Home » Archived » Test and Performance Tools Platform (TPTP) » working with junit tests
working with junit tests [message #41015] Thu, 17 November 2005 04:54 Go to next message
I tried to use tptp with eclipse sdk version 3.1.0 / I20050627-1435
It didn't work the profiling of test cases. But running java classes
worked. Is this normal? Have someone used tptp and wtp at the same time?
what's the best combination of version for those to work? is there any
conflict?
Emerson
Re: working with junit tests [message #41295 is a reply to message #41015] Thu, 17 November 2005 23:00 Go to previous message
Can you please provide more details about your problem.
For example:
What release of TPTP are you using? 4.0.1 or 4.1.0?
Did you download all the required components listed under the 'Requirements'
heading of the download page?
Are you using the agent controller or the integrated agent controller to
profile JUnits?
What is the actual error that you're getting? Are you getting a logged
exception?
"Emerson " <echofloripa@xxxxx.xxx> wrote in message
news:b7c8bffaf4c1d751e8ad8d59b3bd145c$1@www.eclipse.org...
> conflict?
> Emerson
[Updated on: Mon, 06 November 2017 14:29] by Moderator
Previous Topic:Populate Log Navigator runtime
Next Topic:newbie question for setting up tptp - junit
Current Time: Thu Jul 17 11:47:11 EDT 2025
Powered by FUDForum. Page generated in 0.27749 seconds
