Home » Modeling » EMF » [editor] Tree with Columns
Re: [editor] Tree with Columns [message #413796 is a reply to message #413500] |
Mon, 15 October 2007 01:47 |
Miles Parker Messages: 1341 Registered: July 2009 |
Ed et. al.
It seems that it would be pretty 'easy' ;) to support say columns for
some interface shared across EClasses for each of that interface's
properties. For example for the Ecore meta-model itself you could have
a column for names and annotations for all ENamedElements -- trivial
example, I know. In general, one could imagine some way of mapping
property n of each column to an aribtrary EAttribute for a given
cooresponding EObject. Before I attempt to implement something custom,
any plans to support Tree Column's in EMF.edit or thoughts about
patterns for doing so?
On 2007-10-02 07:27:25 -0400, Ed Merks <merks@ca.ibm.com> said:
> Philipp,
> The MappingEditor has some fancier examples. Eclipse now directly
> supports a Tree Viewer with columns so there's no need to use a table
> tree. You'll need to learn about cell editors to support editing of
> the columns. Other than the mapping editor, which is very old, I don't
> have anything specific to point you at. In terms of EMF.edit support,
> it's a matter of making the factory's supported types include
> ITableItemLabelProvider and then specialize the item providers to
> implement getColumnText. (Eclipse 3.3.0 had a problem that
> getColumnText was used even for a tree without columns but that's fixed
> in 3.3.1.)
> Philipp W. Kutter wrote:
>> Hi.
>> There is a version of the generated Editor, named "Tree with Columns"
>> Is there a tutorial or example how to add more columns, and especially
>> how to make fields editable directly in the columns?
>> Has someone developed specific templates supporting this, and is ready
>> to share them?
>> Any input or experience is welcome. I will post my own experiences here
>> once I am successful in doing this.
>> Best, Philipp
Re: [editor] Tree with Columns [message #413802 is a reply to message #413796] |
Mon, 15 October 2007 11:13 |
Ed Merks Messages: 33141 Registered: July 2009 |
Miles,
I've never thought about an automatic way to generate that. Generally I
would expect column support to be specific to the viewer for which the
support is being defined. I assume you know about
ITableItemLabelProvider; you can make your item providers implement that
and make your factory support that type...
Miles Parker wrote:
> Ed et. al.
>> Philipp,
>> don't have anything specific to point you at. In terms of EMF.edit
>> support, it's a matter of making the factory's supported types
>> include ITableItemLabelProvider and then specialize the item
>> providers to implement getColumnText. (Eclipse 3.3.0 had a problem
>> that getColumnText was used even for a tree without columns but
>> that's fixed in 3.3.1.)
>>> Hi.
>>> especially how to make fields editable directly in the columns?
>>> ready to share them?
>>> here once I am successful in doing this.
>>> Best, Philipp
Ed Merks
Re: [editor] Tree with Columns [message #413813 is a reply to message #413796] |
Mon, 15 October 2007 15:05 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
I'd say with the new TreeViewerColumn and EditingSupport-API this could
be done much easier than with the old index-based one.
This way you would generate an EditingSupport/ColumnLabelProvider pair
and use it in all Trees/Tables.
Tom
Miles Parker schrieb:
> Ed et. al.
> properties. For example for the Ecore meta-model itself you could have a
>> Philipp,
>> support, it's a matter of making the factory's supported types include
>> fixed in 3.3.1.)
>>> Hi.
>>> Best, Philipp
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [editor] Tree with Columns [message #413816 is a reply to message #413813] |
Mon, 15 October 2007 16:03 |
Tom,
We'll need to understand what we could do in EMF to exploit/enable
this. So much to do and so little time...
Tom Schindl wrote:
> could be done much easier than with the old index-based one.
> Tom
>> Ed et. al.
>> have a column for names and annotations for all ENamedElements --
>> trivial example, I know. In general, one could imagine some way of
>> mapping property n of each column to an aribtrary EAttribute for a
>> given cooresponding EObject. Before I attempt to implement something
>> custom, any plans to support Tree Column's in EMF.edit or thoughts
>> about patterns for doing so?
>>> Philipp,
>>> table tree. You'll need to learn about cell editors to support
>>> editing of the columns. Other than the mapping editor, which is
>>> very old, I don't have anything specific to point you at. In terms
>>> of EMF.edit support, it's a matter of making the factory's supported
>>> types include ITableItemLabelProvider and then specialize the item
>>>> Hi.
