Home » Modeling » Epsilon » [Epsilon] Re: Eugenia problems
[Epsilon] Re: Eugenia problems [message #342] |
Tue, 16 September 2008 07:03  |
Originally posted by: jendrik.johannes.tu-dresden.de
Hi Dimitrios,
It seems that in the current SVN version some projects are set to 1.6
compliance level (and not to 1.5):
org.eclipse.epsion.eugenia
org.eclipse.epsion.eugenia.runtime
org.eclipse.epsion.hutn.model
org.eclipse.epsion.hutn.model.antlrAst
org.eclipse.epsion.hutn.model.model
changing them to 1.5 removed the first problem.
Now I always get:
Method 'getContainmentReferences' not found (160:38)
Seems like some eol library is not loaded. Any idea where that comes from?
Thanks.
Jendrik
Dimitrios Kolovos wrote:
> Jendrik, Florian,
> I've checked and my compliance level was 1.6 (I forgot to change it in
> Eclipse 3.4 grrrr). However the SVN version is not affected by this and
> it should still work... Just to make this clear, EuGENia has now moved
> to the Eclipse SVN where the rest of Epsilon code is also located
> (http://www.eclipse.org/gmt/epsilon/doc/EpsilonSVN.pdf). Could you
> please confirm that you have the Eclipse SVN version?
> As for affixed nodes, it has to be a containment reference annotated
> with @gmf.affixed
> e.g.
> class Component extends NamedElement {
> @gmf.affixed
> val Port[*]#component ports;
> Would you mind bringing this discussion to the Epsilon newsgroup as it
> may be beneficial for others too?
> Cheers,
> Dimitrios
> Jendrik Johannes wrote:
>> Hi Dimitrios,
>> me and my colleague Florian are both trying to use the latest Eugenia
>> version working. Unfortunately we are not very successful. :) When
>> clicking on "Eugenia > Generate ... Models" we gets this strange and
>> stupid "The chosen operation is not currently available" error. From
>> my expereinces this always happens if some class files are
>> missing/have wrong version. So we it might be some installation error.
>> But it does not work on both our machines. We tried the CVS version
>> and the latest update site version. We are both running OS X, which
>> might be a problem.... maybe something is compiled with Java 6? But
>> then it should work at least with the CVS version... argh. Maybe you
>> have some idea?
>> Another thins is that Florian would like the feature of attaching
>> nodes to the border of a container, which you told me you added. Is
>> that already in the CVS? What is the annotation for that?
>> Thanks for the help. :) Please reply to Florina too.
>> cheers,
>> Jendrik
Re: [Epsilon] Re: Eugenia problems [message #347 is a reply to message #342] |
Tue, 16 September 2008 07:14   |
Hi Jendrik,
Thanks for reporting this. I'll fix it shortly.
Could you please send your metamodel to see if I can reproduce the
second issue?
Dimitrios
> Hi Dimitrios,
> Now I always get:
> Thanks.
> Jendrik
>> Jendrik, Florian,
>> and it should still work... Just to make this clear, EuGENia has now
>> moved to the Eclipse SVN where the rest of Epsilon code is also
>> located (http://www.eclipse.org/gmt/epsilon/doc/EpsilonSVN.pdf). Could
>> you please confirm that you have the Eclipse SVN version?
>> with @gmf.affixed
>> e.g.
>> @gmf.affixed
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> error. But it does not work on both our machines. We tried the CVS
>>> version and the latest update site version. We are both running OS X,
>>> which might be a problem.... maybe something is compiled with Java 6?
>>> But then it should work at least with the CVS version... argh. Maybe
>>> you have some idea?
>>> cheers,
>>> Jendrik
Re: [Epsilon] Re: Eugenia problems [message #352 is a reply to message #347] |
Tue, 16 September 2008 08:25   |
Originally posted by: florian.heidenreich.inf.tu-dresden.de
Hi Dimitrios,
I've uploaded an example metamodel to
http://fheidenreich.de/temp/erm.ecore.zip . After clicking the
'Generate GMF Tool...' menu item, I get an error 'Method 'getLinkLabel'
not found (352:36)' along with this exception
Method 'getLinkLabel' not found (352:36)
org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on(PointExecutor.java:192)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:66)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:36)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:122)
org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(E xecutorFactory.java:184)
org.eclipse.epsilon.eol.execute.AssignExecutor.execute(Assig nExecutor.java:48)
org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te(StatementBlockExecutor.java:25)
org.eclipse.epsilon.eol.execute.ForStatementExecutor.execute (ForStatementExecutor.java:115)
org.eclipse.epsilon.eol.EolModule.execute(EolModule.java:57)
org.eclipse.epsilon.eugenia.EolTransformationActionDelegate. runImpl(EolTransformationActionDelegate.java:77)
for looking into this!
