Home » Archived » BIRT » API document about chart engine
API document about chart engine [message #41182] Wed, 25 May 2005 21:46 Go to next message
Originally posted by: comtodrn.163.com
I want paint a pie chart in my RCP application with birt'chart engine,but
in birt's web site ,I don't found any API document about chart engine,
anyone can help me?
drnstar
Re: API document about chart engine [message #41213 is a reply to message #41182] Thu, 26 May 2005 02:11 Go to previous messageGo to next message
Originally posted by: Michel.lehon.gmail.com
Check out the FAQ of BIRT at
http://www.eclipse.org/birt/faq/
on the left side you have 2 sections about charts.
Whild the information is far from complete... it provides a starting point.
Michel.
Re: API document about chart engine [message #41276 is a reply to message #41213] Thu, 26 May 2005 03:47 Go to previous messageGo to next message
Thank Michel,
I found it ,but it is not enough ,whithout API document,I don't know how
to invoke chart engine
drnstar
Re: API document about chart engine [message #41306 is a reply to message #41276] Thu, 26 May 2005 12:39 Go to previous messageGo to next message
Hi Drnstar,
You could generate the public javadoc API for the chart engine as follows:
A] Download the source for the chart plug-ins (as defined in the FAQ)
B] Invoke the 'BuildChartEngine.xml' ant script with the 'JavaDoc' target
Also, refer to the following posts for additional info:
http://www.eclipse.org/newsportal/article.php?id=710&gro up=eclipse.birt#710
http://www.eclipse.org/newsportal/article.php?id=853&gro up=eclipse.birt#853
Hope that helps.
- Rohit
Subject: Re: API document about chart engine
Newsgroups: eclipse.birt
Organization: EclipseCorner
Date: May 26 2005 02:47:42
Thank Michel,
how
drnstar
Re: API document about chart engine [message #41494 is a reply to message #41306] Thu, 26 May 2005 20:22 Go to previous messageGo to next message
Thanks Rohit,
I'll try it.
Drnstar
Re: API document about chart engine [message #45323 is a reply to message #41494] Mon, 13 June 2005 17:13 Go to previous message
The Chart API is also now available in the release 1 BIRT documentation. Go
to Help->Help Contents, then BIRT Developer Guide->Reference. You will find
all the public API there.
Jane Tatchell
BIRT documentation lead
"Drnstar dh" <comtodrn@163.com> wrote in message
news:d75pm7$adb$1@news.eclipse.org...
> Thanks Rohit,
> I'll try it.
> Drnstar
Previous Topic:Setting Table invisible if no records found
Next Topic:report generation, and serialization
Current Time: Sat Jul 26 12:38:18 EDT 2025
Powered by FUDForum. Page generated in 0.05582 seconds
