eDG.getRootObject(); // works<BR> DataObject=20
purchaseOrder =3D rootObject.getDataObject("purchaseOrder"); =
//=20
works</FONT></DIV>
<DIV> </DIV>
orderDate =3D=20
orderDate);=20
// works </FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2><BR> // This =
doesn't work=20
(DocumentRoot)eDG.getERootObject(); <BR> PurchaseOr=
derType=20
aPOT =3D documentRoot.getPurchaseOrder(); // what I'm =
referring to as=20
the "static" SDO API</FONT></DIV>
<DIV> </DIV>
<BR>java.rmi.ServerException: RemoteException occurred in =
server=20
thread; nested exception is: =
START:<BR> >> =
incompatible=20
with com.ibm.DocumentRoot<BR> >> at=20
</FONT></DIV></FONT></FONT></DIV></BLOCKQUOTE><FONT=20
color=3D#0000c0 size=3D2>Oh, I see. Maybe all that's =
missing is the=20
code to ensure that your generated package is registered with =
the=20
static registry. At some point during the initialization of =
the server=20
you should access the XyzPackage.eINSTANCE to ensure that the =
package=20
is registered.<BR></FONT>
size=3D2>
<BLOCKQUOTE=20
message=20
<A href=3D"news:fihdh6$jpc$1@build.eclipse.org"=20
Gary,<BR><BR>Yes,=20
that is possible:<BR>
<BLOCKQUOTE><A=20
href=3D" http://help.eclipse.org/help33/index.jsp?topic=3D/org.eclips e.emf=
.....ecore.sdo.doc/tutorials/datagraph/datagraph.html"=20
moz-do-not-send=3D"true">Tutorial: Using the SDO Data =
Graph=20
<BLOCKQUOTE cite=3Dmid:fihc9v$c1p$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">By design (with any version of SDO and =
then:
EDataGraph
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></FONT></FONT></DIV ><FONT=20
<BLOCKQUOTE=20
color=3D#0000c0 =
size=3D2></FONT> </BLOCKQUOTE></BLOCKQUOTE><FONT=20
color=3D#0000c0 =
size=3D2><BR></FONT></BLOCKQUOTE></BLOCKQUOTE><FONT=20
color=3D#0000c0=20
size=3D2><BR></FONT></FONT></BLOCKQUOTE></BLOCKQUOTE><BR ></BLOCKQUOTE></B=
ODY></HTML>
------=_NextPart_000_005E_01C8371E.9A4970F0--
Re: SDO Java -serialization/deserialization of EDataGraph - use Static SDO API after deserializatio [message #415213 is a reply to message #415210] |
Wed, 05 December 2007 14:21 |
Ed Merks Messages: 33142 Registered: July 2009 |
--------------090106010808080206020409
Gary,
I wonder if this is even needed?
resourceSet.createResource(URI.createURI(purchaseOrderPackag e.getNsURI()));
Gary Martin wrote:
> Ed,
> IbmPackage purchaseOrderPackage = IbmPackageImpl.eINSTANCE;
> your data graph.
> "Ed Merks" <merks@ca.ibm.com <mailto:merks@ca.ibm.com>> wrote in
> message news:fj4l1s$ttp$1@build.eclipse.org...
> Gary,
> Comments below.
> Gary Martin wrote:
>> Ed,
>> Thanks yet again.
> your data graph. That why the receiver will always use the
> dynamic package that you sent it and told it do use. Can you omit
> this entirely? You shouldn't need it and it's the cause of the
> problem.
>> (mixed:
>> _interface_: false))
>> in message news:fj41hq$s5v$1@build.eclipse.org...
>> Gary,
>> Comments below.
>>> included in
>>> Eastern - I added:
>> package.
>>> feedback):
>>> // create org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl and
>>> // generated IBMFactoryImpl and "static" SDOs (inherit from
>>> EDataObjectImpl
>> JUnit tests):
>> null);
>> same way, it should be able to deserialize the result.
>>> // eDG's ERootObject was set earlier to instance of:
>>> // DocumentRootImpl.setPurchaseOrder was set to instance of
>>> // When accessed (after serialization / deserialization) in
>>> EJB, EDataGraph's rootObject is a:
>>> is instance of:
>>> serialization / deserialization) of instances of generated
>>> "static" SDOs
>>> conscious design choice - not a bug.
>> registered and whether you are transmitting the model from
>> the model already.
>>> // As a result, I can't use the generated "static" SDOs in
>>> the implementation of method acceptEDataGraph(EDataGraph)
>>> Ed:
>>> a) Do you agree / disagree with that conclusion?
>> DynamicEDataObject constructor and look at how the code path
>> I imagine the issues will be very similar or the same.
>>> wrote in message news:fihn1g$e1e$1@build.eclipse.org...
>>> Gary,
>>> Comments below.
>>> Gary Martin wrote:
>>>> Ed,
>>>> problem statement?
