Re: Chaging the current object in a property sheet [message #414966 is a reply to message #414961] |
Mon, 26 November 2007 16:43 |
Ed Merks Messages: 33218 Registered: July 2009 |
--------------050305030705030909010201
Jose,
Viewer panes are just a convenience. In the end, you can change the
generated editor in whatever way works best for you. The EcoreEditor,
for example, doesn't use ViewerPanes.
Jose Hernandez wrote:
> Hi Ed,
> There seems to be some disconnect between the UI forms and EMF editor
> hierarchy but I have managed to get the UI forms working with EMF by adding
> my form page directly as a page in the editor. I am not sure whether this is
> the correct way of doing things though.
> Would you be able to tell me whether a viewer pane still needs to be used
> when adding forms to the editor or adding the form directly as a page is Ok?
> Thanks
> Jos
Ed Merks
FUDForum. Page generated in 0.03774 seconds
