Home » Modeling » GMF (Graphical Modeling Framework) » How to modify the properties page?.. Please help
How to modify the properties page?.. Please help [message #41766] Thu, 07 September 2006 07:28 Go to next message
Originally posted by: vikas.goyal.hp.com
If I want to modify the property view of the GMF editor. How can I do
it? I would like to add an additional column here and populate the values.
for example: If I have an element like the following:
<NodeA employeeid="abc" customizable="true"/>
In property view i want this to be shown as follows: Label Header should
be as follows:
Attribute Name Value Modifable
employeeid abc true (drop down box)
Here I would like to shown the attribute employeeid and its value "abc" to
be displayed along with the value of customizable. I want to display only
the value of the customizable attribute.
Please suggest ...
Thanks & regards
Vikas
Re: How to modify the properties page?.. Please help [message #43853 is a reply to message #41766] Sun, 10 September 2006 08:01 Go to previous messageGo to next message
Originally posted by: a318mb.gmail.com
Hi.
See group eclipse.tools.emf
Example -
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg1 8913.html
For gmf find and override ...
package xxxxxx.diagram.providers
public class XXXXXPropertyProvider extends GenericEMFPropertiesProvider
protected ICompositePropertySource createPropertySource(Object object,
IItemPropertySource itemPropertySource) {
if (object instanceof XXXXXImpl) return new
XXXXXXPropertySource(object,itemPropertySource, "MYGROUP"); //$NON-NLS-1$}
package xxxx.diagram.providers;
import
org.eclipse.gmf.runtime.emf.ui.properties.descriptors.EMFCom positePropertySo
urce
import ...
public class XXXXPropertySource extends EMFCompositePropertySource {
protected IPropertyDescriptor newPropertyDescriptor(IItemPropertyDescriptor
itemPropertyDescriptor) {
return new XXXXSourcePropertyDescriptor(object, itemPropertyDescriptor,
getCategory());
package XXXXX.diagram.providers;
import
org.eclipse.gmf.runtime.emf.ui.properties.descriptors.EMFCom positeSourceProp
ertyDescriptor
import ...
public class XXXXXSourcePropertyDescriptor extends
EMFCompositeSourcePropertyDescriptor {
protected CellEditor doCreateEditor(Composite composite) {
Object genericFeature = getFeature();
if (object instanceof MyFeature) {
MyDialogCellEditor cellEditor = new MyDialogCellEditor(composite){
protected void focusLost() {
if (isActivated()) { deactivate(); }
return cellEditor;
return super.doCreateEditor(composite);
package....
import org.eclipse.jface.viewers.DialogCellEditor;
import....
public class MyDialogCellEditor extends DialogCellEditor {
protected Object openDialogBox(Control cellEditorWindow) {
//TODO show dialog return new vaule
Re: How to modify the properties page?.. Please help [message #60619 is a reply to message #43853] Tue, 10 October 2006 06:01 Go to previous message
Hi Mishael,
I just tried your proposal. Looks like it works quite well. But as I'm
totally new with writing my own Properties-view I'm not sure about some
things happening. Could you please give some more explanations?
1. in 'Take control of your properties'-Paper the propertyDescriptors
are generated in the getPropertyDescriptors()-method. Why do I need to
override ...
> @Override
> getCategory());
2. What's the DialogCellEditor for? and why am I not able to edit my
Properties?
3. By now, the Properties are all added to the Advanced-Tab of the
Tabbed-Property-View. Is there a way to use the custom-properties in old
Properties-view? Or better: Do you know how to replace the
tabbed-Properties-View with the old one (table-properties with two
columns name-Value-Pairs)
It would be very nice of you if you could lighten up my
mysteries-clouded brain.
Thanks in advance
Alex
Previous Topic:Strange setScale() call in GMF generated code for createTargetDecoration()
Next Topic:Modular diagrams
Current Time: Fri Nov 07 08:14:33 EST 2025
Powered by FUDForum. Page generated in 0.03758 seconds