>>> you need to generate the static code for your SDO model
>>>> import com.ibm.ItemType;
>>>> import com.ibm.PurchaseOrderType;
>>>> import com.ibm.DocumentRoot;
>>>> import com.ibm.util.IbmResourceUtil;
>>>> import commonj.sdo.DataObject;
>>>> import commonj.sdo.Property;
>>>> import org.eclipse.emf.ecore.impl.EReferenceImpl;
>>>> import org.eclipse.emf.ecore.sdo.EDataGraph;
>>>> import
>>>> org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl;
>>>> public void acceptEDataGraph (EDataGraph eDG) {
>>>> DataObject rootObject = eDG.getRootObject(); // works
>>>> rootObject.getDataObject("purchaseOrder"); // works
>>>> java.util.Date orderDate =
>>>> purchaseOrder.getDate("orderDate"); // works
>>>> // I get this exception
>>>> server thread; nested exception is:
>>>> >> SERVER (id=4773e3aa, host=IBM-0CA191A407D) TRACE START:
>>>> >> at
>>> registered.
>>>> <mailto:merks@ca.ibm.com>> wrote in message
>>>> Gary,
>>>> < http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.....ecore.sdo.doc/tutorials/datagraph/datagraph.html>
>>>>> then:
>>>>> EDataGraph
<html>
<head>
</head>
Gary,<br>
<br>
I wonder if this is even needed?<br>
<blockquote><font face="Arial" size="2">Resource packageResource =
resourceSet.createResource(URI.createURI(purchaseOrderPackag e.getNsURI())); </font><br>
<br>
</blockquote>
Gary Martin wrote:
<blockquote cite="mid:fj6bg5$50a$1@build.eclipse.org" type="cite">
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<meta content="MSHTML 6.00.2900.3199" name="GENERATOR">
<div><font face="Arial" size="2">Ed,</font></div>
<div> </div>
<div><font face="Arial" size="2">Success! Thanks again for all your
help.</font></div>
<div> </div>
<div><font face="Arial" size="2">For those following this thread,
what finally worked was:</font></div>
<div> </div>
<div><font face="Arial" size="2">Snippet from client:</font></div>
<div> </div>
<div><font face="Arial" size="2">IbmPackage purchaseOrderPackage =
IbmPackageImpl.eINSTANCE;<br>
ResourceSet resourceSet = eDG.getResourceSet();<br>
resourceSet.createResource(URI.createURI(purchaseOrderPackag e.getNsURI())); <br>
// packageResource.getContents().add(purchaseOrderPackage);& ;nbsp; <br>
purchaseOrderPackage); <br>
<br>
// ************************************************** eye catcher ******<br>
// <a moz-do-not-send="true"
href="news://news.eclipse.org/eclipse.tools.emf">news://news.eclipse.org/eclipse.tools.emf</a>
- Tuesday, December 04, 2007 5:40 PM Eastern<br>
data graph.<br>
sent it and told it do use.<br>
****** <br>
</font></div>
<blockquote
<div>"Ed Merks" <<a moz-do-not-send="true"
href="mailto:merks@ca.ibm.com">merks@ca.ibm.com</a>> wrote in
href="news:fj4l1s$ttp$1@build.eclipse.org">news:fj4l1s$ttp$1@build.eclipse.org</a>...</div>
Gary,<br>
<br>
Comments below.<br>
<br>
<div> </div>
<div> </div>
<div> </div>
<div>
</div>
</blockquote>
color="#0000c0" size="2">out</font></i><font color="#0000c0" size="2"><font
size="2">.println(</font><font color="#2a00ff" size="2">"eDG.getDataGraphResource().save(System.out,
face="Arial" size="2">So..somehow I need to "fix" the problem
serialization / deserialization) ** on my client **.</font></font></font></p>
face="Arial">I saved the System.out output if it might be useful?</font></font></font></p>
<p> </p>
</font></div>
<div> </div>
<blockquote
size="2">
wrote in message <a href="news:fj41hq$s5v$1@build.eclipse.org"
moz-do-not-send="true">news:fj41hq$s5v$1@build.eclipse.org</a>...</font></div>
<br>
Comments below.<br>
<br>
</font>
size="2">Upon further investigation:</font></font></div>
<div> </div>
size="2">Note: I'm using whatever implementation of SDO 1.0 spec IBM
included in<br>
......\plugins\org.eclipse.emf.ecore.sdo_2.2.0.v200609210005 .jar </font></font></div>
<div> </div>
size="2">In a previous append - Tuesday, November 27, 2007 1:03 PM
Eastern - I included a snippet of source code from a <br>
<div> </div>
size="2">Based on your append - Tuesday, November 27, 2007 1:18 PM
IbmPackage anIbmPackage = IbmPackageImpl.init();<br>
</blockquote>
the preferred way. IbmPackage.eINSTANCE.eClass() is the idiom we
typically use if we only want to force initialize but don't really need
the package.<br>
</font>
type="cite">
size="2">as the 1st statement in that method (This didn't appear to
change the behavior about which I comment below.)</font></font></div>
