Home » Modeling » EMF » Sync names of two resources--use WorkspaceSynchronizer?
Re: Sync names of two resources--use WorkspaceSynchronizer? [message #414147 is a reply to message #414146] |
Fri, 26 October 2007 00:07 |
Hi, Jeff,
That's right -- the WorkspaceSynchronizer's purpose is to notify an editor
that a resource it currently has loaded is changed in the workspace.
Sounds like you're going to need IResourceChangeListener, though I suspect
the WorkspaceSynchronizer might still be useful for helping out editors
that do happen to be open :-)
HTH,
Christian
Jeff Ramsdale wrote:
> I have two files whose names (identical, but for their file extensions)
> I need to keep in sync (that is, if one is renamed the other is also
> automatically renamed). The first is my custom EMF model instance, the
> other is a corresponding UML instance.
> My initial poke at this suggested WorkspaceSychronizer might be a
> candidate for helping me out--I'd have to implement a custom delegate.
> Toying with this approach, though, suggests it would only trap changes
> to a resource referenced by an open editor (technically, an active
> EditingDomain). Is an IResourceChangeListener a better option? Other
> ideas?
> -jeff
Re: Sync names of two resources--use WorkspaceSynchronizer? [message #414244 is a reply to message #414147] |
Fri, 26 October 2007 18:45 |
Jeff Ramsdale Messages: 122 Registered: July 2009 |
Aren't there other scenarios where I might not have any editors open but
that I might have several resources impacted by a change? In other
words, I feel like I'm reinventing something by combining
WorkspaceSynchronizer and an additional ResourceChangeListener.
Here's a concrete example. If I rename a .ecore file, shouldn't the
reference to it in the corresponding .genmodel change as well? Is there
a particular reason this isn't the case? What would be the best way to
implement this capability?
Jeff
Christian W. Damus wrote:
> Hi, Jeff,
> HTH,
> Christian
>> ideas?
>> Thanks,
>> -jeff
Re: Sync names of two resources--use WorkspaceSynchronizer? [message #414245 is a reply to message #414244] |
Fri, 26 October 2007 18:54 |
Ed Merks Messages: 33141 Registered: July 2009 |
--------------090702040608020306030002
Jeff,
Well, yes, there is much we could do in terms of providing refactoring
support. But that's a pretty challenging problem in the general case
and we likely can't tackle that without help from the community.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=149508
> but that I might have several resources impacted by a change? In other
> there a particular reason this isn't the case? What would be the best
> way to implement this capability?
> Jeff
>> Hi, Jeff,
>> editor
>> suspect
>> HTH,
>> Christian
>>> ideas?
>>> Thanks,
>>> -jeff
<html>
<head>
</head>
Jeff,<br>
<br>
and we likely can't tackle that without help from the community.<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=149508">https://bugs.eclipse.org/bugs/show_bug.cgi?id=149508</a><br>
</blockquote>
<br>
<br>
<blockquote cite="mid:fftcl1$p5k$1@build.eclipse.org" type="cite">Aren't
there other scenarios where I might not have any editors open but that
I might have several resources impacted by a change? In other words, I
feel like I'm reinventing something by combining WorkspaceSynchronizer
<br>
<br>
<br>
<br>
Jeff
<br>
<br>
<br>
<blockquote type="cite">Hi, Jeff,
<br>
<br>
editor
<br>
<br>
<br>
suspect
<br>
<br>
<br>
<br>
HTH,
<br>
<br>
Christian
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">I have two files whose names (identical,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
ideas?
<br>
<br>
<br>
<br>
-jeff
<br>
</blockquote>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------090702040608020306030002--
Ed Merks
Current Time: Fri Apr 26 04:01:54 GMT 2024
Powered by FUDForum. Page generated in 0.02770 seconds
