| Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE Build, P2 Metadata and Target Platform Problems
 Goto Forum:|
| PDE Build, P2 Metadata and Target Platform Problems [message #41087] | Mon, 19 January 2009 20:30  |  |
| Eclipse User  |  |  |  |  | Originally posted by: jconlon.apache.org
 Had been stuck for while on a problem with building my RCP features
 based app with PDE Build to include p2 metadata.  The setup is based on
 Andrew Niefer's Example Headless build for a RCP product with p2 @
 http://aniefer.blogspot.com/2008/06/example-headless-build-f or-rcp-product.html
 While I got Andrew's demo working with no problem I could not get my
 features based RCP product built by the Headless Director
 (org.eclipse.equinox.p2.director.app.application to create
 zips of the product that contain P2 metadata.)
 Here is the exception I kept getting:
 [java] Time to load bundles: 38
 [java] Starting application: 43688
 [java] !SESSION 2009-01-19 09:49:40.096
 [java] eclipse.buildId=M20080911-1700
 [java] java.version=1.6.0_05
 [java] java.vendor=Sun Microsystems Inc.
 [java] BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
 [java] Framework arguments:  --launcher.suppressErrors
 -application org.eclipse.equinox.p2.director.app.application -flavor
 tooling -installIU com.verticon.tracker.editor.Tracker -version
 0.3.1.v200901190943 -p2.os win32 -p2.ws win32 -p2.arch x86 -roaming
 -profileProperties org.eclipse.update.install.features=true -profile
 TrackerProfile -metadataRepository
 file:/home/jconlon/eclipse-workspaces/tracker-TRUNK/com.vert icon.tracker.builder/buildDirectory/repo
 -artifactRepository
 -destination
 /home/jconlon/eclipse-workspaces/tracker-TRUNK/com.verticon. tracker.builder/buildDirectory/result/tmp/eclipse
 -bundlepool
 [java] Command-line arguments:  -clean -consoleLog -debug
 --launcher.suppressErrors -application
 org.eclipse.equinox.p2.director.app.application -flavor tooling
 -installIU com.verticon.tracker.editor.Tracker -debug -consoleLog
 -version 0.3.1.v200901190943 -p2.os win32 -p2.ws win32 -p2.arch x86
 -roaming -profileProperties org.eclipse.update.install.features=true
 -profile TrackerProfile -metadataRepository
 -artifactRepository
 -destination
 -bundlepool
 [java]
 [java] !ENTRY org.eclipse.equinox.p2.metadata.repository 2 0
 2009-01-19 09:51:57.823
 [java] !MESSAGE Error parsing metadata repository
 [java] !SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2009-01-19
 09:51:57.823
 [java] !MESSAGE Error at line 10, column 91: Missing required
 attribute in "repository": url
 09:51:57.824
 [java] !MESSAGE Error at line 10, column 91: Illegal value for
 attribute "url" of element "repository": null
 09:51:57.824
 [java] !MESSAGE Error at line 11, column 91: Missing required
 09:51:57.824
 [java] !MESSAGE Error at line 11, column 91: Illegal value for
 09:51:57.824
 [java] !MESSAGE Error at line 12, column 90: Missing required
 09:51:57.824
 [java] !MESSAGE Error at line 12, column 90: Illegal value for
 09:51:57.825
 [java] !MESSAGE Error at line 13, column 90: Missing required
 09:51:57.825
 [java] !MESSAGE Error at line 13, column 90: Illegal value for
 [java] Installing com.verticon.tracker.editor.Tracker
 0.3.1.v200901190943.
 [java] Installation failed.
 [java]
 [java] !ENTRY org.eclipse.equinox.p2.engine 4 4 2009-01-19
 09:53:34.418
 [java] !MESSAGE An error occurred while collecting items to be
 installed
 [java] !SUBENTRY 1 org.eclipse.equinox.p2.artifact.repository 4 0
 2009-01-19 09:53:34.419
 [java] !MESSAGE Problems downloading artifact:
 osgi.bundle,org.eclipse.platform,3.3.101.v200809111700.