</blockquote>
and the server?<br>
</font>
type="cite">
<div> </div>
size="2"><br>
<div> </div>
size="2">// create org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl and
populate root Object and contained objects using<br>
<div> </div>
<div> </div>
size="2">Object anObject = ((EDataGraphImpl)
org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl$EDataGraphExte rnalizable <br>
// just
<div> </div>
size="2">aSDOExchanger.acceptEDataGraph(eDG); // defined on remote
</blockquote>
this (which we have in our JUnit tests):<br>
<br>
<small> eDataGraph.getDataGraphResource().save(System.out,
null);<br>
ByteArrayOutputStream outputStream = new ByteArrayOutputStream();<br>
ObjectOutputStream objectOutputStream = new
ObjectOutputStream(outputStream);<br>
objectOutputStream.writeObject(eDataGraph);<br>
objectOutputStream.close();<br>
InputStream inputStream = new
ByteArrayInputStream(outputStream.toByteArray());<br>
ObjectInputStream objectInputStream = new
ObjectInputStream(inputStream);<br>
(EDataGraph)objectInputStream.readObject();<br>
otherEDataGraph.getDataGraphResource().save(System.out, null);<br>
</small><br>
able to deserialize the result.<br>
</font>
type="cite">
<div> </div>
size="2">// eDG's ERootObject was set earlier to instance of:
com.ibm.impl.DocumentRootImpl (generated "static" SDO - inherits from
com.ibm.impl.PurchaseOrderTypeImpl (generated "static" SDO)<br>
<br>
// When accessed (after serialization / deserialization) in EJB,
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl<br>
// When accessed in EJB, DocumentRootImpl.getPurchaseOrder is instance
of: org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl<br>
<br>
// I've concluded that this "replacement" (during serialization /
deserialization) of instances of generated "static" SDOs<br>
// (that inherit from EDataObjectImpl)<br>
design choice - not a bug.<br>
</blockquote>
type of models you have registered and whether you are transmitting the
the model already.<br>
</font>
type="cite">
size="2">// As a result, I can't use the generated "static" SDOs in
the implementation of method acceptEDataGraph(EDataGraph)</font></font></div>
<div> </div>
<div> </div>
size="2">a) Do you agree / disagree with that conclusion?<br>
</blockquote>
set a breakpoint in the constructor for your generated DocumentRoot and
see how the code gets there. Similarly, set a breakpoint in the
DynamicEDataObject constructor and look at how the code path that gets
you there is different in that case...<br>
</font>
type="cite">
size="2">b) Do you know if this behavior is different (by design) in
newer Tuscany implementations of SDO 1.0 or 2.0?</font></font></div>
</blockquote>
or the same.<br>
</font>
type="cite">
<blockquote
<br>
Comments below.<br>
<br>
<blockquote cite="mid:fihm57$brk$1@build.eclipse.org"
size="2">
<div> </div>
<div><font face="Arial" size="2">Thank you. I'm
<div><font face="Arial" size="2">the SDO Data Graph
Editor itself illustrates c) in my problem statement?</font></div>
</blockquote>
code.<br>
</font>
type="cite">
size="2">
<div> </div>
<div><font face="Arial" size="2">Here's a snippet of code
<div><font face="Arial" size="2">API, but unable to use
the static API.</font></div>
<div> </div>
<div><font face="Arial" size="2">import com.ibm.ItemType;<br>
import com.ibm.PurchaseOrderType;<br>
import com.ibm.DocumentRoot;<br>
</font></div>
</blockquote>
how to generate the the code.<br>
</font>
type="cite">
size="2">
com.ibm.util.IbmResourceFactoryImpl;<br>
import com.ibm.util.IbmResourceUtil;</font></div>
<div> </div>
commonj.sdo.DataObject;<br>
import commonj.sdo.Property;</font></div>
<div> </div>
<div><font face="Arial" size="2"><br>
import org.eclipse.emf.ecore.impl.EReferenceImpl;<br>
import org.eclipse.emf.ecore.sdo.EDataGraph;<br>
import org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl;</font ></div>
<div> </div>
<div> </div>
<div> </div>
<div><font face="Arial" size="2">// method defined on the
public void acceptEDataGraph (EDataGraph eDG) {</font></div>
<div> </div>
DataObject rootObject = eDG.getRootObject(); // works<br>
DataObject purchaseOrder = rootObject.getDataObject("purchaseOrder");
// works</font></div>
<div> </div>
<div><font face="Arial" size="2"> java.util.Date
orderDate = purchaseOrder.getDate("orderDate"); // works<br>
