Home » Modeling » EMF » EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor)
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #404112 is a reply to message #404109] |
Sat, 30 September 2006 13:50 |
Ed Merks Messages: 33142 Registered: July 2009 |
Kamesh,
Probably the best you will get is pointers to existing source code (Eric
Gamma's monkey-see-monkey-do principle) and it will typically be quite
complex. The XSDEditor is a relatively simple (i.e., crude) example.
It will reparse the text whenever the text changes. It uses an
IDocumentListener with a delay to avoid responding to every key stroke.
For the reverse, the command stack listener calls
handleStructuredModelChange whenever a command has been executed, which
serializes the resource in memory and updates the text in the text
editor. This is quite a brute force approach, but should serve as a
starting point.
Kamesh Sampath wrote:
> Folks,
> Am really trying hard to save a model by editing a raw text and there
> by updating the MODEL . All my attempts are in vain .
> My Scenario:
> The editing domain and model is same for both the editors i mean to
> say am sharing the same common EMF model.
> I have an Multipage editor with two pages 1. TreeViewer to edit the
> model 2. TextEditor to view the model source
> I am able to view the changes made to the TreeViewer in the TextEditor
> but am struck up with the reverse scenario i.e when i make any textual
> changes to the model in form text in TextEditor i should synchronize
> that with the underlying model file , I am using the XML editor
> created out of eclipse platform samples.
> My issues are ,
> 1. How to track the textual changes in the Text Editor?
> 2. How to fire the model commands based on the Textual Changes?
> I dont know how to do this ? can anyone help me please . I dont mind
> even the model file gets corrupted as am not enforcing any validations
> now , all that i want is to make both work in sync changes to Model
> reflected in Source and Changes to source should be reflected in model.
> I am trying to do exactly like the PDE editor. I even saw the PDE
> editor source but its really long and very confusing to me.
> Any pointers will be really helpful.
> Thanks.
Ed Merks
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #404114 is a reply to message #404112] |
Sat, 30 September 2006 15:35 |
Kamesh Sampath Messages: 191 Registered: July 2009 |
Ed,
Thats right ! thats y i sought to see the PDE Editor , but for my
requirement its quite complex hence i asked for somthing much simpler.
Will try the XSD editor.
Thanks .
Kamesh
Ed Merks wrote:
> Kamesh,
> (Eric Gamma's monkey-see-monkey-do principle) and it will typically be
> quite complex. The XSDEditor is a relatively simple (i.e., crude)
> example. It will reparse the text whenever the text changes. It uses
> an IDocumentListener with a delay to avoid responding to every key
> stroke. For the reverse, the command stack listener calls
> which serializes the resource in memory and updates the text in the
> text editor. This is quite a brute force approach, but should serve
> as a starting point.
>> Folks,
>> My Scenario:
>> textual changes to the model in form text in TextEditor i should
>> synchronize that with the underlying model file , I am using the XML
>> editor created out of eclipse platform samples.
>> My issues are ,
>> validations now , all that i want is to make both work in sync
>> changes to Model reflected in Source and Changes to source should be
>> reflected in model.
>> Thanks.
Kamesh Sampath
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #404116 is a reply to message #404114] |
Sat, 30 September 2006 17:21 |
Kamesh Sampath schrieb:
> Ed,
> simpler. Will try the XSD editor.
Doesn't WTP have an XML editor? I don't use it but I'd expect that they
have text/model sync...
Cheers
/Eike
> Thanks .
> Kamesh
> Ed Merks wrote:
>> Kamesh,
>> be quite complex. The XSDEditor is a relatively simple (i.e., crude)
>> uses an IDocumentListener with a delay to avoid responding to every
>> key stroke. For the reverse, the command stack listener calls
>>> Folks,
>>> there by updating the MODEL . All my attempts are in vain .
>>> My Scenario:
>>> My issues are ,
>>> reflected in model.
>>> Thanks.