 [java] !SUBENTRY 2 org.eclipse.core.runtime 0 0 2009-01-19
 09:53:34.419
 [java] !MESSAGE OK
 [java] !SUBENTRY 2 org.eclipse.equinox.p2.artifact.repository 4 4
 [java] !MESSAGE File has invalid content: /tmp/signatureFile17624.jar
 [java] !SUBENTRY 3 org.eclipse.equinox.p2.artifact.repository 4 0
 [java] !MESSAGE Invalid content: plugin_customization.ini
 [java] !STACK 0
 [java] org.eclipse.osgi.signedcontent.InvalidContentException: The
 file "plugin_customization.ini" in the jar "/tmp/signatureFile17624.jar"
 has been tampered!
 [java] 	at
 org.eclipse.osgi.internal.signedcontent.DigestedInputStream. verifyDigests(DigestedInputStream.java:102)
 [java] 	at
 org.eclipse.osgi.internal.signedcontent.DigestedInputStream. read(DigestedInputStream.java:129)
 [java] 	at
 org.eclipse.osgi.baseadaptor.bundlefile.BundleEntry.getBytes (BundleEntry.java:102)
 [java] 	at
 org.eclipse.osgi.internal.signedcontent.SignedContentImpl$Si gnedContentEntryImpl.verify(SignedContentImpl.java:167)
 [java] 	at
 org.eclipse.osgi.internal.signedcontent.SignedContentFile.ge tSignedEntries(SignedContentFile.java:51)
 [java] 	at
 org.eclipse.equinox.internal.p2.artifact.repository.Signatur eVerifier.verifyContent(SignatureVerifier.java:82)
 [java] 	at
 org.eclipse.equinox.internal.p2.artifact.repository.Signatur eVerifier.verify(SignatureVerifier.java:59)
 [java] 	at
 org.eclipse.equinox.internal.p2.artifact.repository.Signatur eVerifier.close(SignatureVerifier.java:100)
 [java] 	at
 org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.reportStatus(SimpleArtifactRepositor y.java:815)
 [java] 	at
 org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.downloadArtifact(SimpleArtifactRepos itory.java:442)
 [java] 	at
 org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:515)
 [java] 	at
 org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transferSingle(MirrorRequest.java:162)
 [java] 	at
 org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transfer(MirrorRequest.java:146)
 [java] 	at
 org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.perform(MirrorRequest.java:94)
 [java] 	at
 org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:504)
 [java] 	at
 org.eclipse.equinox.internal.p2.artifact.repository.simple.D ownloadJob.run(DownloadJob.java:64)
 [java] 	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
 09:53:34.421
 [java] !MESSAGE OK
 [java] Java Result: 13
 Got similar errors from the Admin UI when I pointed it at the repo I
 created with PDE Build above:
 An error occurred while collecting items to be installed
 File has invalid content: /tmp/signatureFile9067.jar
 The file "plugin_customization.ini" in the jar
 "/tmp/signatureFile9067.jar" has been tampered!
 Was able to cause Andrew's demo to fail in similar ways by adding the
 org.eclipse.platform plugin to the product configuration.
 Searching the bugzilla I  noticed the similarity with
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=241596
 but because I have very little debug or diagnostic messages I had to
 grope in the dark to fix this.
 My last grope was successful - I created a fresh target platform from
 3.4.1 EMF-all-in-one, RCP-delta-pack, and a handful of Equinox plugins
 that were required by the product.
 Since I would hate to have anyone else have to go through this hassle
 and am still in the dark on what caused it -  Does anyone have any
 ideas, and/or suggestions on what might have been happening? Any
 troubleshooting techniques for dealing with similar p2 problems would
 also be helpful.
 thanks for any ideas,
 John
| Re: PDE Build, P2 Metadata and Target Platform Problems [message #41185 is a reply to message #41087] | Tue, 20 January 2009 12:12   |  |
| Eclipse User  |  |  |  |  | So, org.eclipse.platform,3.3.101.v200809111700 is failing signature verification.  You basically want to identify where the "corruption" is
 being introduced.
 In general, to track down this kind of verification error, you want to
 run "jarsigner -verify" on the jars in several locations:
 1) The jar in your repository
 (buildDirectory/repo/plugins/org.eclipse.platform_3.3.101.v2 00809111700.jar)
 2) The jar in the output of the build. (in the example this is
 Builder/I.TestBuild/TestBuild-win32.win32.x86.zip
 3) The input to the build, ie baseLocation
 if (1) passes, then I guess there is a bug in p2 install somewhere
 if (2) passes and (1) failed, the bug is in p2 metadata generation.
 if (3) passes and (2) failed, the bug is in pde.build
 if (3) fails, your input files are corrupt, where did you get them from?
 were they ever modified?