>>>> Best, Philipp
Ed Merks
Re: [editor] Tree with Columns [message #413817 is a reply to message #413816] |
Mon, 15 October 2007 16:06 |
Ed,
Once I have time I'll try to come up with a solution :-)
Tom
Ed Merks schrieb:
> Tom,
> Tom Schindl wrote:
>> Tom
>>> Ed et. al.
>>>> Philipp,
>>>>> Hi.
>>>>> Best, Philipp
Re: [editor] Tree with Columns [message #413820 is a reply to message #413817] |
Mon, 15 October 2007 16:15 |
Tom,
You're like an angel from heaven! O:-)
Tom Schindl wrote:
> Ed,
> Tom
> Ed Merks schrieb:
>> Tom,
>> Tom Schindl wrote:
>>> Hi,
>>> pair and use it in all Trees/Tables.
>>> Tom
>>>> Ed et. al.
>>>> for some interface shared across EClasses for each of that
>>>> interface's properties. For example for the Ecore meta-model itself
>>>> you could have a column for names and annotations for all
>>>> ENamedElements -- trivial example, I know. In general, one could
>>>> imagine some way of mapping property n of each column to an
>>>> aribtrary EAttribute for a given cooresponding EObject. Before I
>>>> attempt to implement something custom, any plans to support Tree
>>>> Column's in EMF.edit or thoughts about patterns for doing so?
>>>>> Philipp,
>>>>> terms of EMF.edit support, it's a matter of making the factory's
>>>>> supported types include ITableItemLabelProvider and then
>>>>> specialize the item providers to implement getColumnText.
>>>>> (Eclipse 3.3.0 had a problem that getColumnText was used even for
>>>>> a tree without columns but that's fixed in 3.3.1.)
>>>>>> Hi.
>>>>>> Columns"
>>>>>> experiences here once I am successful in doing this.
>>>>>> Best, Philipp
Ed Merks
Re: [editor] Tree with Columns [message #413825 is a reply to message #413802] |
Mon, 15 October 2007 19:29 |
On 2007-10-15 07:13:21 -0400, Ed Merks <merks@ca.ibm.com> said:
> Miles,
> I would expect column support to be specific to the viewer for which
> the support is being defined.
Yes, that is definetly true..I guess I was thinking of something along
the lines of the default Tree Editor which has worked very well for me.
I find it awkward to click back and forth from the tree view to the
property editor, so I'd love the ability to allow users to edit key
attributes directly from the Tree row. Together with drag and drop that
would create a very powerful intuitive editor for hierarchically
organized data. (Say a visual behavior editor.)
> I assume you know about ITableItemLabelProvider; you can make your item
> providers implement that and make your factory support that type...
Well, that might be assuming a lot ;) esp. as my SWT/JFace expereince
is still pretty light, but yes -- especially with the nice support for
custom provider roots (thanks again) it would be a very simple matter
to continue to use the same adapters for all of my base
behavior..perfect. The "only" remaining piece then would be editing
support as Tom discusses.
It seems in fact from my reading of things that at the EMF API level
anyway would be to do something like provide a
getColumnPropertyDescriptor(int columnIndex)
in ITableItemProvider or elsewhere. That would be extremely nice..
> Miles Parker wrote:
>> Ed et. al.
>>> Philipp,
>>> in 3.3.1.)
>>>> Hi.
>>>> to share them?
>>>> Best, Philipp
Re: [editor] Tree with Columns [message #413826 is a reply to message #413825] |
Mon, 15 October 2007 20:02 |
Miles,
Yes, support for editing cells of a table would be cool. Something
like IUpdateableItemText already lets you do some in place editing in
the tree itself...
>> Miles,
>> Generally I would expect column support to be specific to the viewer
>> for which the support is being defined.
> me. I find it awkward to click back and forth from the tree view to
> the property editor, so I'd love the ability to allow users to edit
> key attributes directly from the Tree row. Together with drag and drop
> that would create a very powerful intuitive editor for hierarchically
>> item providers implement that and make your factory support that type...
>> Miles Parker wrote:
>>> Ed et. al.
>>>> Philipp,
>>>> supported types include ITableItemLabelProvider and then specialize
>>>> the item providers to implement getColumnText. (Eclipse 3.3.0 had
>>>> a problem that getColumnText was used even for a tree without
>>>>> Hi.
>>>>> Best, Philipp
Ed Merks
Re: [editor] Tree with Columns [message #413827 is a reply to message #413826] |
Mon, 15 October 2007 20:33 |
I didn't know that..cool!