Florian
On 2008-09-16 13:14:10 +0200, Dimitrios Kolovos <dskolovos@gmail.com> said:
> Hi Jendrik,
> second issue?
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> Now I always get:
>> Thanks.
>> Jendrik
>>> Jendrik, Florian,
>>> with @gmf.affixed
>>> e.g.
>>> @gmf.affixed
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> stupid "The chosen operation is not currently available" error. From my
>>>> expereinces this always happens if some class files are missing/have
>>>> wrong version. So we it might be some installation error. But it does
>>>> not work on both our machines. We tried the CVS version and the latest
>>>> update site version. We are both running OS X, which might be a
>>>> problem.... maybe something is compiled with Java 6? But then it should
>>>> work at least with the CVS version... argh. Maybe you have some idea?
>>>> Another thins is that Florian would like the feature of attaching nodes
>>>> to the border of a container, which you told me you added. Is that
>>>> cheers,
>>>> Jendrik
Re: [Epsilon] Re: Eugenia problems [message #357 is a reply to message #352] |
Tue, 16 September 2008 08:35   |
Hi Florian,
I just ran into this issue (and fixed it) this morning as well! An
update from the SVN should resolve this.
Dimitrios
Florian Heidenreich wrote:
> Hi Dimitrios,
> http://fheidenreich.de/temp/erm.ecore.zip . After clicking the 'Generate
> GMF Tool...' menu item, I get an error 'Method 'getLinkLabel' not found
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Cheers,
> Florian
>> Hi Jendrik,
>> second issue?
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> Now I always get:
>>> from?
>>> Thanks.
>>> Jendrik
>>>> Jendrik, Florian,
>>>> in Eclipse 3.4 grrrr). However the SVN version is not affected by
>>>> this and it should still work... Just to make this clear, EuGENia
>>>> has now moved to the Eclipse SVN where the rest of Epsilon code is
>>>> also located
>>>> with @gmf.affixed
>>>> e.g.
>>>> @gmf.affixed
>>>> it may be beneficial for others too?
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>> Eugenia version working. Unfortunately we are not very successful.
>>>>> :) When clicking on "Eugenia > Generate ... Models" we gets this
>>>>> strange and stupid "The chosen operation is not currently
>>>>> available" error. From my expereinces this always happens if some
>>>>> class files are missing/have wrong version. So we it might be some
>>>>> installation error. But it does not work on both our machines. We
>>>>> tried the CVS version and the latest update site version. We are
>>>>> both running OS X, which might be a problem.... maybe something is
>>>>> compiled with Java 6? But then it should work at least with the CVS
>>>>> cheers,
>>>>> Jendrik
Re: [Epsilon] Re: Eugenia problems [message #363 is a reply to message #357] |
Tue, 16 September 2008 09:04   |
Hi Dimitrios,
it works finally -- thanks a lot for the speedy fix and a very helpful
project! :-)
Florian
On 2008-09-16 14:35:18 +0200, Dimitrios Kolovos <dskolovos@gmail.com> said:
> Hi Florian,
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> at
>> at
for
>> looking into this!
>> Cheers,
>> Florian
>>> Hi Jendrik,
>>> second issue?
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> Now I always get:
>>>> Thanks.
>>>> Jendrik
>>>>> Jendrik, Florian,
>>>>> with @gmf.affixed
>>>>> e.g.
>>>>> @gmf.affixed
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi Dimitrios,
>>>>>> cheers,
>>>>>> Jendrik
Re: [Epsilon] Re: Eugenia problems [message #367 is a reply to message #363] |
Tue, 16 September 2008 10:32  |
Glad it helped! If during your GMF editor development you come up with
additional patterns that could be automated with EuGENia please let us know!
Dimitrios
> Hi Dimitrios,
> project! :-)
> Cheers,
> Florian
>> Hi Florian,
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> 'getLinkLabel' not found (352:36)' along with this exception
>>> at
> at
> at
>>> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> for
>>> looking into this!
>>> Cheers,
>>> Florian
>>> said:
>>>> Hi Jendrik,
>>>> second issue?
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>> 1.6 compliance level (and not to 1.5):
>>>>> Now I always get:
>>>>> comes from?
