Home » Eclipse Projects » Mylyn » Re: Plug-in received NumberformatException
Re: Plug-in received NumberformatException [message #41405] Fri, 18 January 2008 09:12 Go to next message
Earnie,
It looks to be related to Mylyn so I've added their newsgroup to the
"to" list of the reply. Perhaps you should exclude the Mylyn plugins
from the plugins being used by your application when it runs (via the
Plug-ins tab of the launch configuration for your application).
Earnie wrote:
> Greetings all,
> I just created my first plug-in project in 3.3.1.1 and when I run it
> inside Eclipse I get receive the following exception. The app loads is
> displayed and appears to work ok just can't figure out why it gets
> this exception. Sometimes the number is "" and sometimes it is in the
> format ".2343e.35236".
> Thanks in advance for any and all help.
> Earnie!
> java.lang.NumberFormatException: For input string: ""
> at java.lang.NumberFormatException.forInputString(Unknown Source)
> at java.lang.Long.parseLong(Unknown Source)
> at java.text.DigitList.getLong(Unknown Source)
> at java.text.DecimalFormat.parse(Unknown Source)
> at java.text.SimpleDateFormat.subParse(Unknown Source)
> at java.text.SimpleDateFormat.parse(Unknown Source)
> at java.text.DateFormat.parse(Unknown Source)
> at
> org.eclipse.mylyn.internal.context.core.SaxContextContentHan dler.createEventFromAttributes(SaxContextContentHandler.java :82)
> at
> org.eclipse.mylyn.internal.context.core.SaxContextContentHan dler.startElement(SaxContextContentHandler.java:62)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDispatcher.dispatch(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
> Source)
> at
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
> Source)
> at
> org.eclipse.mylyn.internal.context.core.SaxContextReader.rea dContext(SaxContextReader.java:59)
> at
> org.eclipse.mylyn.internal.context.core.InteractionContextEx ternalizer.readContextFromXML(InteractionContextExternalizer .java:132)
> at
> org.eclipse.mylyn.internal.context.core.InteractionContextEx ternalizer.readContextFromXML(InteractionContextExternalizer .java:121)
> at
> org.eclipse.mylyn.internal.context.core.InteractionContextMa nager.loadActivityMetaContext(InteractionContextManager.java :140)
> at
> org.eclipse.mylyn.internal.context.core.InteractionContextMa nager.getActivityMetaContext(InteractionContextManager.java: 132)
> at
> org.eclipse.mylyn.internal.context.core.InteractionContextMa nager.processActivityMetaContextEvent(InteractionContextMana ger.java:177)
> at
> org.eclipse.mylyn.internal.monitor.ui.ShellLifecycleListener . <init>(ShellLifecycleListener.java:35)
> at
> org.eclipse.mylyn.monitor.ui.MonitorUiPlugin$2.run(MonitorUi Plugin.java:110)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
> at
> org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
> at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at org.ebsinc.warfighter.Application.start(Application.java:20)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
> java.lang.NumberFormatException: multiple points
> at sun.misc.FloatingDecimal.readJavaFormatString(Unknown Source)
> at java.lang.Double.parseDouble(Unknown Source)
> at java.text.DigitList.getDouble(Unknown Source)
> at
> org.eclipse.mylyn.internal.context.core.SaxContextContentHan dler.createEventFromAttributes(SaxContextContentHandler.java :83)
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> org.eclipse.mylyn.internal.tasks.core.TaskActivityManager.re loadTimingData(TaskActivityManager.java:176)
> at
> org.eclipse.mylyn.tasks.ui.TaskListManager.resetAndRollOver( TaskListManager.java:419)
> at
> org.eclipse.mylyn.tasks.ui.TaskListManager.resetAndRollOver( TaskListManager.java:403)
> at
> org.eclipse.mylyn.tasks.ui.TaskListManager.readExistingOrCre ateNewList(TaskListManager.java:270)
> at
> org.eclipse.mylyn.tasks.ui.TasksUiPlugin.start(TasksUiPlugin .java:353)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
> at
> org.eclipse.core.internal.runtime.InternalPlatform.start(Int ernalPlatform.java:877)
> at
> org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:360)
> at
> org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:340)
> at
> org.eclipse.ui.internal.EarlyStartupRunnable.getPluginForCom patibility(EarlyStartupRunnable.java:149)
> at
> org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:73)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at org.eclipse.ui.internal.Workbench$54.run(Workbench.java:2190 )
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> java.lang.NumberFormatException: empty String
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Plug-in received NumberformatException [message #41470 is a reply to message #41405] Wed, 23 January 2008 00:09 Go to previous message
Originally posted by: beatmik.acm.org
Hi Earnie,
This bug should be fixed in the 2.2 release of Mylyn:
http://www.eclipse.org/mylyn/downloads/
It was not associated with any bad behavior, only an innocuous
interaction event not being correctly restored. If you update and still
see it please comment on the following bug report.
209377: NumberFormatException in log after startup
https://bugs.eclipse.org/bugs/show_bug.cgi?id=209377
Mik
Ed Merks wrote:
> Earnie,
> Earnie wrote:
>> Greetings all,
>> Earnie!
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Plug-in received NumberformatException [message #587125 is a reply to message #41405] Wed, 23 January 2008 00:09 Go to previous message
Hi Earnie,
Mik
Ed Merks wrote:
> Earnie,
> Earnie wrote:
>> Greetings all,
>> Earnie!
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> Source)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:Mylyn Update link
Next Topic:after deactivating issue, working sets broken in navigator
Current Time: Sun Aug 31 02:55:26 EDT 2025
Powered by FUDForum. Page generated in 0.04724 seconds