System.out.println("orderDate: " + orderDate); // works </font></div>
<div> </div>
// This doesn't work <br>
DocumentRoot documentRoot = (DocumentRoot)eDG.getERootObject(); <br>
PurchaseOrderType aPOT = documentRoot.getPurchaseOrder(); // what I'm
referring to as the "static" SDO API</font></div>
<div> </div>
<div><font face="Arial" size="2">// I get this exception <br>
java.rmi.ServerException: RemoteException occurred in server thread;
nested exception is: <br>
java.rmi.RemoteException: <br>
>> SERVER (id=4773e3aa, host=IBM-0CA191A407D) TRACE START:<br>
>> java.rmi.RemoteException: ; nested exception is: <br>
com.ibm.DocumentRoot<br>
>> at
sdo.exchanger.SDOExchangerBean.acceptEDataGraph(SDOExchanger Bean.java:89) </font></div>
</blockquote>
the package is registered.<br>
</font>
type="cite">
size="2">
<blockquote
<div>"Ed Merks" <<a href="mailto:merks@ca.ibm.com"
moz-do-not-send="true">merks@ca.ibm.com</a>> wrote in message <a
href="news:fihdh6$jpc$1@build.eclipse.org" moz-do-not-send="true">news:fihdh6$jpc$1@build.eclipse.org</a>...</div>
Gary,<br>
<br>
Yes, that is possible:<br>
<blockquote><a
href=" http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.....ecore.sdo.doc/tutorials/datagraph/datagraph.html"
moz-do-not-send="true">Tutorial: Using the SDO Data Graph Editor</a><br>
</blockquote>
<br>
Gary Martin wrote:
<blockquote cite="mid:fihc9v$c1p$1@build.eclipse.org"
type="cite">
<pre wrap="">By design (with any version of SDO and Tuscany Java implementation),
then:
EDataGraph
</pre>
</blockquote>
<br>
</blockquote>
<blockquote
style="border-left: 2px solid rgb(0, 0, 0); padding-right: 0px; padding-left: 5px; margin-left: 5px; margin-right: 0px;"> </blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------090106010808080206020409--
Ed Merks
Re: SDO Java -serialization/deserialization of EDataGraph - simplified (as you suggested) code work [message #415217 is a reply to message #415213] |
Wed, 05 December 2007 15:45 |
------=_NextPart_000_006E_01C8372B.FF0CF5E0
Ed,
It's not.
This snippet of code from the client worked (i.e. can use Dynamic and/or =
Static SDOs in EJB method implementation):
IbmPackage purchaseOrderPackage =3D IbmPackageImpl.eINSTANCE; // *also* =
in EJB's ejbCreate() method
// ResourceSet resourceSet =3D eDG.getResourceSet();=20
// Resource packageResource =3D =
resourceSet.createResource(URI.createURI(purchaseOrderPackag e.getNsURI())=
// packageResource.getContents().add(purchaseOrderPackage);=20
purchaseOrderPackage); // register locally - serialized and sent??
// ************************************************** eye catcher =
data graph.
of the problem.
news:fj6c56$c38$1@build.eclipse.org...
Gary,
Gary Martin wrote:=20
Ed,
=20
// So you are registering this package locally and sending it with =
your data graph.
// That why the receiver will always use the dynamic package that =
// Can you omit this entirely? You shouldn't need it and it's the =
******=20
Gary,
Comments below.
Ed,
Thanks yet again.
I ran this code on my *client* (please note my comments //):
your data graph. That why the receiver will always use the dynamic =
package that you sent it and told it do use. Can you omit this =
entirely? You shouldn't need it and it's the cause of the problem.
System.out.println("eDG.getERootObject: " + =
(comment: Overnight shipping, orderDate: 2007-03-10)])
ByteArrayOutputStream outputStream =3D new =
ObjectOutputStream objectOutputStream =3D new =
InputStream inputStream =3D new =
ObjectInputStream objectInputStream =3D new =
EDataGraph otherEDataGraph =3D =
System.out.println("otherEDataGraph.getDataGraphResource().save(System.ou=
t, null); after deserialization =
System.out.println("otherEDataGraph.getERootObject: " + =
// otherEDataGraph.getERootObject: =
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl@3ae63ae6 (eClass: =
org.eclipse.emf.ecore.impl.EClassImpl@42f242f2 (name: DocumentRoot) =
(instanceClassName: null) (abstract: false, interface: false))
replaced with DynamicEDataObjectImpl(s) during serialization / =
Gary,
Comments below.
included in
WebSphere App Server v6.1.0.11 - =
Eastern - I added:
IbmPackage anIbmPackage =3D IbmPackageImpl.init();
IbmPackage.eINSTANCE would be the preferred way. =
IbmPackage.eINSTANCE.eClass() is the idiom we typically use if we only =
Is this done on both the client and the server?
