Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Build, P2 Metadata and Target Platform Problems
PDE Build, P2 Metadata and Target Platform Problems [message #41087] Mon, 19 January 2009 20:30 Go to next message
Originally posted by: jconlon.apache.org
Had been stuck for while on a problem with building my RCP features
based app with PDE Build to include p2 metadata. The setup is based on
Andrew Niefer's Example Headless build for a RCP product with p2 @
http://aniefer.blogspot.com/2008/06/example-headless-build-f or-rcp-product.html
While I got Andrew's demo working with no problem I could not get my
features based RCP product built by the Headless Director
(org.eclipse.equinox.p2.director.app.application to create
zips of the product that contain P2 metadata.)
Here is the exception I kept getting:
[java] Time to load bundles: 38
[java] Starting application: 43688
[java] !SESSION 2009-01-19 09:49:40.096
[java] eclipse.buildId=M20080911-1700
[java] java.version=1.6.0_05
[java] java.vendor=Sun Microsystems Inc.
[java] BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
[java] Framework arguments: --launcher.suppressErrors
-application org.eclipse.equinox.p2.director.app.application -flavor
tooling -installIU com.verticon.tracker.editor.Tracker -version
0.3.1.v200901190943 -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming
-profileProperties org.eclipse.update.install.features=true -profile
TrackerProfile -metadataRepository
file:/home/jconlon/eclipse-workspaces/tracker-TRUNK/com.vert icon.tracker.builder/buildDirectory/repo
-artifactRepository
-destination
/home/jconlon/eclipse-workspaces/tracker-TRUNK/com.verticon. tracker.builder/buildDirectory/result/tmp/eclipse
-bundlepool
[java] Command-line arguments: -clean -consoleLog -debug
--launcher.suppressErrors -application
org.eclipse.equinox.p2.director.app.application -flavor tooling
-installIU com.verticon.tracker.editor.Tracker -debug -consoleLog
-version 0.3.1.v200901190943 -p2.os win32 -p2.ws win32 -p2.arch x86
-roaming -profileProperties org.eclipse.update.install.features=true
-profile TrackerProfile -metadataRepository
-artifactRepository
-destination
-bundlepool
[java]
[java] !ENTRY org.eclipse.equinox.p2.metadata.repository 2 0
2009-01-19 09:51:57.823
[java] !MESSAGE Error parsing metadata repository
[java] !SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-01-19
09:51:57.823
[java] !MESSAGE Error at line 10, column 91: Missing required
attribute in "repository": url
09:51:57.824
[java] !MESSAGE Error at line 10, column 91: Illegal value for
attribute "url" of element "repository": null
09:51:57.824
[java] !MESSAGE Error at line 11, column 91: Missing required
09:51:57.824
[java] !MESSAGE Error at line 11, column 91: Illegal value for
09:51:57.824
[java] !MESSAGE Error at line 12, column 90: Missing required
09:51:57.824
[java] !MESSAGE Error at line 12, column 90: Illegal value for
09:51:57.825
[java] !MESSAGE Error at line 13, column 90: Missing required
09:51:57.825
[java] !MESSAGE Error at line 13, column 90: Illegal value for
[java] Installing com.verticon.tracker.editor.Tracker
0.3.1.v200901190943.
[java] Installation failed.
[java]
[java] !ENTRY org.eclipse.equinox.p2.engine 4 4 2009-01-19
09:53:34.418
[java] !MESSAGE An error occurred while collecting items to be
installed
[java] !SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 0
2009-01-19 09:53:34.419
[java] !MESSAGE Problems downloading artifact:
osgi.bundle,org.eclipse.platform,3.3.101.v200809111700.
