Home » Language IDEs » C / C++ IDE (CDT) » Help with the make process
Help with the make process [message #41449] Tue, 10 September 2002 02:21 Go to next message
Originally posted by: rliu.netfyi.com
I installed MinGW and follow the simple dirctions to make a Hello program
but can't seem to get it working. It keeps having problem make the
makefile. This the message in the "C-Build" (BTW, I'm unable to copy text
in the "C-Build", it would be nice it we can copy text):
make -f makefile clean all
!CBuilder.build_error!
(CreateProcess: make -f makefile clean all error=2)
This is my makefile
objects = HelloWorldC.o
HelloWorldC : $(objects)
C:/MinGW/bin/gcc -o HelloWorldC $(objects) -L
C:/MinGW/lib/gcc-lib/MinGW32/3.2/ -lstdc++
$(objects) : HelloWorldC.cpp
C:/MinGW/bin/gcc -c HelloWorldC.cpp
all :
${MAKE} HelloWorldC
PHONY : clean
clean :
-del HelloWorldC.exe $(objects)
What I'm doing wrong?
Also, initially I had the MinGW in C:\Program Files\Eclipse\MinGW and the
long filename with space seem to cause problem. I had to use the quotes
like "C:\Program Files\...\MinGW\..."
Thanks!
Re: Help with the make process [message #41637 is a reply to message #41449] Wed, 11 September 2002 23:54 Go to previous messageGo to next message
"Raymond Liu" <rliu@netfyi.com> wrote in message
news:alk318$f0a$1@rogue.oti.com...
> Hello,
> This is my makefile
> all :
> ${MAKE} HelloWorldC
> PHONY : clean
> clean :
From the error above, it looks like the CDT is unable to spawn
make on the project. Are you able to run "make" from a
command.com on the project? You need at least make in
the path, or you'll need to manually edit the builder command
(in project->preferences) to specify the full path to make.
That's a good hint. If you install MinGW in a directory with no spaces,
do things work better?
Sebastien
> Thanks!
Re: Help with the make process [message #41694 is a reply to message #41637] Thu, 12 September 2002 17:17 Go to previous messageGo to next message
> > Hello,
> > This is my makefile
> > all :
> > ${MAKE} HelloWorldC
> > PHONY : clean
> > clean :
> Sebastien
> > Thanks!
Raymond Liu wrote:
This is where I'm a bit confuse. I can't seem to find "make.exe" or
"make.com" or "make.bat" in my file system. Is it part of MinGW install?
Or, part of CDT install? Or, am I missing another component?
I did move MinGW to the C:\ root so space should not be a factor any more.
Thanks!
Re: Help with the make process [message #41813 is a reply to message #41694] Fri, 13 September 2002 20:03 Go to previous messageGo to next message
> Thanks!
The make program has a longer filename, then you expect!
It's <MinGW-PATH>\bin\mingw32-make.exe.
Why it's not given another shortname form like the other tools... don't
ask me.
But you can safely rename it to make.exe.
Henning
Re: Help with the make process [message #41839 is a reply to message #41813] Sat, 14 September 2002 11:58 Go to previous messageGo to next message
Raymond wrote:
Thanks! That helped. I was able to manually type in on the command line
to complie the object and then the EXE. However, I'm still having problem
getting CDT to tell the make.exe (which I renamed) to make the EXE. I get
the following:
makefile 4: *** missing separator. Stop.
I think the problem is the example makefile that I got. I don't know a lot
about makefile syntax so I'm not sure what the problem is. Can someone
help? Here is the very simple makefile:
HelloWorldC2 : $(objects)
gcc -o HelloWorldC2 $(objects) -L C:/MinGW/lib/gcc-lib/mingw32/3.2/
-lstdc++
$(objects) : HelloWorldC2.c
gcc -c HelloWorldC2.c
all :
${MAKE} HelloWorldC2
PHONY : clean
clean :
-del HelloWorldC2.exe $(objects)
C-Build puts a red stop icon next to the "${MAKE} HelloWorldC2" line. What
am I doing wrong?
Finally, I can't see find a project setting for CDT for INCLUDE and LIB
and BIN path. Instead, I had to go to the Windows environment setting. Is
there one and I am just not looking in the right place?
Thanks!
Raymond Liu
> > Thanks!
> ask me.
> Henning
Re: Help with the make process [message #41900 is a reply to message #41839] Sat, 14 September 2002 21:58 Go to previous message
> the following:
Generally that means you are missing a hard-tab on line 4. You need to
have a hard-tab before the action for a target.
all:
<HT>some action
If <HT> is a space or a series of spaces then it won't work right.
chris
Chris McKillop <cdm@qnx.com> "The faster I go, the behinder I get."
Software Engineer, QSSL -- Lewis Carroll --
http://qnx.wox.org/
Previous Topic:Open view through action
Next Topic:Extending CDT
Current Time: Tue Jul 15 02:39:55 EDT 2025
Powered by FUDForum. Page generated in 1.27179 seconds