 Since creating a fresh target fixed things for you, I expect the last
 case, somehow the input files got corrupted.
 In this particular case, this is complicated by org.eclipse.platform
 being a folder shaped bundle, so (2) and (3) both are folders.
 jarsigner doesn't verify folders.  You can try zipping them into jars
 and verifying that.  Or, org.eclipse.osgi has experimental API that can
 verify folders, so you could write a small tool using
 CertificateVerifierFactory.  (See as an example
 org.eclipse.pde.build.tests/PDETestCase#assertJarVerifies)
 -Andrew
 >      [java] Framework arguments:  --launcher.suppressErrors -application
 > -artifactRepository
 > -destination
 > -bundlepool
 > -artifactRepository
 > -destination
 > -bundlepool
 >      [java]
 > 09:51:57.823
 > 09:51:57.824
 > 09:51:57.824
 > 09:51:57.824
 > 09:51:57.824
 > 09:51:57.824
 > 09:51:57.825
 > 09:51:57.825
 >      [java]
 > 09:53:34.418
 > installed
 > 09:53:34.419
 >      [java] !MESSAGE OK
 >      [java] !STACK 0
 > has been tampered!
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 > 09:53:34.421
 >      [java] !MESSAGE OK
 > also be helpful.
 > John
| Re: PDE Build, P2 Metadata and Target Platform Problems [message #41278 is a reply to message #41185] | Tue, 20 January 2009 14:55   |  |
 Hi Andrew,
 See inline comments...
 > being introduced.
 Yes, this is the idea I have been exploring (aka groping) as well.
 Before I go further I should point out that to try the tests you
 suggested I first attempted to get the thing to fail again.
 Unfortunately changing the target platform back to the original one I
 first experienced the failures in no longer fails. Ugh! (I failed to
 fail so to speak.)  Nevertheless...
 Have noticed all along that this plugin was a jar and that it failed
 verification.  And even when the director succeeds in extracting a
 product from the repository (like in todays tests) this jar fails to
 verify...
 [echo] verifying
 /home/jconlon/eclipse-workspaces/ganymeade1/Builder/repo/plu gins/org.eclipse.platform_3.3.101.v200809111700.jar
 [exec] jarsigner: java.lang.SecurityException: SHA1 digest error
 for plugin_customization.ini
 In the output zip the org.eclipse.platform_3.3.101.v200809111700 is not
 a jar it's a folder.
 Here too org.eclipse.platform_3.3.101.v200809111700 in the baseLocation
 (my targetPlatform) is a folder.
 4) Let me add a fourth test - the result zip from a successful director
 extraction.
 Here too org.eclipse.platform_3.3.101.v200809111700 is a folder
 Results -
 (1) failed to verify!
 (2) a folder - testing after rejaring validation passes
 (3) folder - testing after rejaring validation passes
 (4) folder - testing after rejaring validation passes
 I hoped this was the case too, but things appear to be more convoluted,
 as mentioned above my old targetPlatform now seems to work. It also
 has/had a good folder in it.
 > being a folder shaped bundle, so (2) and (3) both are folders. jarsigner
 > doesn't verify folders.  You can try zipping them into jars and
 > verifying that.
 As mentioned above I rejared and verified.
 Questions:
 So Why is the repo jaring up the platform folder? (1)
 Why is it corrupting the jar in the process? (1)
 And if the repo has a broken platform plugin jared where is the
 resulting product created by the director getting the good folder to put
 in the result?  (4)
 Or why doesn't the director now NOT fail with a bad jar in the repo?
 Aren't there any diagnostic messages that can log what is going on with
 the P2 and the director??
 thanks for all your help,
 John
 > -Andrew
 >> on Andrew Niefer's Example Headless build for a RCP product with p2 @
 >> -artifactRepository
 >> -destination
 >> -bundlepool
 >> -artifactRepository
 >> -destination
 >> -bundlepool
 >>      [java]
 >> 09:51:57.823
 >> 09:51:57.824
 >> 09:51:57.824
 >> 09:51:57.824
 >> 09:51:57.824
 >> 09:51:57.824
 >> 09:51:57.825
 >> 09:51:57.825
 >>      [java]
 >> 09:53:34.418
 >> installed
 >> 09:53:34.419
 >>      [java] !MESSAGE OK
 >>      [java] !STACK 0
 >> "/tmp/signatureFile17624.jar" has been tampered!