[java] !SUBENTRY 2 org.eclipse.core.runtime 0 0 2009-01-19
09:53:34.419
[java] !MESSAGE OK
[java] !SUBENTRY 2 org.eclipse.equinox.p2.artifact.repository 4 4
[java] !MESSAGE File has invalid content: /tmp/signatureFile17624.jar
[java] !SUBENTRY 3 org.eclipse.equinox.p2.artifact.repository 4 0
[java] !MESSAGE Invalid content: plugin_customization.ini
[java] !STACK 0
[java] org.eclipse.osgi.signedcontent.InvalidContentException: The
file "plugin_customization.ini" in the jar "/tmp/signatureFile17624.jar"
has been tampered!
[java] at
org.eclipse.osgi.internal.signedcontent.DigestedInputStream. verifyDigests(DigestedInputStream.java:102)
[java] at
org.eclipse.osgi.internal.signedcontent.DigestedInputStream. read(DigestedInputStream.java:129)
[java] at
org.eclipse.osgi.baseadaptor.bundlefile.BundleEntry.getBytes (BundleEntry.java:102)
[java] at
org.eclipse.osgi.internal.signedcontent.SignedContentImpl$Si gnedContentEntryImpl.verify(SignedContentImpl.java:167)
[java] at
org.eclipse.osgi.internal.signedcontent.SignedContentFile.ge tSignedEntries(SignedContentFile.java:51)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.Signatur eVerifier.verifyContent(SignatureVerifier.java:82)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.Signatur eVerifier.verify(SignatureVerifier.java:59)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.Signatur eVerifier.close(SignatureVerifier.java:100)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.reportStatus(SimpleArtifactRepositor y.java:815)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.downloadArtifact(SimpleArtifactRepos itory.java:442)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:515)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transferSingle(MirrorRequest.java:162)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transfer(MirrorRequest.java:146)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.perform(MirrorRequest.java:94)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:504)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.simple.D ownloadJob.run(DownloadJob.java:64)
[java] at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
09:53:34.421
[java] !MESSAGE OK
[java] Java Result: 13
Got similar errors from the Admin UI when I pointed it at the repo I
created with PDE Build above:
An error occurred while collecting items to be installed
File has invalid content: /tmp/signatureFile9067.jar
The file "plugin_customization.ini" in the jar
"/tmp/signatureFile9067.jar" has been tampered!
Was able to cause Andrew's demo to fail in similar ways by adding the
org.eclipse.platform plugin to the product configuration.
Searching the bugzilla I noticed the similarity with
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241596
but because I have very little debug or diagnostic messages I had to
grope in the dark to fix this.
My last grope was successful - I created a fresh target platform from
3.4.1 EMF-all-in-one, RCP-delta-pack, and a handful of Equinox plugins
that were required by the product.
Since I would hate to have anyone else have to go through this hassle
and am still in the dark on what caused it - Does anyone have any
ideas, and/or suggestions on what might have been happening? Any
troubleshooting techniques for dealing with similar p2 problems would
also be helpful.
thanks for any ideas,
John
Re: PDE Build, P2 Metadata and Target Platform Problems [message #41185 is a reply to message #41087] Tue, 20 January 2009 12:12 Go to previous messageGo to next message
So, org.eclipse.platform,3.3.101.v200809111700 is failing signature
verification. You basically want to identify where the "corruption" is
being introduced.
In general, to track down this kind of verification error, you want to
run "jarsigner -verify" on the jars in several locations:
1) The jar in your repository
(buildDirectory/repo/plugins/org.eclipse.platform_3.3.101.v2 00809111700.jar)
2) The jar in the output of the build. (in the example this is
Builder/I.TestBuild/TestBuild-win32.win32.x86.zip
3) The input to the build, ie baseLocation
if (1) passes, then I guess there is a bug in p2 install somewhere
if (2) passes and (1) failed, the bug is in p2 metadata generation.
if (3) passes and (2) failed, the bug is in pde.build
if (3) fails, your input files are corrupt, where did you get them from?
were they ever modified?
Since creating a fresh target fixed things for you, I expect the last
case, somehow the input files got corrupted.
