Home » Eclipse Projects » Technology Project and PMC » A Tool Variable with no extension
A Tool Variable with no extension [message #41374] Thu, 09 January 2003 13:15 Go to next message
Originally posted by: bbagnall.escape.ca
I'm setting up custom tools in Eclipse and trying to pick out the name of a
file, without using the extension. For example if the filename is 'hello.c',
I'd like the tool arguments to pick out the name 'hello' and drop the file
extension.
I went through all the project variables supplied by Eclipse and none of
them gives this option. Do I need to create a makefile in order to have this
kind of functionality? I'm using Windows, so if there is a way to do this in
a batch file that would also be helpful.
Note: The reason for this is I need to run the compiled binary file using an
emulator. This file has no extension, and uses the same name as the main
source file.
Brian Bagnall
My homepage http://www.mts.net/~bbagnall
Re: A Tool Variable with no extension [message #41406 is a reply to message #41374] Thu, 09 January 2003 17:37 Go to previous message
"Brian Bagnall" <bbagnall@escape.ca> wrote in message
news:avkdcq$lu3$1@rogue.oti.com...
a
'hello.c',
> extension.
this
in
an
> source file.
> Brian Bagnall
You can do this using Windows batch files. The syntax is %~nx where x is the
index of the argument containing the full file name. See the topic "Using
batch parameters" in "Support and help" for more details.
Jonathan Gossage
Re: A Tool Variable with no extension [message #588556 is a reply to message #41374] Thu, 09 January 2003 17:37 Go to previous message
a
'hello.c',
> extension.
this
in
an
> source file.
> Brian Bagnall
Jonathan Gossage
Previous Topic:A Tool Variable with no extension
Next Topic:Testing swt applications.
Current Time: Mon Jun 16 07:38:23 EDT 2025
Powered by FUDForum. Page generated in 0.04307 seconds