>>>>> Thanks.
>>>>> Jendrik
>>>>>> Jendrik, Florian,
>>>>>> it in Eclipse 3.4 grrrr). However the SVN version is not affected
>>>>>> by this and it should still work... Just to make this clear,
>>>>>> EuGENia has now moved to the Eclipse SVN where the rest of Epsilon
>>>>>> annotated with @gmf.affixed
>>>>>> e.g.
>>>>>> @gmf.affixed
>>>>>> as it may be beneficial for others too?
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi Dimitrios,
>>>>>>> successful. :) When clicking on "Eugenia > Generate ... Models"
>>>>>>> we gets this strange and stupid "The chosen operation is not
>>>>>>> currently available" error. From my expereinces this always
>>>>>>> happens if some class files are missing/have wrong version. So we
>>>>>>> it might be some installation error. But it does not work on both
>>>>>>> our machines. We tried the CVS version and the latest update site
>>>>>>> version. We are both running OS X, which might be a problem....
>>>>>>> maybe something is compiled with Java 6? But then it should work
>>>>>>> Is that already in the CVS? What is the annotation for that?
>>>>>>> cheers,
>>>>>>> Jendrik
Re: [Epsilon] Re: Eugenia problems [message #560792 is a reply to message #342] |
Hi Jendrik,
second issue?
Dimitrios
> Hi Dimitrios,
> Now I always get:
> Thanks.
> Jendrik
>> Jendrik, Florian,
>> with @gmf.affixed
>> e.g.
>> @gmf.affixed
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> you have some idea?
>>> cheers,
>>> Jendrik
Re: [Epsilon] Re: Eugenia problems [message #560803 is a reply to message #347] |
Hi Dimitrios,
Florian
> Hi Jendrik,
> second issue?
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> Now I always get:
>> Thanks.
>> Jendrik
>>> Jendrik, Florian,
>>> with @gmf.affixed
>>> e.g.
>>> @gmf.affixed
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> cheers,
>>>> Jendrik
Re: [Epsilon] Re: Eugenia problems [message #560814 is a reply to message #352] |
Hi Florian,
Dimitrios
> Hi Dimitrios,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> Cheers,
> Florian
>> Hi Jendrik,
>> second issue?
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> Now I always get:
>>> from?
>>> Thanks.
>>> Jendrik
>>>> Jendrik, Florian,
>>>> also located
>>>> with @gmf.affixed
>>>> e.g.
>>>> @gmf.affixed
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>> cheers,
>>>>> Jendrik
Re: [Epsilon] Re: Eugenia problems [message #560825 is a reply to message #357] |
Hi Dimitrios,
project! :-)
Florian
> Hi Florian,
> Cheers,
> Dimitrios
>> Hi Dimitrios,
>> at
>> at
for
>> looking into this!
>> Cheers,
>> Florian
>>> Hi Jendrik,
>>> second issue?
>>> Cheers,
>>> Dimitrios
>>>> Hi Dimitrios,
>>>> Now I always get:
>>>> Thanks.
>>>> Jendrik
>>>>> Jendrik, Florian,
>>>>> with @gmf.affixed
>>>>> e.g.
>>>>> @gmf.affixed
>>>>> Cheers,
>>>>> Dimitrios
>>>>>> Hi Dimitrios,
>>>>>> cheers,
>>>>>> Jendrik
Re: [Epsilon] Re: Eugenia problems [message #560835 is a reply to message #363] |
Dimitrios
> Hi Dimitrios,
> project! :-)
> Cheers,
> Florian
>> Hi Florian,
>> Cheers,
>> Dimitrios
>>> Hi Dimitrios,
>>> at
> at
> at
>>> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks
> for
>>> looking into this!
>>> Cheers,
>>> Florian
>>> said:
>>>> Hi Jendrik,
>>>> second issue?
>>>> Cheers,
>>>> Dimitrios
>>>>> Hi Dimitrios,
>>>>> Now I always get:
>>>>> comes from?
>>>>> Thanks.
>>>>> Jendrik
>>>>>> Jendrik, Florian,
>>>>>> e.g.
>>>>>> @gmf.affixed
>>>>>> Cheers,
>>>>>> Dimitrios
>>>>>>> Hi Dimitrios,
>>>>>>> cheers,
>>>>>>> Jendrik
Current Time: Thu Jul 24 03:38:41 EDT 2025
Powered by FUDForum. Page generated in 0.07661 seconds