In this particular case, this is complicated by org.eclipse.platform
being a folder shaped bundle, so (2) and (3) both are folders.
jarsigner doesn't verify folders. You can try zipping them into jars
and verifying that. Or, org.eclipse.osgi has experimental API that can
verify folders, so you could write a small tool using
CertificateVerifierFactory. (See as an example
org.eclipse.pde.build.tests/PDETestCase#assertJarVerifies)
-Andrew
> [java] Framework arguments: --launcher.suppressErrors -application
> -artifactRepository
> -destination
> -bundlepool
> -artifactRepository
> -destination
> -bundlepool
> [java]
> 09:51:57.823
> 09:51:57.824
> 09:51:57.824
> 09:51:57.824
> 09:51:57.824
> 09:51:57.824
> 09:51:57.825
> 09:51:57.825
> [java]
> 09:53:34.418
> installed
> 09:53:34.419
> [java] !MESSAGE OK
> [java] !STACK 0
> has been tampered!
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> 09:53:34.421
> [java] !MESSAGE OK
> also be helpful.
> John
Re: PDE Build, P2 Metadata and Target Platform Problems [message #41278 is a reply to message #41185] Tue, 20 January 2009 14:55 Go to previous messageGo to next message
Hi Andrew,
See inline comments...
> being introduced.
Yes, this is the idea I have been exploring (aka groping) as well.
Before I go further I should point out that to try the tests you
suggested I first attempted to get the thing to fail again.
Unfortunately changing the target platform back to the original one I
first experienced the failures in no longer fails. Ugh! (I failed to
fail so to speak.) Nevertheless...
Have noticed all along that this plugin was a jar and that it failed
verification. And even when the director succeeds in extracting a
product from the repository (like in todays tests) this jar fails to
verify...
[echo] verifying
/home/jconlon/eclipse-workspaces/ganymeade1/Builder/repo/plu gins/org.eclipse.platform_3.3.101.v200809111700.jar
[exec] jarsigner: java.lang.SecurityException: SHA1 digest error
for plugin_customization.ini
In the output zip the org.eclipse.platform_3.3.101.v200809111700 is not
a jar it's a folder.
Here too org.eclipse.platform_3.3.101.v200809111700 in the baseLocation
(my targetPlatform) is a folder.
4) Let me add a fourth test - the result zip from a successful director
extraction.
Here too org.eclipse.platform_3.3.101.v200809111700 is a folder
Results -
(1) failed to verify!
(2) a folder - testing after rejaring validation passes
(3) folder - testing after rejaring validation passes
(4) folder - testing after rejaring validation passes
I hoped this was the case too, but things appear to be more convoluted,
as mentioned above my old targetPlatform now seems to work. It also
has/had a good folder in it.
> being a folder shaped bundle, so (2) and (3) both are folders. jarsigner
> doesn't verify folders. You can try zipping them into jars and
> verifying that.
As mentioned above I rejared and verified.
Questions:
So Why is the repo jaring up the platform folder? (1)
Why is it corrupting the jar in the process? (1)
And if the repo has a broken platform plugin jared where is the
resulting product created by the director getting the good folder to put
in the result? (4)
Or why doesn't the director now NOT fail with a bad jar in the repo?
Aren't there any diagnostic messages that can log what is going on with
the P2 and the director??
thanks for all your help,
John
> -Andrew
>> on Andrew Niefer's Example Headless build for a RCP product with p2 @
>> -artifactRepository
>> -destination
>> -bundlepool
>> -artifactRepository
>> -destination
>> -bundlepool
>> [java]
>> 09:51:57.823
>> 09:51:57.824
>> 09:51:57.824
>> 09:51:57.824
>> 09:51:57.824
>> 09:51:57.824
>> 09:51:57.825
>> 09:51:57.825
>> [java]
>> 09:53:34.418
>> installed
>> 09:53:34.419
>> [java] !MESSAGE OK
>> [java] !STACK 0
>> "/tmp/signatureFile17624.jar" has been tampered!