On 2007-10-15 16:02:29 -0400, Ed Merks <merks@ca.ibm.com> said:
> Miles,
> the tree itself...
>>> Miles,
>>> Miles Parker wrote:
>>>> Ed et. al.
>>>>> Philipp,
>>>>> in 3.3.1.)
>>>>>> Hi.
>>>>>> to share them?
>>>>>> Best, Philipp
Re: [editor] Tree with Columns [message #413828 is a reply to message #413827] |
Mon, 15 October 2007 20:41 |
--------------040000020600050300080909
Miles,
*E*xceedingly *M*any *F*eatures. Or is that *E*xcellent *M*ystery
*F*unctionality.
>> Miles,
>> the tree itself...
>>>> Miles,
>>>> viewer for which the support is being defined.
>>> along the lines of the default Tree Editor which has worked very
>>> well for me. I find it awkward to click back and forth from the tree
>>> view to the property editor, so I'd love the ability to allow users
>>> to edit key attributes directly from the Tree row. Together with
>>> drag and drop that would create a very powerful intuitive editor for
>>> hierarchically organized data. (Say a visual behavior editor.)
>>>> type...
>>> expereince is still pretty light, but yes -- especially with the
>>> nice support for custom provider roots (thanks again) it would be a
>>> very simple matter to continue to use the same adapters for all of
>>> my base behavior..perfect. The "only" remaining piece then would be
>>> editing support as Tom discusses.
>>>> Miles Parker wrote:
>>>>> Ed et. al.
>>>>> itself you could have a column for names and annotations for all
>>>>>> Philipp,
>>>>>> directly supports a Tree Viewer with columns so there's no need
>>>>>> to use a table tree. You'll need to learn about cell editors to
>>>>>> support editing of the columns. Other than the mapping editor,
>>>>>> which is very old, I don't have anything specific to point you
>>>>>> at. In terms of EMF.edit support, it's a matter of making the
>>>>>> factory's supported types include ITableItemLabelProvider and
>>>>>> then specialize the item providers to implement getColumnText.
>>>>>>> Hi.
>>>>>>> Columns"
>>>>>>> Best, Philipp
<html>
<head>
</head>
Miles,<br>
<br>
<big><b>E</b></big>xceedingly <big><b>M</b></big>any <big><b>F</b></big>eatures.
Or is that <big><b>E</b></big>xcellent <big><b>M</b></big>ystery <big><b>F</b></big>unctionality.<br>
<br>
<br>
Miles Parker wrote:
<blockquote cite="mid:ff0iqm$m6b$1@build.eclipse.org" type="cite"><br>
<br>
<br>
On 2007-10-15 16:02:29 -0400, Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> said:
<br>
<br>
<blockquote type="cite">Miles,
<br>
<br>
the tree itself...
<br>
<br>
<br>
Miles Parker wrote:
<br>
<blockquote type="cite"><br>
<br>
On 2007-10-15 07:13:21 -0400, Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> said:
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<blockquote type="cite">I assume you know about
<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Miles Parker wrote:
<br>
Ed et. al.
<br>
<br>
<br>
<br>
<br>
On 2007-10-02 07:27:25 -0400, Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> said:
<br>
<br>
<blockquote type="cite">Philipp,
<br>
<br>
in 3.3.1.)
<br>
<br>
<br>
<br>
<blockquote type="cite">Hi.
<br>
<br>
<br>
<br>
<br>
to share them?
<br>
<br>
<br>
<br>
Best, Philipp
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------040000020600050300080909--
Ed Merks
Re: [editor] Tree with Columns [message #413830 is a reply to message #413828] |
Mon, 15 October 2007 21:10 |
I much prefer a tool where the rate of new feature implementation
exceeds that of the rate of feature promotion to one in which the rate
of new feature promotion greatly exceeds the rate of actual feature
implementation. Not naming ..cough..(redmond)..cough.. names..
On 2007-10-15 16:41:15 -0400, Ed Merks <merks@ca.ibm.com> said:
> Miles,
> *F*unctionality.
>>> Miles,
>>> the tree itself...
>>>>> Miles,
>>>>> Miles Parker wrote:
>>>>>> Ed et. al.
>>>>>>> Philipp,
>>>>>>> in 3.3.1.)
>>>>>>>> Hi.
>>>>>>>> to share them?
