Home » Eclipse Projects » DTP » access DTP connection profiles
access DTP connection profiles [message #41308] Thu, 07 February 2008 09:57 Go to next message
Originally posted by: c.sell.NOSPAM.byterefinery.de
I am developing a database modeling tool which currently maintains its own
connection data. now I would like to integrate with DTP in such a way that
DTP connection profiles can be used for export/import purposes as well.
To achieve that, I would create an adapter plugin (dependencies on both
DTP and my plugin) from where I would read the DTP connection profile
information and adapt it to the needs of my tool.
Now comes the question: Can someone tell me how to access the currently
defined DTP connection profiles, and how to read database metadata through
such a profile?
thanks,
Christian
Re: access DTP connection profiles [message #41340 is a reply to message #41308] Thu, 07 February 2008 11:00 Go to previous messageGo to next message
Originally posted by: brianf.sybase.com
Hi Christian...
You bet. This sounds like a cool tool. :)
As for how to get at the profile metadata, if you have DTP installed, you
have a plug-in called org.eclipse.datatools.connectivity. This has a class
in it called org.eclipse.datatools.connectivity.ProfileManager. From here,
you can get a list of existing connection profiles and then start fiddling
with their metadata.
Something like this will get you a list of database-related profiles:
IConnectionProfile[] databaseProfiles =
ProfileManager.getProfilesByCategory("org.eclipse.datatools.connectivity.db.category ");
From there, I'd take a look at the
org.eclipse.datatools.connectivity.drivers.jdbc.JDBCConnecti on class and
specifically it's createConnection (ClassLoader) method. You won't
necessarily need the classloader aspects of it, but it shows how to get the
various details out of a db profile needed to make a JDBC connection.
Hope that helps get you started. If you have more questions, don't hesitate
to ask.
--Fitz
Brian Fitzpatrick
Sybase, Inc.
Sr. Software Engineer
Data Tools Project Connectivity Team Lead/Committer
"Christian Sell" <c.sell@NOSPAM.byterefinery.de> wrote in message
news:8854a19b3fd0658244341dbde3fc2489$1@www.eclipse.org...
> Hello,
> such a profile?
> thanks,
> Christian
Re: access DTP connection profiles [message #41369 is a reply to message #41340] Thu, 07 February 2008 12:24 Go to previous messageGo to next message
Hello Brian,
yes, I thought I'd create something reaally unique ;)
ot that. However, how can I be sure that the profiles returned here are
compatible with the JDBCConnectionFactory class?
it seems to me that your package reference is wrong.. I can only find a
JDBCConnection class in the org.eclipse.datatools.connectivity.db.generic
package. That class is marked as NON-API, however..
thanks,
Christian
Re: access DTP connection profiles [message #41400 is a reply to message #41369] Thu, 07 February 2008 12:49 Go to previous messageGo to next message
Everything in the Database category SHOULD conform to the
JDBCConnectionFactory class and everything should extend that. If you want
DTP to simply hand you a JDBC connection, you can get a profile and then
call:
myprofile.createConnection("java.sql.Connection");
which will give you an IConnection. Once you have the connection, you can
get the raw connection and see if that's a java.sql.Connection and just use
the connection itself.
The JDBCConnection class I'm looking at is in the
org.eclipse.datatools.connectivity.drivers.jdbc package of the
org.eclipse.datatools.connectivity plug-in. The one in the Generic JDBC
plug-in extends that.
--Fitz
news:1509284840dc37253b4ea77c3c758bd4$1@www.eclipse.org...
> Hello Brian,
>> class in it called org.eclipse.datatools.connectivity.ProfileManager.
>> From here, you can get a list of existing connection profiles and then
>> start fiddling with their metadata.
>> the various details out of a db profile needed to make a JDBC connection.
> thanks,
> Christian
Re: access DTP connection profiles [message #41429 is a reply to message #41400] Tue, 12 February 2008 08:56 Go to previous messageGo to next message
we seem to be looking at different codebases. The class I am looking at is
org.eclipse.datatools.connectivity.db.generic.JDBCConnection . It extends
org.eclipse.datatools.connectivity.DriverConnectionBase. And its marked as
NON-API
thanks,
Christian
Re: access DTP connection profiles [message #41459 is a reply to message #41429] Tue, 12 February 2008 16:22 Go to previous message
Hi Christian...
Even in the 1.5 stream, there's still a base JDBCConnection class in the
org.eclipse.datatools.connectivity plug-in and then the one in the generic
JDBC plug-in extends that.
Here's the class definition for
org.eclipse.datatools.connectivity.db.generic.JDBCConnection in
org.eclipse.datatools.connectivity.db.generic:
public class JDBCConnection extends
org.eclipse.datatools.connectivity.drivers.jdbc.JDBCConnecti on in
org.eclipse.datatools.connectivity:
public class JDBCConnection extends DriverConnectionBase
If you'd like to use a JDBCConnection class, I recommend you use the latter,
not the former.
Hope that helps clarify a bit.
--Fitz
news:0e339574644c60ca3474b9e091dc8c47$1@www.eclipse.org...
> NON-API
> thanks,
> Christian
Re: access DTP connection profiles [message #589866 is a reply to message #41308] Thu, 07 February 2008 11:00 Go to previous message
Hi Christian...
to ask.
--Fitz
Brian Fitzpatrick
Sybase, Inc.
> Hello,
> such a profile?
> thanks,
> Christian
Re: access DTP connection profiles [message #589883 is a reply to message #41340] Thu, 07 February 2008 12:24 Go to previous message
Hello Brian,
thanks,
Christian
Re: access DTP connection profiles [message #589893 is a reply to message #41369] Thu, 07 February 2008 12:49 Go to previous message
call:
--Fitz
> Hello Brian,
> thanks,
> Christian
Re: access DTP connection profiles [message #589905 is a reply to message #41400] Tue, 12 February 2008 08:56 Go to previous message
NON-API
thanks,
Christian
Re: access DTP connection profiles [message #589915 is a reply to message #41429] Tue, 12 February 2008 16:22 Go to previous message
Hi Christian...
not the former.
--Fitz
> NON-API
> thanks,
> Christian
Previous Topic:access DTP connection profiles
Next Topic:Thanks for all the DTP Usability Comments!
Current Time: Fri Jul 18 01:24:47 EDT 2025
Powered by FUDForum. Page generated in 2.07844 seconds