Cheers
/Eike
http://www.esc-net.de
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #404117 is a reply to message #404116] |
Sat, 30 September 2006 17:37 |
Eike,
Yes, WTP has a very cool SED DOM that incrementally synchronizes a DOM
structure with the textual source view of it. This in combination with
something that incrementally synchronizes an EMF model with that DOM
would be an extremely cool combination. A generated EMF editor with a
source view would be possible...
>> Ed,
> they have text/model sync...
> Cheers
> /Eike
>> Thanks .
>> Kamesh
>> Ed Merks wrote:
>>> Kamesh,
>>> crude) example. It will reparse the text whenever the text
>>> changes. It uses an IDocumentListener with a delay to avoid
>>> responding to every key stroke. For the reverse, the command stack
>>> listener calls handleStructuredModelChange whenever a command has
>>> been executed, which serializes the resource in memory and updates
>>> the text in the text editor. This is quite a brute force approach,
>>> but should serve as a starting point.
>>>> Folks,
>>>> My Scenario:
>>>> XML editor created out of eclipse platform samples.
>>>> My issues are ,
>>>> mind even the model file gets corrupted as am not enforcing any
>>>> Thanks.
Ed Merks
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #404118 is a reply to message #404117] |
Sat, 30 September 2006 17:57 |
Ed Merks schrieb:
> Eike,
> with something that incrementally synchronizes an EMF model with that
> DOM would be an extremely cool combination. A generated EMF editor
> with a source view would be possible...
Indeed. But personally I'd prefer to see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=108470 addressed before ;-)
Cheers
/Eike
>>> Ed,
>> Cheers
>> /Eike
>>> Thanks .
>>> Kamesh
>>> Ed Merks wrote:
>>>> Kamesh,
>>>>> Folks,
>>>>> My Scenario:
>>>>> to say am sharing the same common EMF model.
>>>>> the model 2. TextEditor to view the model source
>>>>> TextEditor
>>>>> My issues are ,
>>>>> Thanks.
Cheers
/Eike
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #404120 is a reply to message #404116] |
Sat, 30 September 2006 18:05 |
Ed and Eike,
Thanks for further Information . Actually i thoght of looking in to that
.. Let me do it . If am successfull i shall contribue a patch to EMF
editor generation to have an Text editor that will edit the source .
Thanks for the info .
Kamesh
>> Ed,
> Cheers
> /Eike
>> Thanks .
>> Kamesh
>> Ed Merks wrote:
>>> Kamesh,
>>>> Folks,
>>>> My Scenario:
>>>> My issues are ,
>>>> Thanks.
Kamesh Sampath
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #404128 is a reply to message #404120] |
Sat, 30 September 2006 18:57 |
Ed and Eike,
The WTP SED is cool one . We have something called the
StrucutredTextEditor , we can use that i guess. I am just looking in to
that option , once am successful i shall post the message.
Thanks.
Kamesh
> Ed and Eike,
> that .. Let me do it . If am successfull i shall contribue a patch to
> EMF editor generation to have an Text editor that will edit the source .
> Kamesh
>>> Ed,
>> Cheers
>> /Eike
>>> Thanks .
>>> Kamesh
>>> Ed Merks wrote:
>>>> Kamesh,
>>>>> Folks,
>>>>> My Scenario:
>>>>> TextEditor
>>>>> My issues are ,
>>>>> Thanks.
Kamesh Sampath
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #404130 is a reply to message #404128] |
Sat, 30 September 2006 20:01 |
Ed and Eike,
I am able to successully integrate the WTP SED with my Editor . Lots of
redundant stuff has been removed from the common TextEditor that we
develop. But am facing a peculiar problem with the same , whenever we
want to fire the PROP_DIRTY with StructuredTextEditor(WTP Text Editor)
we need to implement the Property Change listener and register the same
with WTP SED , when i do a == comparison between the source and my
initialised text editor inside my propertyChanged(Object source, int
propId) is failing , though when i print the same in the console its
same object name
* (non-Javadoc)
* @see
org.eclipse.ui.IPropertyListener#propertyChanged(java.lang.O bject,
* int)
public void propertyChanged(Object source, int propId) {
System.out.println("Source : " + source + " propID :" + propId
+ "PROP_Dirty=" + IEditorPart.PROP_DIRTY);
System.out.println("Source Editor :" + sourceEditor);
switch (propId) {
case IEditorPart.PROP_DIRTY:
case IEditorPart.PROP_INPUT: {
if (source == sourceEditor) {
if (sourceEditor.getEditorInput() != getEditorInput()) {
System.out.println("2.1");
setInput(sourceEditor.getEditorInput());
Runnable runnable = new Runnable() {
public void run() {
firePropertyChange(IEditorPart.PROP_DIRTY);
postOnDisplayQue(runnable);
break;
Can you help me why its failing ??