>>>>>>>> Best, Philipp
> <html>
> <head>
> </head>
> Miles,<br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> the tree itself...
> <br>
> <br>
> <br>
> Miles Parker wrote:
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> </blockquote>
> <br>
> <br>
> <br>
> <br>
> </blockquote>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> Miles Parker wrote:
> <br>
> Ed et. al.
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> in 3.3.1.)
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> <br>
> to share them?
> <br>
> <br>
> <br>
> <br>
> Best, Philipp
> <br>
> </blockquote>
> </blockquote>
> </blockquote>
> </blockquote>
> </blockquote>
> </blockquote>
> <br>
> <br>
> </blockquote>
> <br>
> </body>
> </html>
Running Prototype for Tree with Columns [message #414504 is a reply to message #413820] |
Fri, 09 November 2007 15:49 |
Philipp Kutter Messages: 306 Registered: July 2009 |
Hi, Ed.
I have a running prototype.
It allows to have the same edit support you have in the
standard property view, for references and attributes.
If there is someone who has a couple days time, and wants to improve the
example, he can contact me at kutter@montages.com
With a little time, this can be turned into a useful example/tutorial
for the community. Maybe Miles, Tom, or Ron are interested.. With even
a little more time, it could be turned into an improved editor JET which
shows the label-feature editable in the second column.
Best, Philipp
Ed Merks wrote:
> Tom,
> Tom Schindl wrote:
>> Ed,
>> Tom
>> Ed Merks schrieb:
>>> Tom,
>>> Tom Schindl wrote:
>>>> Hi,
>>>> Tom
>>>>> Ed et. al.
>>>>>> Philipp,
>>>>>>> Hi.
>>>>>>> Columns"
>>>>>>> Best, Philipp
Re: Running Prototype for Tree with Columns [message #414507 is a reply to message #414504] |
Fri, 09 November 2007 16:19 |
Philipp,
Maybe it would be good to open bugzilla feature request and put it as an
attachment.
Note that with IUpdateableItemText it's possible to support in-place
editing directly in the tree view.
> Hi, Ed.
> the example, he can contact me at kutter@montages.com
> Best, Philipp
> Ed Merks wrote:
>> Tom,
>> Tom Schindl wrote:
>>> Ed,
>>> Tom
>>> Ed Merks schrieb:
>>>> Tom,
>>>> Tom Schindl wrote:
>>>>> Hi,
>>>>> Tom
>>>>>> Ed et. al.
>>>>>>> Philipp,
>>>>>>> for a tree without columns but that's fixed in 3.3.1.)
>>>>>>>> Hi.
>>>>>>>> Columns"
>>>>>>>> is ready to share them?
>>>>>>>> Best, Philipp
Ed Merks
Re: Running Prototype for Tree with Columns [message #414516 is a reply to message #414507] |
Fri, 09 November 2007 23:21 |
Hi, Ed.
I am actually not sure whether there should be anything added/changed in
EMF itself. But if someone has time to elaborate the topic, this person
may come up with a proposal for a feature request.
I assume just adding a prototype doing in-place editing in the tree view
will not be enough to motivate the EMF team to update the generator
template. At least, someone should provide the editor JET template
showing how this is done... this could be added.
Best, Philipp
Ed Merks wrote:
> Philipp,
> attachment.
>> Hi, Ed.
>> Best, Philipp
>> Ed Merks wrote:
>>> Tom,
>>> Tom Schindl wrote:
>>>> Ed,
>>>> Tom
>>>> Ed Merks schrieb:
>>>>> Tom,
>>>>> Tom Schindl wrote:
>>>>>> Hi,
>>>>>> Tom
>>>>>>> Ed et. al.
>>>>>>>> Philipp,
>>>>>>>>> Hi.
>>>>>>>>> Columns"
>>>>>>>>> Best, Philipp
Re: Running Prototype for Tree with Columns [message #414518 is a reply to message #414516] |
Sat, 10 November 2007 13:17 |
Philipp,
It sounds like this would make another good EMF Recipe then:
http://wiki.eclipse.org/EMF/Recipes
> Hi, Ed.
> in EMF itself. But if someone has time to elaborate the topic, this
> person may come up with a proposal for a feature request.
> Best, Philipp
> Ed Merks wrote:
>> Philipp,
>> an attachment.
>>> Hi, Ed.