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >> 09:53:34.421
 >>      [java] !MESSAGE OK
 >> also be helpful.
 >> John
| Re: PDE Build, P2 Metadata and Target Platform Problems [message #41372 is a reply to message #41278] | Wed, 21 January 2009 14:24   |  |
 Although I was able to build my product from the repo, I can't do it
 from an AdminUI without getting:
 File has invalid content: /tmp/signatureFile55296.jar
 "/tmp/signatureFile55296.jar" has been tampered!
 thanks,
 John
 > Hi Andrew,
 >> is being introduced.
 > verify...
 > [echo] verifying
 > extraction.
 >> from? were they ever modified?
 > Results -
 >> and verifying that.
 > Questions:
 > in the result?  (4)
 > John
 >> -Andrew
 >>> -artifactRepository
 >>> -destination
 >>> -bundlepool
 >>> -artifactRepository
 >>> -destination
 >>> -bundlepool
 >>>      [java]
 >>> 09:51:57.823
 >>> 09:51:57.824
 >>> 09:51:57.824
 >>> 09:51:57.824
 >>> 09:51:57.824
 >>> 09:51:57.824
 >>> 09:51:57.825
 >>> 09:51:57.825
 >>>      [java]
 >>> 09:53:34.418
 >>> installed
 >>> 0 2009-01-19 09:53:34.419
 >>> 09:53:34.419
 >>>      [java] !MESSAGE OK
 >>> 4 2009-01-19 09:53:34.419
 >>>      [java] !STACK 0
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>> 09:53:34.421
 >>>      [java] !MESSAGE OK
 >>> plugins that were required by the product.
 >>> also be helpful.
 >>> John
| Re: PDE Build, P2 Metadata and Target Platform Problems [message #41436 is a reply to message #41372] | Wed, 21 January 2009 19:08  |  |
 This seems to be related to the other repository I had configured in the
 Admin UI - http://download.eclipse.org/eclipse/updates/3.4.x
 When I remove it and add a local repository ( a locally installed
 Eclipse 3.4.1 SDK) to the the Admin UI, the product now installs in
 Profiles.
 So is the org.eclipse.platform in the
 http://download.eclipse.org/eclipse/updates/3.4.x corrupt?
 BTW - I can't add the
 to my Admin UI for some reason??
 thanks for any help or insights,
 John
 > thanks,
 > John
 >> Hi Andrew,
 >>> to run "jarsigner -verify" on the jars in several locations:
 >> verify...
 >> [echo] verifying
 >> not a jar it's a folder.
 >> baseLocation (my targetPlatform) is a folder.
 >> director extraction.
 >> Results -
 >> convoluted, as mentioned above my old targetPlatform now seems to
 >> work. It also has/had a good folder in it.
 >>> and verifying that.
 >> Questions:
 >> put in the result?  (4)
 >> with the P2 and the director??
 >> John
 >>> -Andrew
 >>>> -artifactRepository
 >>>> -destination
 >>>> -bundlepool
 >>>> -artifactRepository
 >>>> -destination
 >>>> -bundlepool
 >>>>      [java]
 >>>> 09:51:57.823
 >>>> 09:51:57.824
 >>>> 09:51:57.824
 >>>> 09:51:57.824
 >>>> 09:51:57.824
 >>>> 09:51:57.824
 >>>> 09:51:57.825
 >>>> 09:51:57.825
 >>>>      [java]
 >>>> 09:53:34.418
 >>>> installed
 >>>> 09:53:34.419
 >>>>      [java] !MESSAGE OK
 >>>>      [java] !STACK 0
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>> 09:53:34.421
 >>>>      [java] !MESSAGE OK
 >>>> the org.eclipse.platform plugin to the product configuration.
 >>>> from 3.4.1 EMF-all-in-one, RCP-delta-pack, and a handful of Equinox
 >>>> hassle and am still in the dark on what caused it -  Does anyone
 >>>> have any ideas, and/or suggestions on what might have been
 >>>> happening? Any troubleshooting techniques for dealing with similar
 >>>> p2 problems would also be helpful.
 >>>> John
| Re: PDE Build, P2 Metadata and Target Platform Problems [message #588489 is a reply to message #41087] | Tue, 20 January 2009 12:12  |  |
 being introduced.
