Home » Modeling » EMF » Serializing Ecore model
Serializing Ecore model [message #413646] |
Sun, 07 October 2007 10:01 |
Lorenzo Dalla Vecchia Messages: 58 Registered: July 2009 |
Member |
Hi everyone.
With the help of this ng and refering to this article on devx
(http://www.devx.com/Java/Article/29093/0/page/3), I succeeded in doing the
following:
- loading an Ecore MetaModel (modeling level 2) obtaining its Java objects
representation
- using the above metamodel to programmatically create a conforming instance
Model (modeling level 1) using classes like EObject, EClass, etc.
As a last step, I know need to serialize the model into an Ecore file.
I'm using the following code, partly inspired by the devx article:
public void saveModel(String path, EObject rootElement)
throws IOException
// Prepare ResourceSet and needed factories
ResourceSet resourceSet = new ResourceSetImpl();
Map<String,ResourceFactoryImpl> extMap =
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap();
extMap.put("*", new XMIResourceFactoryImpl());
// Register necessary packages
resourceSet.getPackageRegistry().put(myPackage1.getNsURI(),
myPackage1);
resourceSet.getPackageRegistry().put(myPackage2.getNsURI(),
myPackage2);
// Create the resource
Resource resource =
resourceSet.createResource(URI.createFileURI(path));
List<EObject> objectList = resource.getContents();
objectList.add(rootElement);
// Serialize model
resource.save(null);
The two parameters of the above method are the path of a local file to save
to and the EObject that is the root of my model, instantiated
programmatically.
The resulting Ecore files seems ok, but with a little flaw: it does not set
a default namespace (xmlns) in the root element, and therefore the element
names can't be correctly mapped to the Ecore file of the metamodel.
How can I fix that? I already tried using an EcoreResourceFactoryImpl
instead of XMIResourceFactoryImpl without any difference in the generated
file. Other ideas?
Thank you.
Lorenzo
Re: Serializing Ecore model [message #413647 is a reply to message #413646] |
Sun, 07 October 2007 11:36 |
Ed Merks Messages: 33216 Registered: July 2009 |
Lorenzo,
Comments below.
Lorenzo Dalla Vecchia wrote:
> Hi everyone.
> doing the following:
> objects representation
> instance Model (modeling level 1) using classes like EObject, EClass,
> etc.
Typically I would refer a .ecore file containing an EPackage as a Ecore
file.
> throws IOException
> myPackage1);
> myPackage2);
> Resource resource =
It's often a good idea to use new File(path).getAbsolutePath() or
getCanonicalPath() to ensure you have a fully qualified path name.
> // Serialize model
> save to and the EObject that is the root of my model, instantiated
> programmatically.
> not set a default namespace (xmlns) in the root element, and therefore
> the element names can't be correctly mapped to the Ecore file of the
> metamodel.
What's the value of rootElement.eClass().getEPackage().getNsURI() and
getNsPrefix(). Both should generally be non-null and the former should
be universally unique.
> generated file. Other ideas?
It sounds like you've either not specified the namespace URI or the
namespace prefix of the package appropriately.
> Thank you.
> Lorenzo
Ed Merks
Re: Serializing Ecore model [message #413773 is a reply to message #413772] |
Fri, 12 October 2007 10:36 |
Tom,
It's best to ask about it on the EODM newsgroup, which I've added to the
"to" list of the reply.
Tom wrote:
> Thanks so much. I really don't need 2-way conversion. I would just
> like to have my ".model" files converted to OWL so that the diagrams
> created from within the gmf editor can be stored in an OWL db. I tried
> to use EODM Ecore2OWL, but havent found a way to turn my models into
> actual ecore documents for that. I appreciate your help!
> Tom
> Ed Merks wrote:
>> Tom,
>> Unless there is a two way converter I'm not sure how saving Ecore as
>> OWL will be reversible...
>> Tom wrote:
>>> Should I use the same approach to serialize to OWL? However, there
>>> is no
> OWLResourceFactoryImpl extant. I have seen ecore2owl, so instead I
> could save to ecore then run that converter. What would be the
> preferred method, especially within the context of a GMF project,
> saving graph instances to OWL?
>>> Thanks!
>>> Tom
Ed Merks
Current Time: Fri Sep 20 13:28:30 GMT 2024
Powered by FUDForum. Page generated in 0.04848 seconds
