Re: Generating code for OCL annotations in OCL 1.0.1/EMF 2.2 [message #41719] |
Fri, 26 October 2007 12:52  |
Hi, Uday,
The MDT OCL newsgroup is the correct place for discussion event of the 1.0.x
version which was hosted in the EMFT project.
The article you reference was initially devised for version OCL 1.0.x and
EMF 2.2. See the second attachment to the Eclipse Corner bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=143580
HTH,
Christian
Uday Kabe wrote:
> I was reading through the article "Implementing Model Integrity in EMF
> with MDT OCL" and wondering if something similar can be done with OCL
> 1.0.1/EMF2.2?
> If so, can anyone point me to an article or to documentation that provides
> some details on how to do it?
> Thanx in advance.
> Uday
Re: Generating code for OCL annotations in OCL 1.0.1/EMF 2.2 [message #41817 is a reply to message #41751] |
Fri, 26 October 2007 14:58   |
--------------090602000302020108070504
Uday,
Often people don't notice that when they select a property in the
properties view the status line shows a short description. The idea for
this setting is that it allows you to specify additional plugin
dependencies that will be generated into the MANIFEST.MF when it's
generated the first time; plugin.xml and MANIFEST.MF doesn't support
merge so will not be touched after that first time. So if you know you
are generating code that won't compile without additional classpath
entries, you can specify them this way...
Uday Kabe wrote:
> Thanx Christian.
> I am unclear on the potential uses of the Model Plugin Variables setting in
> the genmodel? Could you elaborate on it?
> Thanx.
> Uday
> "Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
> news:fft60q$c15$1@build.eclipse.org...
>> Hi, Uday,
>> 1.0.x
>> HTH,
>> Christian
>>> 1.0.1/EMF2.2?
>>> provides
>>> Thanx in advance.
>>> Uday
<html>
<head>
</head>
Uday,<br>
<br>
for this setting is that it allows you to specify additional plugin
entries, you can specify them this way...<br>
<br>
<br>
Uday Kabe wrote:
<blockquote cite="mid:fft9gu$e0n$1@build.eclipse.org" type="cite">
<pre wrap="">Thanx Christian.
Thanx.
Uday
"Christian W. Damus" <a class="moz-txt-link-rfc2396E" href="mailto:cdamus@ca.ibm.com"><cdamus@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:fft60q$c15$1@build.eclipse.org">news:fft60q$c15$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Hi, Uday,
1.0.x
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=143580">https://bugs.eclipse.org/bugs/show_bug.cgi?id=143580</a>
HTH,
Christian
Uday Kabe wrote:
</pre>
<pre wrap="">I was reading through the article "Implementing Model Integrity in EMF
1.0.1/EMF2.2?
provides
Thanx in advance.
Uday
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------090602000302020108070504--
Re: Generating code for OCL annotations in OCL 1.0.1/EMF 2.2 [message #41842 is a reply to message #41817] |
Fri, 26 October 2007 18:43  |
------=_NextPart_000_01AA_01C817F7.B5C5CFE0
charset="iso-8859-1"
Ed,
Thanx for the info on the setting; it's definitely good to know.
You are absolutely right. That very sneaky status line seems to be out =
of my line of sight; I will remember to check it more often now.
Thanx again.
Uday
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:fftdcl$t0k$1@build.eclipse.org...
Uday,
Often people don't notice that when they select a property in the =
properties view the status line shows a short description. The idea for =
this setting is that it allows you to specify additional plugin =
dependencies that will be generated into the MANIFEST.MF when it's =
generated the first time; plugin.xml and MANIFEST.MF doesn't support =
merge so will not be touched after that first time. So if you know you =
are generating code that won't compile without additional classpath =
Uday Kabe wrote:=20
Thanx Christian.
I am unclear on the potential uses of the Model Plugin Variables setting =
in=20
Thanx.
Uday
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message=20
Hi, Uday,
The MDT OCL newsgroup is the correct place for discussion event of the=20
1.0.x
The article you reference was initially devised for version OCL 1.0.x =
and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D143580
HTH,
Christian
Uday Kabe wrote:
I was reading through the article "Implementing Model Integrity in =
EMF
1.0.1/EMF2.2?
If so, can anyone point me to an article or to documentation that=20
provides
Thanx in advance.
Uday
=20
=20
<HTML><HEAD>
<META content=3D"MSHTML 6.00.6000.16544" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>Ed,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Thanx for the info on the setting; it's =
definitely=20
good to know.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>You are absolutely right. That =
very sneaky=20
status line seems to be out of my line of sight; I will remember =
to check=20
it more often now.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanx again.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Uday</FONT></DIV>
<BLOCKQUOTE=20
<DIV>"Ed Merks" <<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>>=20
wrote in message <A=20
href=3D"news:fftdcl$t0k$1@build.eclipse.org">news:fftdcl$t0k$1@build.ecli=
pse.org</A>...</DIV>Uday,<BR><BR>Often=20
people don't notice that when they select a property in the properties =
view=20
the status line shows a short description. The idea for this =
setting is=20
that it allows you to specify additional plugin dependencies that will =
be=20
generated into the MANIFEST.MF when it's generated the first time; =
plugin.xml=20
and MANIFEST.MF doesn't support merge so will not be touched after =
that first=20
time. So if you know you are generating code that won't compile =
without=20
additional classpath entries, you can specify them this =
way...<BR><BR><BR>Uday=20
Kabe wrote:=20
<BLOCKQUOTE cite=3Dmid:fft9gu$e0n$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Thanx Christian.
in=20
Thanx.
Uday
"Christian W. Damus" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:cdamus@ca.ibm.com"><cdamus@ca.ibm.com></A> wrote in =
message=20
<A class=3Dmoz-txt-link-freetext =
href=3D"news:fft60q$c15$1@build.eclipse.org">news:fft60q$c15$1@build.ecli=
pse.org</A>...
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi, Uday,
1.0.x
and
href=3D"https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D143580">https://b=
ugs.eclipse.org/bugs/show_bug.cgi?id=3D143580</A>
HTH,
Christian
Uday Kabe wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">I was reading through the =
1.0.1/EMF2.2?
provides
Thanx in advance.
Uday
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_01AA_01C817F7.B5C5CFE0--
FUDForum. Page generated in 0.04065 seconds