>>> example/tutorial for the community. Maybe Miles, Tom, or Ron are
>>> which
>>> Best, Philipp
>>> Ed Merks wrote:
>>>> Tom,
>>>> Tom Schindl wrote:
>>>>> Ed,
>>>>> Tom
>>>>> Ed Merks schrieb:
>>>>>> Tom,
>>>>>> exploit/enable this. So much to do and so little time...
>>>>>> Tom Schindl wrote:
>>>>>>> Hi,
>>>>>>> this could be done much easier than with the old index-based one.
>>>>>>> EditingSupport/ColumnLabelProvider pair and use it in all
>>>>>>> Trees/Tables.
>>>>>>> Tom
>>>>>>>> Ed et. al.
>>>>>>>> columns for some interface shared across EClasses for each of
>>>>>>>> that interface's properties. For example for the Ecore
>>>>>>>> meta-model itself you could have a column for names and
>>>>>>>> annotations for all ENamedElements -- trivial example, I know.
>>>>>>>> In general, one could imagine some way of mapping property n of
>>>>>>>>> Philipp,
>>>>>>>>> need to use a table tree. You'll need to learn about cell
>>>>>>>>> editors to support editing of the columns. Other than the
>>>>>>>>> mapping editor, which is very old, I don't have anything
>>>>>>>>> specific to point you at. In terms of EMF.edit support, it's
>>>>>>>>> to implement getColumnText. (Eclipse 3.3.0 had a problem that
>>>>>>>>>> Hi.
>>>>>>>>>> Columns"
>>>>>>>>>> Best, Philipp
Ed Merks
Re: Running Prototype for Tree with Columns [message #414534 is a reply to message #414504] |
Mon, 12 November 2007 01:26 |
Hi Philipp,
I'm definately interested but given that my current time is very limited
I won't have the time look at it (or at least I don't know exactly when
I have time).
To me this sounds like a bugzilla where you add your code we can then
base the next steps on. All contributions have to made through bugzilla
because this ensures the IP-Process all committers have to follow!
To me it also have to possibility that others who might have the spirit
to work and give feedback could attach to the bug :-)
Tom
Philipp W. Kutter schrieb:
> Hi, Ed.
> Best, Philipp
> Ed Merks wrote:
>> Tom,
>> Tom Schindl wrote:
>>> Ed,
>>> Tom
>>> Ed Merks schrieb:
>>>> Tom,
>>>> Tom Schindl wrote:
>>>>> Hi,
>>>>> Tom
>>>>>> Ed et. al.
>>>>>>> Philipp,
>>>>>>>> Hi.
>>>>>>>> Columns"
>>>>>>>> Best, Philipp
Re: Running Prototype for Tree with Columns [message #414558 is a reply to message #414504] |
Tue, 13 November 2007 03:17 |
Ron Bermejo Messages: 30 Registered: July 2009 |
Member |
> Hi, Ed.
> Best, Philipp
Hello Philipp!
I am interested in your example...
I think we implemented the same thing :-)
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=207324)
I am also currently interested in the developments in this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=75625
plus this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=144260
equals a tree/table editor for EMF objects that uses databinding!
-Ron
Re: Running Prototype for Tree with Columns [message #414959 is a reply to message #414558] |
Mon, 26 November 2007 15:28 |
Hi, Ron.
I'll forward your feature request to our developer.
He will then see whether his classes can be combined with
what you already submitted.
Best, Philipp
>> Hi, Ed.
>> Best, Philipp
> Hello Philipp!
> plus this bug:
> -Ron
Re: Running Prototype for Tree with Columns [message #414960 is a reply to message #414534] |
Mon, 26 November 2007 15:34 |
Hi, Tom.
My developer will see how his classes fit with what Ron added in his
bug. He basically did two classes, which allow to have the normal EMF
editing stuff apearing in the columns of the tree editor.
Best, Philipp
Tom Schindl wrote:
> Hi Philipp,
> I have time).
> Tom
>> Hi, Ed.
>> Best, Philipp
>> Ed Merks wrote:
>>> Tom,
>>> Tom Schindl wrote:
>>>> Ed,
>>>> Tom
>>>> Ed Merks schrieb:
>>>>> Tom,
>>>>> Tom Schindl wrote:
>>>>>> Hi,
>>>>>> Tom
>>>>>>> Ed et. al.
>>>>>>>> Philipp,
>>>>>>>>> Hi.
>>>>>>>>> Columns"
>>>>>>>>> Best, Philipp
Current Time: Fri Apr 26 00:07:46 GMT 2024
Powered by FUDForum. Page generated in 0.12543 seconds