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> 09:53:34.421
>> [java] !MESSAGE OK
>> also be helpful.
>> John
Re: PDE Build, P2 Metadata and Target Platform Problems [message #41372 is a reply to message #41278] Wed, 21 January 2009 14:24 Go to previous messageGo to next message
Although I was able to build my product from the repo, I can't do it
from an AdminUI without getting:
File has invalid content: /tmp/signatureFile55296.jar
"/tmp/signatureFile55296.jar" has been tampered!
thanks,
John
> Hi Andrew,
>> is being introduced.
> verify...
> [echo] verifying
> extraction.
>> from? were they ever modified?
> Results -
>> and verifying that.
> Questions:
> in the result? (4)
> John
>> -Andrew
>>> -artifactRepository
>>> -destination
>>> -bundlepool
>>> -artifactRepository
>>> -destination
>>> -bundlepool
>>> [java]
>>> 09:51:57.823
>>> 09:51:57.824
>>> 09:51:57.824
>>> 09:51:57.824
>>> 09:51:57.824
>>> 09:51:57.824
>>> 09:51:57.825
>>> 09:51:57.825
>>> [java]
>>> 09:53:34.418
>>> installed
>>> 0 2009-01-19 09:53:34.419
>>> 09:53:34.419
>>> [java] !MESSAGE OK
>>> 4 2009-01-19 09:53:34.419
>>> [java] !STACK 0
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> 09:53:34.421
>>> [java] !MESSAGE OK
>>> plugins that were required by the product.
>>> also be helpful.
>>> John
Re: PDE Build, P2 Metadata and Target Platform Problems [message #41436 is a reply to message #41372] Wed, 21 January 2009 19:08 Go to previous message
This seems to be related to the other repository I had configured in the
Admin UI - http://download.eclipse.org/eclipse/updates/3.4.x
When I remove it and add a local repository ( a locally installed
Eclipse 3.4.1 SDK) to the the Admin UI, the product now installs in
Profiles.
So is the org.eclipse.platform in the
http://download.eclipse.org/eclipse/updates/3.4.x corrupt?
BTW - I can't add the
to my Admin UI for some reason??
thanks for any help or insights,
John
> thanks,
> John
>> Hi Andrew,
>>> to run "jarsigner -verify" on the jars in several locations:
>> verify...
>> [echo] verifying
>> not a jar it's a folder.
>> baseLocation (my targetPlatform) is a folder.
>> director extraction.
>> Results -
>> convoluted, as mentioned above my old targetPlatform now seems to
>> work. It also has/had a good folder in it.
>>> and verifying that.
>> Questions:
>> put in the result? (4)
>> with the P2 and the director??
>> John
>>> -Andrew
>>>> -artifactRepository
>>>> -destination
>>>> -bundlepool
>>>> -artifactRepository
>>>> -destination
>>>> -bundlepool
>>>> [java]
>>>> 09:51:57.823
>>>> 09:51:57.824
>>>> 09:51:57.824
>>>> 09:51:57.824
>>>> 09:51:57.824
>>>> 09:51:57.824
>>>> 09:51:57.825
>>>> 09:51:57.825
>>>> [java]
>>>> 09:53:34.418
>>>> installed
>>>> 09:53:34.419
>>>> [java] !MESSAGE OK
>>>> [java] !STACK 0
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> 09:53:34.421
>>>> [java] !MESSAGE OK
>>>> the org.eclipse.platform plugin to the product configuration.
>>>> from 3.4.1 EMF-all-in-one, RCP-delta-pack, and a handful of Equinox
>>>> hassle and am still in the dark on what caused it - Does anyone
>>>> have any ideas, and/or suggestions on what might have been
>>>> happening? Any troubleshooting techniques for dealing with similar
>>>> p2 problems would also be helpful.
>>>> John
Re: PDE Build, P2 Metadata and Target Platform Problems [message #588489 is a reply to message #41087] Tue, 20 January 2009 12:12 Go to previous message
being introduced.