Snippet from EJB client (with comments on which I ask your =
feedback):
// create org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl and =
// generated IBMFactoryImpl and "static" SDOs (inherit from =
EDataObjectImpl
eDG).getWriteReplacement(); // =
You might want to try code like this (which we have in our =
JUnit tests):
eDataGraph.getDataGraphResource().save(System.out, null);
null);
This should help demonstrate that the datagraph is properly =
serializable and can be recovered from the serialization. Try this on =
the client. If the server were configured the same way, it should be =
// eDG's ERootObject was set earlier to instance of: =
com.ibm.impl.DocumentRootImpl (generated "static" SDO - inherits from =
EDataObjectImpl)
// DocumentRootImpl.setPurchaseOrder was set to instance of =
=20
// When accessed (after serialization / deserialization) in =
EJB, EDataGraph's rootObject is a: =
// When accessed in EJB, DocumentRootImpl.getPurchaseOrder =
is instance of: org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl
=20
// I've concluded that this "replacement" (during =
serialization / deserialization) of instances of generated "static" SDOs
No, it really depends on what type of models you have =
registered and whether you are transmitting the model from the client to =
the server or just assuming the server knows the model already.
// As a result, I can't use the generated "static" SDOs in =
Ed:
generated DocumentRoot and see how the code gets there. Similarly, set =
a breakpoint in the DynamicEDataObject constructor and look at how the =
code path that gets you there is different in that case...
I think Tuscany started out with EMF's SDO implementation, so =
Gary,
Comments below.
Ed,
problem statement?
No, I'm suggesting that the tutorial shows you the steps =
you need to generate the static code for your SDO model and then the =
Here's a snippet of code from the method in my EJB where =
It looks like you've already generated the code so that =
makes me a bit confused about why you asked how to generate the the =
code.
import =
DataObject rootObject =3D eDG.getRootObject(); // =
works
java.util.Date orderDate =3D =
System.out.println("orderDate: " + orderDate); // =
works=20
DocumentRoot documentRoot =3D =
"static" SDO API
// I get this exception=20
server thread; nested exception is:=20
START:
>> at =
Gary,
then:
EDataGraph
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2900.3199" name=3DGENERATOR></HEAD>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>It's not.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>This snippet of code from the client =
worked (i.e.=20
can use Dynamic and/or Static SDOs in EJB method =
implementation):</FONT></DIV>
<P align=3Dleft><STRONG>IbmPackage purchaseOrderPackage =3D=20
IbmPackageImpl.</STRONG></FONT><I><FONT color=3D#0000c0=20
size=3D2><STRONG>eINSTANCE</STRONG></I></FONT><FONT =
size=3D2><STRONG>; //=20
*also* in EJB's ejbCreate() method</STRONG></P>
<P align=3Dleft></FONT><FONT color=3D#3f7f5f size=3D2>// ResourceSet =
resourceSet =3D=20
eDG.getResourceSet(); </P></FONT><FONT size=3D2>
<P align=3Dleft></FONT><FONT color=3D#3f7f5f size=3D2>// Resource =
);</P></FONT><FONT=20
size=3D2>
<P align=3Dleft></FONT><FONT color=3D#3f7f5f size=3D2>//=20
</P></FONT><FONT=20
size=3D2>
purchaseOrderPackage); // register locally - serialized and=20
sent??</P></FONT><FONT size=3D2>
<P align=3Dleft></P>
************************************************** eye catcher=20
******************************************</P></FONT><FONT size=3D2>
news://news.eclipse.org/eclipse.tools.emf - Tuesday, December 04, 2007 =
5:40 PM=20
Eastern</P></FONT><FONT size=3D2>
<P align=3Dleft></FONT><FONT color=3D#3f7f5f size=3D2>// So you are =
registering this=20
package locally and sending it with your data graph.</P></FONT><FONT =
size=3D2>
<P align=3Dleft></FONT><FONT color=3D#3f7f5f size=3D2>// That why the =
receiver will=20
always use the dynamic package that you sent it and told it do=20
use.</P></FONT><FONT size=3D2>
<P align=3Dleft></FONT><FONT color=3D#3f7f5f size=3D2>// Can you omit =
this entirely?=20
You shouldn't need it and it's the cause of the problem.</P></FONT><FONT =
size=3D2>
<P></FONT><FONT color=3D#3f7f5f size=3D2>//=20
