[ATL] How to transform a Model contain in a XML document [message #41329] |
Thu, 24 May 2007 09:47  |
Originally posted by: erik_becker.gmx.de
After having reproduced the Starter Guide I tried to make my own
transformation of a model specified by a normal XML document (no XMI).
And surprise, surprise it unfortunately doesn't work. ;-)
I'm think my problem is that I haven't really understood what I 've to
do with the input XML to be able to read it with ATL Tools.
Here's what I did:
0) Create xml document for model (input.xml)
1) Created a meta model (e.g. input.km3) for the input model / the XML
document with KM3.
2) Produced a Ecore model (e.g. input.ecore) from the KM3
3) Created a meta model for the output model (e.g. output.km3)
4) Produced a Ecore model (e.g. output.ecore) from the KM3
5) Wrote an atl file.
6) Created a 'Lunch Configuration': IN -> input.xml (MM input)
OUT -> output.xml (MM output)
7) Run
I've I do so I get an error message that the transformation failed.
I tried already to 'Inject XML file to XML model' with the input XML.
Now the error message disappeared, but it doesn' t work as well, because
only my called entrypoint rule is executed.
If I understood correct that because now my input XML is in the form of
the XML meta model used in ATL and there a no matching elements found.
Is that right?
What is to do transform a model in XML to another?
What I'm doing wrong?
How do get a ATL readable model form the XML specifying my model?
Thanks & Regards
Erik
Re: [ATL] How to transform a Model contain in a XML document [message #41391 is a reply to message #41329] |
Thu, 24 May 2007 10:05   |
.... yet ;-).
Yes, it seems so. But you seem to have understood the problem (i.e.,
injecting an XML document results in a model conforming to the XML
metamodel). You just have not found the solution yet. But your are
lucky: I am giving it to you below ;-).
> Here's what I did:
> document with KM3.
> 7) Run
This is normal, because the launch configuration only lets you use XMI
files as input.
BTW, I was wondering what a "Lunch Configuration" could be. Is this a
menu that you find in a restaurant? ;-)
> Is that right?
Exactly. Your injected XMI file contains a model conforming to the XML
metamodel.
You just need to write an ATL transformation ;-).
For instance:
module XML2MyMM;
create OUT : MyMM from IN : XML;
rule Test {
from
s : XML!Element (
s.name = 'test'
to
t : MyMM!Test (
name <- s.getAttrVal('name')
where getAttrVal would be a helper that gets the value of an attribute
of an XML!Element.
The following Howto entry highlights the main points and links to
examples about dealing with XML files:
http://wiki.eclipse.org/index.php/ATL_Howtos#How_can_I_handl e_arbitrary_XML_documents.3F
Please, feel free to contribute to it if you feel it is not detailed
enough yet ;-).
Frédéric Jouault
Re: [ATL] How to transform a Model contain in a XML document [message #41794 is a reply to message #41598] |
Fri, 25 May 2007 11:01  |
Hi Erik,
I would suggest that you have a look at the XML2CPL.atl transformation
in the Telephony DSLs ATL use case
(http://www.eclipse.org/m2m/atl/usecases/DSLsTelephony/).
This transformation does create nested structures in the target
metamodel from a source XML model.
Let us know if you still have questions after that.
Frédéric Jouault
Erik Becker wrote:
> Hi Frédéric,
> thanks for your answer. Unfortunately it's not that easy as hoped.
> The XML document I want to transform is nested and quite complex.
> I decided to transform its as instance of the XML meta model instead to
> transform it first into 'My meta model', but this is really difficult.
> Isn't there another possibility to get a ATL-readable version of a XML
> document?
> While my explorations I encountered some problems:
> 1) I want to create a structure in my target model which is like this:
> <Package ..>
> <WorkflowProcesses>
> <WorkflowProcess ...> </WorkflowProcess>
> </WorkflowProcesses>
> </Package>
> I thought if I bind WorkflowProcess elements to a reference
> WorkflowProcess this would work. Unfortunately it don't. I get something
> like this ...
> <Package ..>
> <WorkflowProcesses ..> </WorkflowProcesses>
> </Package>
> 2) As you my already know I create an instance of the XPDL MM form the
> Atlantic zoo. The output of my transformation looks like this:
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <Package xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
> xmlns="XPDL" ..>
> </Package>
> I expected to receive something like this:
> <xmi xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns="XPDL">
> <Package ..>
> </Package>
> Additionally I get an empty XML document if I use the XML extractor to
> create a XML form my traget model. What I'm doing wrong?
> Thanks and Greetings
> Erik
FUDForum. Page generated in 0.03692 seconds