Kamesh
> Ed and Eike,
> to that option , once am successful i shall post the message.
> Thanks.
> Kamesh
>> Ed and Eike,
>> Kamesh
>>>> Ed,
>>> Cheers
>>> /Eike
>>>> Thanks .
>>>> Kamesh
>>>> Ed Merks wrote:
>>>>> Kamesh,
>>>>> typically be quite complex. The XSDEditor is a relatively simple
>>>>> (i.e., crude) example. It will reparse the text whenever the text
>>>>> stack listener calls handleStructuredModelChange whenever a
>>>>> command has been executed, which serializes the resource in memory
>>>>> and updates the text in the text editor. This is quite a brute
>>>>> force approach, but should serve as a starting point.
>>>>>> Folks,
>>>>>> My Scenario:
>>>>>> TextEditor
>>>>>> My issues are ,
>>>>>> Thanks.
Kamesh Sampath
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #404131 is a reply to message #404130] |
Sat, 30 September 2006 21:12 |
Kamesh,
Should use be using .equals verses ==?
> Ed and Eike,
> same object name
> * (non-Javadoc)
> * @see
> * int)
> switch (propId) {
> getEditorInput()) {
> public void run() {
> break;
> Kamesh
>> Ed and Eike,
>> Thanks.
>> Kamesh
>>> Ed and Eike,
>>> to EMF editor generation to have an Text editor that will edit the
>>> source .
>>> Kamesh
>>>>> Ed,
>>>> Cheers
>>>> /Eike
>>>>> Thanks .
>>>>> Kamesh
>>>>> Ed Merks wrote:
>>>>>> Kamesh,
>>>>>> code (Eric Gamma's monkey-see-monkey-do principle) and it will
>>>>>> text changes. It uses an IDocumentListener with a delay to avoid
>>>>>> memory and updates the text in the text editor. This is quite a
>>>>>> brute force approach, but should serve as a starting point.
>>>>>>> Folks,
>>>>>>> My Scenario:
>>>>>>> TextEditor
>>>>>>> My issues are ,
>>>>>>> PDE editor source but its really long and very confusing to me.
>>>>>>> Thanks.
Ed Merks
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #414645 is a reply to message #404130] |
Thu, 15 November 2007 23:19 |
Vasanth Velusamy Messages: 31 Registered: July 2009 |
Member |
Kamesh, Ed,
I know it has been over a year since the last post on this topic, but,
any updates on this? As of now, the generated EMF multipage editor still
lacks a source editor.
Vasanth
> Ed and Eike,
> same object name
> * (non-Javadoc)
> * @see
> * int)
> switch (propId) {
> public void run() {
> break;
> Kamesh
>> Ed and Eike,
>> Thanks.
>> Kamesh
>>> Ed and Eike,
>>> Kamesh
>>>>> Ed,
>>>> Cheers
>>>> /Eike
>>>>> Thanks .
>>>>> Kamesh
>>>>> Ed Merks wrote:
>>>>>> Kamesh,
>>>>>>> Folks,
>>>>>>> My Scenario:
>>>>>>> TextEditor
>>>>>>> My issues are ,
>>>>>>> Thanks.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #414646 is a reply to message #414645] |
Thu, 15 November 2007 23:33 |
Vasanth,
It's highly unlikely that that without active contributors from the
community this issue will get addressed directly by the vanishingly
small EMF team. It would make a great EMFT component.