******************************************</P></FONT></DIV >
<BLOCKQUOTE=20
href=3D"news:fj6c56$c38$1@build.eclipse.org">news:fj6c56$c38$1@build.ecli=
pse.org</A>...</DIV>Gary,<BR><BR>I=20
wonder if this is even needed?<BR>
<BLOCKQUOTE><FONT face=3DArial size=3D2>Resource packageResource =3D=20
);</FONT><BR><BR></BLOCKQUOTE>Gary=20
Martin wrote:=20
<BLOCKQUOTE cite=3Dmid:fj6bg5$50a$1@build.eclipse.org type=3D"cite">
<DIV> </DIV>
your=20
help.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>For those following this thread, =
what finally=20
<DIV> </DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>IbmPackage purchaseOrderPackage =3D =
);<BR>//=20
/=20
******<BR>//=20
<A href=3D"news://news.eclipse.org/eclipse.tools.emf"=20
moz-do-not-send=3D"true">news://news.eclipse.org/eclipse.tools.emf</A> - =
registering this=20
package locally and sending it with your data graph.<BR>// That why =
the=20
receiver will always use the dynamic package that you sent it and =
told it do=20
use.<BR>// Can you omit this entirely? You shouldn't need it =
and it's=20
the cause of the problem.<BR>//=20
******=20
<BR></FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A href=3D"mailto:merks@ca.ibm.com"=20
moz-do-not-send=3D"true">merks@ca.ibm.com</A>> wrote in message =
<A=20
href=3D"news:fj4l1s$ttp$1@build.eclipse.org"=20
moz-do-not-send=3D"true">news:fj4l1s$ttp$1@build.eclipse.org</A>...</DIV>=
Gary,<BR><BR>Comments=20
below.<BR><BR>Gary Martin wrote:=20
<BLOCKQUOTE cite=3Dmid:fj4dcs$pb1$1@build.eclipse.org =
type=3D"cite">
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Thanks yet again.</FONT></DIV>
<DIV> </DIV>
(please note=20
my comments //):</FONT></DIV>
<DIV> </DIV>
<DIV>
=3D=20
resourceSet.createResource(URI.<I>createURI</I>(purchaseOrderPackage.getN=
/P>
<P><FONT=20
RI(),=20
registering=20
this package locally and sending it with your data graph. =
That why=20
the receiver will always use the dynamic package that you sent it =
and told=20
it do use. Can you omit this entirely? You shouldn't =
need it=20
and it's the cause of the problem.<BR>
type=3D"cite">
<DIV><FONT face=3DArial =
size=3D2><STRONG>...</STRONG></FONT></DIV>
color=3D#0000c0=20
size=3D2>.println(</FONT><FONT color=3D#2a00ff=20
size=3D2>"eDG.getDataGraphResource().save(System.out, null); =
before=20
serialization =
<P align=3Dleft><FONT color=3D#0000c0 size=3D2><FONT=20
size=3D2>.println(</FONT><FONT color=3D#2a00ff =
size=3D2>"eDG.getERootObject:=20
"</FONT><FONT size=3D2> + =
<P align=3Dleft><FONT color=3D#0000c0 size=3D2>// <FONT=20
size=3D2>eDG.getERootObject:=20
<STRONG>com.ibm.impl.DocumentRootImpl</STRONG>@52565256 (mixed:=20
(comment:=20
Overnight shipping, </FONT><U><FONT color=3D#000080=20
size=3D2>orderDate</FONT></U><FONT size=3D2>:=20
size=3D2><FONT=20
size=3D2>eDG.getDataGraphResource().save(System.</FONT><I ><FONT=20
</FONT><B><FONT=20
color=3D#7f0055 size=3D2>null</FONT></B><FONT=20
size=3D2><FONT=20
size=3D2>ByteArrayOutputStream outputStream =3D </FONT><B><FONT=20
color=3D#7f0055 size=3D2>new</FONT></B><FONT size=3D2>=20
size=3D2><FONT=20
size=3D2>ObjectOutputStream objectOutputStream =3D =
</FONT><B><FONT=20
size=3D2><FONT=20
size=3D2><FONT=20
size=3D2><FONT=20
size=3D2>InputStream inputStream =3D </FONT><B><FONT =
color=3D#7f0055=20
size=3D2><FONT=20
size=3D2><FONT=20
size=3D2><FONT=20
size=3D2>"otherEDataGraph.getDataGraphResource().save(System.out, null); =
after deserialization=20
size=3D2><FONT=20
size=3D2>"otherEDataGraph.getERootObject: "</FONT><FONT =
size=3D2> +=20
size=3D2><FONT size=3D2>//=20
<FONT size=3D2>otherEDataGraph.getERootObject:=20
<STRONG>org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl </STRONG>@3a=
e63ae6=20
(eClass: org.eclipse.emf.ecore.impl.EClassImpl@42f242f2 (name:=20
DocumentRoot) (instanceClassName: null) (abstract: false,=20
</FONT><U><FONT color=3D#000080 =
NT=20
</FONT><B><FONT=20
face=3DArial=20
size=3D2>So..somehow I need to "fix" the problem =
(EDataObjectImpl(s)=20
replaced with DynamicEDataObjectImpl(s) during serialization /=20
deserialization) ** on my client **.</FONT></FONT></FONT></P>
System.out output if it might be =
<P> </P></FONT></DIV>
<DIV> </DIV>
<BLOCKQUOTE=20
size=3D2>
message <A=20
></DIV><FONT=20
wrote: </FONT>
<BLOCKQUOTE cite=3Dmid:fj3vsh$82p$1@build.eclipse.org=20
<META content=3D"MSHTML 6.00.2900.3199" =
