total or partial CASE generation from EPFC [message #41739] |
Mon, 01 October 2007 05:27 |
Just a little post to know your opinion on the relevance or the
feasability of creating an extension of EPFC which would generate
completely or partially automatically a CASE above JDT or other IDE in
Eclipse from the description of the method made in EPFC.
The thought is that a method which is not well instrumented is not well
used and can drive the project to failure. It is the same problem with
languages ; it is often better to have a less well suited language to a
problem if this language is well tooled than , in the absolute, a better
language which would only have VI or Textpad for developping the code.
The generated CASE would address especially the documentation, the
reporting, the collaboration concerns of the method and then could
customize other plugins like Topcased,, Rational XIDE, ... It could use
as basis for instance Mylin, UML2, ECF, ans so on..., too.
Waiting for your comments :)
regards
Xavier
FUDForum. Page generated in 0.06255 seconds