Vasanth Velusamy wrote:
> Kamesh, Ed,
> still lacks a source editor.
> Vasanth
>> Ed and Eike,
>> same object name
>> * (non-Javadoc)
>> * @see
>> * int)
>> switch (propId) {
>> getEditorInput()) {
>> public void run() {
>> break;
>> Kamesh
>>> Ed and Eike,
>>> Thanks.
>>> Kamesh
>>>> Ed and Eike,
>>>> source .
>>>> Kamesh
>>>>>> Ed,
>>>>> Cheers
>>>>> /Eike
>>>>>> Thanks .
>>>>>> Kamesh
>>>>>> Ed Merks wrote:
>>>>>>> Kamesh,
>>>>>>> simple (i.e., crude) example. It will reparse the text whenever
>>>>>>> the text changes. It uses an IDocumentListener with a delay to
>>>>>>> avoid responding to every key stroke. For the reverse, the
>>>>>>> command stack listener calls handleStructuredModelChange
>>>>>>> whenever a command has been executed, which serializes the
>>>>>>> resource in memory and updates the text in the text editor.
>>>>>>> starting point.
>>>>>>>> Folks,
>>>>>>>> My Scenario:
>>>>>>>> mean to say am sharing the same common EMF model.
>>>>>>>> TextEditor
>>>>>>>> should synchronize that with the underlying model file , I am
>>>>>>>> using the XML editor created out of eclipse platform samples.
>>>>>>>> My issues are ,
>>>>>>>> Thanks.
Ed Merks
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #414661 is a reply to message #414655] |
Fri, 16 November 2007 10:56 |
--------------060404030403070404040004
David,
Trying to usurp EMFT contributors are you?! :-P
It would be very helpful for WTP to provide SSE in a form that's more
easily consumable (i.e., with minimal dependencies).
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205892
I suspect that would require some fundamental restructuring that would
break APIs, so that's not so likely to happen even with contributor
involvement...
David Williams wrote:
> On Thu, 15 Nov 2007 18:33:53 -0500, Ed Merks <merks@ca.ibm.com> wrote:
>> Vasanth,
> Well, it's make an even better component in the WTP Incubator! :)
> But Ed's point is just as valid. It will take someone from the community several
> months of full time work to put together all the pieces we have, which
> we know is no volunteer-in-your-free-time sort of effort.
<html>
<head>
</head>
David,<br>
<br>
Trying to usurp EMFT contributors are you?! :-P<br>
<br>
easily consumable (i.e., with minimal dependencies).<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=205892">https://bugs.eclipse.org/bugs/show_bug.cgi?id=205892</a><br>
</blockquote>
involvement...<br>
<br>
<br>
<blockquote cite="mid:op.t1vih2otac05ss@dmw2t23.ibm.com" type="cite">
<pre wrap="">On Thu, 15 Nov 2007 18:33:53 -0500, Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Vasanth,
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------060404030403070404040004--
Ed Merks
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #414693 is a reply to message #414691] |
Fri, 16 November 2007 14:13 |
Vasanth,
I think so.
> Given that a generated Source Editor cannot be expected in the
> immediate future, what would the best way for me to implement it
> myself? Earlier in this thread, Ed mentioned using IDocumentListener.
> Is that the way to go?
> Vasanth
>>> Vasanth,
>> community several
Ed Merks
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #414697 is a reply to message #414693] |
Fri, 16 November 2007 16:37 |
Steve Blass Messages: 276 Registered: July 2009 |
"Open with Text Editor" works and the changes are picked up by the EMF
editor when you save. Adding an "Edit Source" button to an EMF editor
ViewerPane for opening the source in a text editor is fairly straight
forward. Crude yes. Possibly effective depending on the target
audience for the EMF model source editing capability. Works for me but
I wouldn't give the option to pedestrian users.
Ed Merks wrote:
> Vasanth,
> I think so.
>> Thanks,
>> Vasanth
>>>> Vasanth,
>>> community several
Current Time: Sat Apr 27 02:29:39 GMT 2024
Powered by FUDForum. Page generated in 0.05531 seconds