<DIV> </DIV>
size=3D2>Note: I'm=20
using whatever implementation of SDO 1.0 spec IBM included=20
in<BR>WebSphere App Server v6.1.0.11 -=20
......\plugins\org.eclipse.emf.ecore.sdo_2.2.0.v200609210005 .jar </FONT></F=
ONT></DIV>
<DIV> </DIV>
size=3D2>In a=20
previous append - Tuesday, November 27, 2007 1:03 PM Eastern =
- I=20
included a snippet of source code from a <BR>method -=20
acceptEDataGraph(EDataGraph) defined by a Stateless Session =
EJB and=20
on the EJB's remote interface.</FONT></FONT></DIV>
<DIV> </DIV>
size=3D2>Based on=20
your append - Tuesday, November 27, 2007 1:18 PM Eastern - I =
added:<BR>IbmPackage anIbmPackage =3D=20
IbmPackageImpl.init();<BR></FONT></FONT></DIV></BLOCKQUOTE ><FONT=20
preferred=20
way. IbmPackage.eINSTANCE.eClass() is the idiom we =
typically use=20
if we only want to force initialize but don't really need the=20
package.<BR></FONT>
type=3D"cite">
statement in that method (This didn't appear to change =
the=20
behavior about which I comment=20
size=3D2>Is=20
this done on both the client and the server?<BR></FONT>
type=3D"cite">
<DIV> </DIV>
size=3D2><BR>Snippet=20
from EJB client (with comments on which I ask your=20
<DIV> </DIV>
size=3D2>// create=20
org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl and populate =
root=20
Object and contained objects using<BR>// generated =
IBMFactoryImpl=20
<DIV> </DIV>
<DIV> </DIV>
size=3D2>Object=20
anObject =3D ((EDataGraphImpl) eDG).getWriteReplacement(); =
//=20
org.eclipse.emf.ecore.sdo.impl.EDataGraphImpl$EDataGraphExte rnalizable <BR=
nbsp; & nbsp; & n=
bsp; &n bsp; &n b=
sp; &nb sp; &nb s=
p; =20
// just curious what Object was returned</FONT></FONT></DIV>
<DIV> </DIV>
remote=20
interface of Stateless Session=20
EJB</FONT></FONT></DIV></BLOCKQUOTE><FONT color=3D#0000c0 =
size=3D2>You=20
might want to try code like this (which we have in our JUnit=20
eDataGraph.getDataGraphResource().save(System.out,=20
null);<BR> ByteArrayOutputStream =
outputStream =3D new=20
ByteArrayOutputStream();<BR> =
ObjectOutputStream=20
objectOutputStream =3D new=20
ObjectOutputStream(outputStream);<BR> =20
objectOutputStream.writeObject(eDataGraph);<BR> =20
objectOutputStream.close();<BR> InputStream=20
inputStream =3D new=20
ByteArrayInputStream(outputStream.toByteArray());<BR> =20
ObjectInputStream objectInputStream =3D new=20
ObjectInputStream(inputStream);<BR> =
EDataGraph=20
(EDataGraph)objectInputStream.readObject();<BR> =20
otherEDataGraph.getDataGraphResource().save(System.out,=20
datagraph=20
is properly serializable and can be recovered from the=20
serialization. Try this on the client. If the =
server were=20
configured the same way, it should be able to deserialize the=20
result.<BR></FONT>
type=3D"cite">
<DIV> </DIV>
ERootObject was set earlier to instance of:=20
com.ibm.impl.DocumentRootImpl (generated "static" SDO - =
inherits=20
from EDataObjectImpl)<BR>// =
DocumentRootImpl.setPurchaseOrder was=20
set to instance of com.ibm.impl.PurchaseOrderTypeImpl =
(generated=20
"static" SDO)<BR> <BR>// When accessed =
(after=20
serialization / deserialization) in EJB, EDataGraph's =
rootObject is=20
a: =
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl<BR>// When=20
accessed in EJB, DocumentRootImpl.getPurchaseOrder is =
instance of:=20
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl<BR> &nbs=
p;<BR>//=20
/=20
deserialization) of instances of generated "static" =
SDOs<BR>// (that=20
DynamicEDataObjectImpl has to be a conscious design choice - =
not a=20
bug.<BR></FONT></FONT></DIV></BLOCKQUOTE><FONT =
color=3D#0000c0=20
size=3D2>No, it really depends on what type of models you have =
registered and whether you are transmitting the model from the =
client=20
to the server or just assuming the server knows the model=20
already.<BR></FONT>
type=3D"cite">
size=3D2>// As a=20
result, I can't use the generated "static" SDOs in the=20
implementation of method=20
<DIV> </DIV>
<DIV> </DIV>
size=3D2>a) Do you=20
agree / disagree with that=20
conclusion?<BR></FONT></FONT></DIV></BLOCKQUOTE><FONT =
color=3D#0000c0=20
size=3D2>No. If you can get serialization and =
deserialization to=20
work locally on the client end, set a breakpoint in the =
constructor=20
for your generated DocumentRoot and see how the code gets =