-Andrew
> -artifactRepository
> -destination
> -bundlepool
> -artifactRepository
> -destination
> -bundlepool
> [java]
> 09:51:57.823
> 09:51:57.824
> 09:51:57.824
> 09:51:57.824
> 09:51:57.824
> 09:51:57.824
> 09:51:57.825
> 09:51:57.825
> [java]
> 09:53:34.418
> installed
> 09:53:34.419
> [java] !MESSAGE OK
> [java] !STACK 0
> has been tampered!
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> 09:53:34.421
> [java] !MESSAGE OK
> also be helpful.
> John
Re: PDE Build, P2 Metadata and Target Platform Problems [message #588519 is a reply to message #41185] Tue, 20 January 2009 14:55 Go to previous message
Hi Andrew,
> being introduced.
verify...
[echo] verifying
extraction.
Results -
> verifying that.
Questions:
in the result? (4)
John
> -Andrew
>> -artifactRepository
>> -destination
>> -bundlepool
>> -artifactRepository
>> -destination
>> -bundlepool
>> [java]
>> 09:51:57.823
>> 09:51:57.824
>> 09:51:57.824
>> 09:51:57.824
>> 09:51:57.824
>> 09:51:57.824
>> 09:51:57.825
>> 09:51:57.825
>> [java]
>> 09:53:34.418
>> installed
>> 09:53:34.419
>> [java] !MESSAGE OK
>> [java] !STACK 0
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> 09:53:34.421
>> [java] !MESSAGE OK
>> also be helpful.
>> John
Re: PDE Build, P2 Metadata and Target Platform Problems [message #588547 is a reply to message #41278] Wed, 21 January 2009 14:24 Go to previous message
thanks,
John
> Hi Andrew,
> verify...
> [echo] verifying
> extraction.
> Results -
>> and verifying that.
> Questions:
> in the result? (4)
> John
>> -Andrew
>>> -artifactRepository
>>> -destination
>>> -bundlepool
>>> -artifactRepository
>>> -destination
>>> -bundlepool
>>> [java]
>>> 09:51:57.823
>>> 09:51:57.824
>>> 09:51:57.824
>>> 09:51:57.824
>>> 09:51:57.824
>>> 09:51:57.824
>>> 09:51:57.825
>>> 09:51:57.825
>>> [java]
>>> 09:53:34.418
>>> installed
>>> 09:53:34.419
>>> [java] !MESSAGE OK
>>> [java] !STACK 0
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> [java] at
>>> 09:53:34.421
>>> [java] !MESSAGE OK
>>> also be helpful.
>>> John
Re: PDE Build, P2 Metadata and Target Platform Problems [message #588569 is a reply to message #41372] Wed, 21 January 2009 19:08 Go to previous message
Profiles.
John
> thanks,
> John
>> Hi Andrew,
>> verify...
>> [echo] verifying
>> Results -
>>> and verifying that.
>> Questions:
>> John
>>> -Andrew
>>>> -artifactRepository
>>>> -destination
>>>> -bundlepool
>>>> -artifactRepository
>>>> -destination
>>>> -bundlepool
>>>> [java]
>>>> 09:51:57.823
>>>> 09:51:57.824
>>>> 09:51:57.824
>>>> 09:51:57.824
>>>> 09:51:57.824
>>>> 09:51:57.824
>>>> 09:51:57.825
>>>> 09:51:57.825
>>>> [java]
>>>> 09:53:34.418
>>>> installed
>>>> 09:53:34.419
>>>> [java] !MESSAGE OK
>>>> [java] !STACK 0
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> [java] at
>>>> 09:53:34.421
>>>> [java] !MESSAGE OK
>>>> John
Previous Topic:Possible to have multiple features in one project?
Next Topic:Drag and Drop between 2 opened editors
Current Time: Sun May 11 14:39:33 EDT 2025
Powered by FUDForum. Page generated in 0.10672 seconds
