Home » Modeling » M2T (model-to-text transformation) » Setting string to a variable
Setting string to a variable [message #41697] Mon, 11 February 2008 12:29 Go to next message
Originally posted by: pankaj.surti.xxxx.com
I use the following syntax to set the variable with string value.
<c:setVariable select="'Somevalue'" var="ctlType"/>
I do get the value correctly when I use
(context.getVariable("ctlType").toString());
My questions is:
Is this correct way to use the "select"?
-Pankaj.
Re: Setting string to a variable [message #41846 is a reply to message #41697] Wed, 13 February 2008 11:10 Go to previous message
Yes.
And, in addition to using Java code, you could use:
<c:get select="$ctlType"/>
You can also use:
<c:setVariable select=" 3 " var="someNumericVar"/>
And, for that matter, you can loop via:
<c:iterate select=" 10 " var="index">
index: <c:get select="$index"/>
</c:iterate>
Paul
"pankaj" <pankaj.surti@xxxx.com> wrote in message
news:0e815c8f13613ae88b2df9d5663e30e6$1@www.eclipse.org...
> My questions is:
> -Pankaj.
Previous Topic:Debugging the JET in the Eclipse
Next Topic:How to test an element specified in the input xml or not?
Current Time: Fri Jun 06 12:31:08 EDT 2025
Powered by FUDForum. Page generated in 0.20626 seconds