there. =20
constructor and=20
look at how the code path that gets you there is different in =
that=20
case...<BR></FONT>
type=3D"cite">
size=3D2>b) Do you=20
know if this behavior is different (by design) in newer =
Tuscany=20
implementations of SDO 1.0 or=20
2.0?</FONT></FONT></DIV></BLOCKQUOTE><FONT color=3D#0000c0 =
size=3D2>I=20
think Tuscany started out with EMF's SDO implementation, so I =
imagine=20
the issues will be very similar or the same.<BR></FONT>
type=3D"cite">
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: =
moz-do-not-send=3D"true">merks@ca.ibm.com</A>> wrote in =
message=20
<A href=3D"news:fihn1g$e1e$1@build.eclipse.org"=20
></DIV><FONT=20
below.<BR><BR>Gary=20
Martin wrote: </FONT>
name=3DGENERATOR>
<STYLE></STYLE>
</FONT>
size=3D2>
<DIV> </DIV>
suggesting=20
that the source code of</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>the SDO Data Graph =
Editor itself=20
illustrates c) in my problem=20
color=3D#0000c0 size=3D2>No, I'm suggesting that the =
tutorial shows=20
you the steps you need to generate the static code for =
your SDO=20
model and then the datagraph editor shows your model being =
used to=20
read and write instances or your model using your =
generated=20
code.<BR></FONT>
<BLOCKQUOTE cite=3Dmid:fihm57$brk$1@build.eclipse.org =
type=3D"cite">
size=3D2>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Here's a snippet of =
code from the=20
dynamic</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>API, but unable to use =
the static=20
API.</FONT></DIV>
<DIV> </DIV>
com.ibm.PurchaseOrderType;<BR>import=20
ONT=20
generated the=20
code so that makes me a bit confused about why you asked =
how to=20
generate the the code.<BR></FONT>
type=3D"cite">
size=3D2>
<DIV><FONT face=3DArial size=3D2>import=20
<DIV> </DIV>
commonj.sdo.DataObject;<BR>import=20
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2><BR>import=20
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl;</FONT ></DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>// method defined on =
the remote=20
interface <BR>public void acceptEDataGraph (EDataGraph=20
eDG) {</FONT></DIV>
<DIV> </DIV>
size=3D2><BR> DataObject=20
rootObject =3D eDG.getRootObject(); //=20
works<BR> DataObject purchaseOrder =3D=20
rootObject.getDataObject("purchaseOrder"); // =
works</FONT></DIV>
<DIV> </DIV>
size=3D2> java.util.Date=20
orderDate =3D purchaseOrder.getDate("orderDate"); //=20
works<BR> System.out.println("orderDate: " +=20
orderDate); // works </FONT></DIV>
<DIV> </DIV>
doesn't=20
work <BR> DocumentRoot documentRoot =3D=20
derType=20
referring to=20
as the "static" SDO API</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>// I get this exception =
<BR>java.rmi.ServerException: RemoteException occurred =
in server=20
<BR> java.rmi.RemoteException:=20
<BR> >> SERVER (id=3D4773e3aa, =
host=3DIBM-0CA191A407D)=20
TRACE START:<BR> >> =20
<BR> java.lang.ClassCastException:=20
org.eclipse.emf.ecore.sdo.impl.DynamicEDataObjectImpl=20
incompatible with =
com.ibm.DocumentRoot<BR> >> =20
at=20
missing is=20
the code to ensure that your generated package is =
registered with=20
the static registry. At some point during the =
initialization of=20
the server you should access the XyzPackage.eINSTANCE to =
ensure=20
that the package is registered.<BR></FONT>
type=3D"cite">
size=3D2>
<BLOCKQUOTE=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; =
MARGIN-LEFT: 5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: 0px">
moz-do-not-send=3D"true">merks@ca.ibm.com</A>> =
wrote in=20
message <A =
moz-do-not-send=3D"true">news:fihdh6$jpc$1@build.eclipse.org</A>...</DIV>=
<BLOCKQUOTE><A=20
......ecore.sdo.doc/tutorials/datagraph/datagraph.html"=20
moz-do-not-send=3D"true">Tutorial: Using the SDO =
Data Graph=20
Editor</A><BR></BLOCKQUOTE><BR>Gary Martin wrote:=20
<BLOCKQUOTE cite=3Dmid:fihc9v$c1p$1@build.eclipse.org=20
type=3D"cite"><PRE wrap=3D"">By design (with any =
then:
EDataGraph
<BLOCKQUOTE=20
MARGIN-LEFT: 5px; BORDER-LEFT: rgb(0,0,0) 2px solid; MARGIN-RIGHT: =
0px"> </BLOCKQUOTE></BLOCKQUOTE><FONT=20
color=3D#0000c0 =
color=3D#0000c0=20
LOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_006E_01C8372B.FF0CF5E0--
Current Time: Fri Apr 26 10:05:58 GMT 2024
Powered by FUDForum. Page generated in 0.04390 seconds