 -Andrew
 > -artifactRepository
 > -destination
 > -bundlepool
 > -artifactRepository
 > -destination
 > -bundlepool
 >      [java]
 > 09:51:57.823
 > 09:51:57.824
 > 09:51:57.824
 > 09:51:57.824
 > 09:51:57.824
 > 09:51:57.824
 > 09:51:57.825
 > 09:51:57.825
 >      [java]
 > 09:53:34.418
 > installed
 > 09:53:34.419
 >      [java] !MESSAGE OK
 >      [java] !STACK 0
 > has been tampered!
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 >      [java]     at
 > 09:53:34.421
 >      [java] !MESSAGE OK
 > also be helpful.
 > John
| Re: PDE Build, P2 Metadata and Target Platform Problems [message #588519 is a reply to message #41185] | Tue, 20 January 2009 14:55  |  |
 Hi Andrew,
 > being introduced.
 verify...
 [echo] verifying
 extraction.
 Results -
 > verifying that.
 Questions:
 in the result?  (4)
 John
 > -Andrew
 >> -artifactRepository
 >> -destination
 >> -bundlepool
 >> -artifactRepository
 >> -destination
 >> -bundlepool
 >>      [java]
 >> 09:51:57.823
 >> 09:51:57.824
 >> 09:51:57.824
 >> 09:51:57.824
 >> 09:51:57.824
 >> 09:51:57.824
 >> 09:51:57.825
 >> 09:51:57.825
 >>      [java]
 >> 09:53:34.418
 >> installed
 >> 09:53:34.419
 >>      [java] !MESSAGE OK
 >>      [java] !STACK 0
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >>      [java]     at
 >> 09:53:34.421
 >>      [java] !MESSAGE OK
 >> also be helpful.
 >> John
| Re: PDE Build, P2 Metadata and Target Platform Problems [message #588547 is a reply to message #41278] | Wed, 21 January 2009 14:24  |  |
 thanks,
 John
 > Hi Andrew,
 > verify...
 > [echo] verifying
 > extraction.
 > Results -
 >> and verifying that.
 > Questions:
 > in the result?  (4)
 > John
 >> -Andrew
 >>> -artifactRepository
 >>> -destination
 >>> -bundlepool
 >>> -artifactRepository
 >>> -destination
 >>> -bundlepool
 >>>      [java]
 >>> 09:51:57.823
 >>> 09:51:57.824
 >>> 09:51:57.824
 >>> 09:51:57.824
 >>> 09:51:57.824
 >>> 09:51:57.824
 >>> 09:51:57.825
 >>> 09:51:57.825
 >>>      [java]
 >>> 09:53:34.418
 >>> installed
 >>> 09:53:34.419
 >>>      [java] !MESSAGE OK
 >>>      [java] !STACK 0
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>>      [java]     at
 >>> 09:53:34.421
 >>>      [java] !MESSAGE OK
 >>> also be helpful.
 >>> John
| Re: PDE Build, P2 Metadata and Target Platform Problems [message #588569 is a reply to message #41372] | Wed, 21 January 2009 19:08  |  |
 Profiles.
 John
 > thanks,
 > John
 >> Hi Andrew,
 >> verify...
 >> [echo] verifying
 >> Results -
 >>> and verifying that.
 >> Questions:
 >> John
 >>> -Andrew
 >>>> -artifactRepository
 >>>> -destination
 >>>> -bundlepool
 >>>> -artifactRepository
 >>>> -destination
 >>>> -bundlepool
 >>>>      [java]
 >>>> 09:51:57.823
 >>>> 09:51:57.824
 >>>> 09:51:57.824
 >>>> 09:51:57.824
 >>>> 09:51:57.824
 >>>> 09:51:57.824
 >>>> 09:51:57.825
 >>>> 09:51:57.825
 >>>>      [java]
 >>>> 09:53:34.418
 >>>> installed
 >>>> 09:53:34.419
 >>>>      [java] !MESSAGE OK
 >>>>      [java] !STACK 0
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>>      [java]     at
 >>>> 09:53:34.421
 >>>>      [java] !MESSAGE OK
 >>>> John
 Current Time: Thu Oct 30 22:24:01 EDT 2025
 Powered by FUDForum . Page generated in 0.04591 seconds |
