Home » Archived » Visual Editor (VE) » Can't create Visual Classes
Can't create Visual Classes [message #41169] Thu, 10 June 2004 16:52 Go to next message
Originally posted by: thomasnagashima.hotmail.com
Whenever I try to create a visual class I get the following:
Attempted to beginRule: F/<project path>, does not match
outer scope rule: L/<project path>/TestFrame.java
Any ideas what this means?
I've tried with M8 and all the corresponding EMF, GEF and VE.
I've also tried with latest integration builds and what they
said they required.
Thanks.
Re: Can't create Visual Classes [message #41200 is a reply to message #41169] Thu, 10 June 2004 17:58 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
Please list exactly what versions of Eclipse,GEF,EMF,and VE you have.
This had occurred on one of the previous drivers.
Thanks, Rich Kulp
Re: Can't create Visual Classes [message #41231 is a reply to message #41200] Fri, 11 June 2004 15:46 Go to previous messageGo to next message
I've tried two setups. First, Eclipse M8, VE 1.0RC1, GEF I20040330, and
EMF I200403250631. These are the ones specified by VE 1.0RC1.
I did see someone say if they got the latest integration builds it worked.
So used the latest Eclipse integration and all the corresponding
integration builds for GEF and EMF and VE.
So no luck with either.
Re: Can't create Visual Classes [message #41354 is a reply to message #41200] Mon, 14 June 2004 03:52 Go to previous messageGo to next message
The same happened to me:
Eclipse RC1
VE-runtime-1.0M1
GEF-runtime-I20040610
emf-sdo-runtime-I200406100948
Frank Senn
Re: Can't create Visual Classes [message #41385 is a reply to message #41354] Mon, 14 June 2004 09:06 Go to previous messageGo to next message
Frank,
VE-runtime-1.0M1 does not run under Eclipse RC1 - only Eclipse M8.
Please download the latest Integration build of VE and that build's
required versions of GEF and EMF and it should work fine.
- Jeff
> Eclipse RC1
> VE-runtime-1.0M1
> Frank Senn
Re: Can't create Visual Classes [message #44725 is a reply to message #41385] Mon, 28 June 2004 16:56 Go to previous messageGo to next message
Originally posted by: agaba.compuflex.hu
> Frank,
> - Jeff
eclipse-SDK-3.0-linux-gtk.zip
VE-runtime-1.0M1.zip
emf-sdo-runtime-I200406241017.zip
GEF-runtime-I20040624.zip
And I removed the reference to xerces from:
eclipse/features/com.ibm.wtp.emf.integration.core_1.0.0
Thank you for your help in advance
Agaba
Re: Can't create Visual Classes [message #44760 is a reply to message #44725] Mon, 28 June 2004 17:45 Go to previous messageGo to next message
Agaba írta:
>> Frank,
>> - Jeff
> Agaba
I tried the above mentioned too.
It stops when I want to create a visual class with the following error:
The selected wizard could not be started.
Reason:
Plug-in org.eclipse.ve.java.core was unable to load
org.eclipse.ve.internal.java.codegen.wizards.NewVisualClassC reationWizard.
installed files:
GEF-runtime-3.0.zip
VE-runtime-S20040628.zip
emf-sdo-runtime-2.0.0.zip
xsd-runtime-2.0.0.zip
Thank you
Agaba
Re: Can't create Visual Classes [message #44873 is a reply to message #44760] Tue, 29 June 2004 08:42 Go to previous messageGo to next message
Agaba,
Try removing the configuration directory in your eclipse directory. If
that doesn't fix it, please post the contents of the .log file in the
..metadata directory in your workspace.
- Jeff
> Reason:
> installed files:
> GEF-runtime-3.0.zip
> Thank you
> Agaba
Re: Can't create Visual Classes [message #45025 is a reply to message #44873] Tue, 29 June 2004 19:17 Go to previous message
Thank you for your help,
it's working! ( removing the configuration helped )
Agaba
Jeff Myers írta:
> Agaba,
> - Jeff
>> Reason:
>> installed files:
>> GEF-runtime-3.0.zip
>> Thank you
>> Agaba
Re: Can't create Visual Classes [message #591693 is a reply to message #41169] Thu, 10 June 2004 17:58 Go to previous message
Thanks, Rich Kulp
Re: Can't create Visual Classes [message #591707 is a reply to message #41200] Fri, 11 June 2004 15:46 Go to previous message
Re: Can't create Visual Classes [message #591744 is a reply to message #41200] Mon, 14 June 2004 03:52 Go to previous message
Eclipse RC1
VE-runtime-1.0M1
Frank Senn
Re: Can't create Visual Classes [message #591761 is a reply to message #41354] Mon, 14 June 2004 09:06 Go to previous message
Frank,
- Jeff
> Eclipse RC1
> VE-runtime-1.0M1
> Frank Senn
Re: Can't create Visual Classes [message #593019 is a reply to message #41385] Mon, 28 June 2004 16:56 Go to previous message
> Frank,
> - Jeff
Agaba
Re: Can't create Visual Classes [message #593033 is a reply to message #44725] Mon, 28 June 2004 17:45 Go to previous message
Agaba írta:
>> Frank,
>> - Jeff
> Agaba
Reason:
installed files:
GEF-runtime-3.0.zip
Thank you
Agaba
Re: Can't create Visual Classes [message #593073 is a reply to message #44760] Tue, 29 June 2004 08:42 Go to previous message
Agaba,
- Jeff
> Reason:
> installed files:
> GEF-runtime-3.0.zip
> Thank you
> Agaba
Re: Can't create Visual Classes [message #593144 is a reply to message #44873] Tue, 29 June 2004 19:17 Go to previous message
Agaba
Jeff Myers írta:
> Agaba,
> - Jeff
>> Reason:
>> installed files:
>> GEF-runtime-3.0.zip
>> Thank you
>> Agaba
Previous Topic:copy and paste doesn't work after installing VE
Next Topic:why wont the selectionchanged method work without invokiing tthe plugin?
Current Time: Sun Aug 31 02:52:52 EDT 2025
Powered by FUDForum. Page generated in 0.05782 seconds
