Home » Modeling » EMF » Error found in EMF 2.4, extension of map creates "The interface Entry cannot be implemented mor
Re: Error found in EMF 2.4, extension of map creates "The interface Entry cannot be implemented [message #414708 is a reply to message #414707] |
Sun, 18 November 2007 18:16 |
Philipp Kutter Messages: 306 Registered: July 2009 |
Perfect, this solved the problem. A corresponding validation constraint
might be added... shall I open a feature request?
You ask for the use of extending a map entry class. Here is our approach:
We treat strongly typed maps, as supported in EMF models as first class
citizens of our business models. Especially, since I can use containment
semantics for either of key or value, and since I can use the many-flag
to have values being lists. (I never tried out what a many-flagged
key-feature would give...)
Thanks to the mapping of maps to classes with key/value features, we can
now attach additional attributes or references to the map entries. And
often, there are different variants of these additional attributes or
references, which are then added to different subtypes of the map entry.
Does this make sense to you?
Best, Philipp
Ed Merks wrote:
> Philipp,
> I guess I didn't notice this posting for some reason...
> If you set instanceClassName to java.util.Map$Entry for
> MapEClass1Extension it works okay. I'm not sure what utility there is
> in extending a map entry EClass though mind you. What are you trying to
> accomplish by doing this?
> Philipp W. Kutter wrote:
>> Ed, shall I enter a bug report?
>> Best, Philipp
>>> Hi.
>>> In the included ZIP, an error is appearing.
>>> You can as well recreate it by creating a map with ecore in one project,
>>> and then creating an extension of the map in the next one.
>>> The full error is:
>>> Severity and Description Path Resource Location Creation
>>> Time Id
>>> The interface Entry cannot be implemented more than once with
>>> different arguments: Map.Entry<EClass2,EClass3> and Map.Entry
>>> TestMapsExtension/src/TestMapsExtension/impl
>>> MapEClass1ExtensionImpl.java line 25 1194980174734 13531
>>> Any idea what this is?
>>> Best, Philipp
Re: Error found in EMF 2.4, extension of map creates "The interface Entry cannot be implemented [message #414710 is a reply to message #414708] |
Sun, 18 November 2007 20:35 |
Ed Merks Messages: 33216 Registered: July 2009 |
--------------070605050407090609060306
Philipp,
Please add your test case to 207449
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=207449>
It does make sense, though generally if a client simply uses the EMap's
put to add things, just a base entry will be created...
> constraint might be added... shall I open a feature request?
> many-flag to have values being lists. (I never tried out what a
> many-flagged key-feature would give...)
> can now attach additional attributes or references to the map entries.
> And
> Best, Philipp
> Ed Merks wrote:
>> Philipp,
>> is in extending a map entry EClass though mind you. What are you
>> trying to accomplish by doing this?
>>> Best, Philipp
>>>> Hi.
>>>> project,
>>>> The full error is:
>>>> Creation Time Id
>>>> Best, Philipp
<html>
<head>
</head>
Philipp,<br>
<br>
Please add your test case to <a name="b207449"
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=207449">207449</a><br>
<br>
put to add things, just a base entry will be created...<br>
<br>
<br>
<blockquote cite="mid:fhpvg5$m9t$1@build.eclipse.org" type="cite">Perfect,
this solved the problem. A corresponding validation constraint might be
<br>
<br>
<br>
approach:
<br>
<br>
<br>
containment
<br>
<br>
<br>
And
<br>
entry.
<br>
<br>
<br>
<br>
Best, Philipp
<br>
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Philipp,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">Ed, shall I enter a bug report?
<br>
<br>
Best, Philipp
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi.
<br>
<br>
<br>
project,
<br>
<br>
<br>
The full error is:
<br>
Time Id
<br>
The interface Entry cannot be implemented more than once with different
<br>
<br>
<br>
<br>
Best, Philipp
<br>
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------070605050407090609060306--
Ed Merks
Re: Error found in EMF 2.4, extension of map creates "The interface Entry cannot be implemented [message #414749 is a reply to message #414710] |
Tue, 20 November 2007 15:35 |
Done.
Ed Merks wrote:
> Philipp,
>> And
>> Best, Philipp
>> Ed Merks wrote:
>>> Philipp,
>>>> Best, Philipp
>>>>> Hi.
>>>>> project,
>>>>> The full error is:
>>>>> Creation Time Id
>>>>> Best, Philipp
Current Time: Sun Sep 22 07:31:36 GMT 2024
Powered by FUDForum. Page generated in 0.04050 seconds
