Home » Archived » EPF » Iterations
Iterations [message #40986] Mon, 24 September 2007 00:40 Go to next message
I'm unsure how to convey "iterative activity." I run across two general
types of iterations in my modeling of development processes.
1. Piecemeal - Whereby each iteration is essentially
the same activity, repeated multiple
times.
2. Evolutionary - Whereby a component is realized in
over multiple iterations, be each
iteration is a different activity.
An piecemeal example is developing a persistence layer. The iterative
steps would be adding support for one query/table for one iteration, and
other queries/tables for other iterations. The activity of adding
support for different queries is very similar from one iteration to the
next.
An evolutionary example would be developing a transport layer. The
first iteration would be simply getting something that excepts a request
and logs it. There might not be any other code to invoke at this point.
But later iterations would add support for interpretations of various
messages and the invocations of downstream components. It's an
iterative process, but the steps are not identical for each iteration.
Does EPF provide a way to model these? I've been developing for a
while, but I'm new to process modeling.
- Paul
Re: Iterations [message #41017 is a reply to message #40986] Mon, 24 September 2007 06:33 Go to previous messageGo to next message
Isn't this incremental vs. iterative?
Roman
"Paul Glezen" <pglezen@us.ibm.com> wrote in message
news:fd7f3j$at9$1@build.eclipse.org...
> times.
> other queries/tables for other iterations. The activity of adding support
> for different queries is very similar from one iteration to the next.
> An evolutionary example would be developing a transport layer. The first
> iteration would be simply getting something that excepts a request and
> logs it. There might not be any other code to invoke at this point. But
> later iterations would add support for interpretations of various messages
> and the invocations of downstream components. It's an iterative process,
> Does EPF provide a way to model these? I've been developing for a while,
> - Paul
Re: Iterations [message #41171 is a reply to message #41017] Tue, 25 September 2007 23:26 Go to previous messageGo to next message
Perhaps. Which one is "incremental" and which one is "iterative"?
After reviewing the input fields available, I suspect we simply describe
what we mean in the "Main" section of the iteration panel itself.
> Roman
>> times.
>> over multiple iterations, but each
Re: Iterations [message #41263 is a reply to message #41171] Thu, 27 September 2007 03:06 Go to previous messageGo to next message
May this help
http://en.wikipedia.org/wiki/Iterative_and_incremental_devel opment?
I guess definitions may vary however my understanding was that the iterative
rather means evolutionary whereas incremental means complete piece of
functionality at the time.
Note that there are certain reasons to deliver an increment in the iteration
but that is probably another topic..
Hope this helps,
Roman
news:fdcjho$tkb$1@build.eclipse.org...
>> Roman
>>> times.
Re: Iterations [message #41679 is a reply to message #41263] Sat, 29 September 2007 13:58 Go to previous message
Thanks, Roman. I think this straightens me out.
Roman Smirak wrote:
> May this help
> Hope this helps,
> Roman
Re: Iterations [message #583430 is a reply to message #40986] Mon, 24 September 2007 06:33 Go to previous message
Roman
> times.
> - Paul
Re: Iterations [message #583498 is a reply to message #41017] Tue, 25 September 2007 23:26 Go to previous message
> Roman
>> times.
Re: Iterations [message #583553 is a reply to message #41171] Thu, 27 September 2007 03:06 Go to previous message
May this help
Hope this helps,
Roman
>> Roman
>>> times.
Re: Iterations [message #583749 is a reply to message #41263] Sat, 29 September 2007 13:58 Go to previous message
Roman Smirak wrote:
> May this help
> Hope this helps,
> Roman
Previous Topic:Problem with 1.2.0.1
Next Topic:translation request
Current Time: Fri Oct 24 16:00:16 EDT 2025
Powered by FUDForum. Page generated in 0.07748 seconds
