Home » Language IDEs » AspectJ » Plugin and Fragment with AspectJ
Plugin and Fragment with AspectJ [message #40981] Wed, 29 September 2004 08:04 Go to next message
Originally posted by: wdr.isogmbh.de
Hallo,
i have developed a plugin for eclipse 3.0 and a fragment for that plugin.
All works fine.
After i converted the plugin to an aspectj project i get the following
messages in the problems view.
The project cannot be built until its prerequisite plugin is built.
Cleaning and building all projects is recommended
How can I use my fragment when my plugin is an aspectj project?
Thanks for help.
Re: Plugin and Fragment with AspectJ [message #41043 is a reply to message #40981] Wed, 29 September 2004 12:03 Go to previous messageGo to next message
Originally posted by: hawkinsh.uk.ibm.com
thomas wrote:
> Hallo,
> All works fine.
> Thanks for help.
Could you let me know which version of AJDT you're using? There has been
quite a lot of work in the area of project dependencies recently and I was
wondering if you've picked up these changes.
Thanks, Helen
Re: Plugin and Fragment with AspectJ [message #41074 is a reply to message #40981] Wed, 29 September 2004 16:44 Go to previous messageGo to next message
Originally posted by: andrew.hammer.h2-reactor.com
Thomas,
Try adding an AspectJ nature to the fragment. I've received the same
error with AJDT 1.1.12 when downloading the AJDT source. There are regular
plugins that depend on AspectJ plugins. When I made these dependant plugins
AspectJ plugins, the problem was resolved.
Andrew Hammer
"thomas" <wdr@isogmbh.de> wrote in message news:cje8d7$j73$1@eclipse.org...
> Hallo,
> All works fine.
> Thanks for help.
Re: Plugin and Fragment with AspectJ [message #41106 is a reply to message #41043] Thu, 30 September 2004 06:43 Go to previous messageGo to next message
I am using AJDT 1.1.11
> Thanks, Helen
Re: Plugin and Fragment with AspectJ [message #41167 is a reply to message #41106] Thu, 30 September 2004 09:32 Go to previous messageGo to next message
If possible, would you be able to upgrade your version of AJDT to the
latest development build? (the fixes to the project dependencies area have
been added since the 1.1.12 release). This can be done by creating a new
update site location with the following url:
http://download.eclipse.org/technology/ajdt/30/dev/update
I believe your problem should be fixed in this version (when you upgrade
your version of AJDT its probably worth ensuring that you have no editors
showing - there has been some renaming of the ajdt plugins since the
1.1.12 release).
If this is not convenient for you, then could you try adding AJ nature to
your feature plugin and see if this helps?
Thanks, Helen
Re: Plugin and Fragment with AspectJ [message #41291 is a reply to message #41167] Fri, 01 October 2004 04:09 Go to previous messageGo to next message
Hi !
I tried to put this url in the find/install wizard, but there is no feature showing ! I see the
AspectJ feature under the remote site on the "Update sites to visit" page, but then nothing on the
"Search results page"...
I am using version 3.1M2 on winxp...
Am I doing something wrong ?
Thanks.
Thierry
Re: Plugin and Fragment with AspectJ [message #41322 is a reply to message #41291] Fri, 01 October 2004 05:43 Go to previous messageGo to next message
No, I think the issue is with the update site. We haven't done it
deliberately, but I think it's unhappy with your Eclipse version. We hit a
problem where the feature wouldn't show up with Eclipse 3.0.1 (only
Eclipse 3.0.0). We've fixed that, and I'll investigate the problem with
3.1 builds. In the meantime would you be able to try with Eclipse 3.0.0 or
3.0.1? AJDT is likely to be more stable with those versions of Eclipse
anyway. (It is quite time consuming trying to keep up with all the Eclipse
milestone builds, although of course it is useful to know if there are any
problems there.)
Matt.
Re: Plugin and Fragment with AspectJ [message #41352 is a reply to message #41322] Fri, 01 October 2004 07:48 Go to previous messageGo to next message
> 3.0.1?
Now the update works for both 3.0.1 and 3.1M2.
> problems there.)
I understand... We cannot expect you to give us a release for each nightly build of Eclipse ;-)
> Matt.
Thank you for the quick answer !
Thierry.
Re: Plugin and Fragment with AspectJ [message #42974 is a reply to message #41167] Mon, 18 October 2004 03:09 Go to previous message
I have upgraded my version to AJDT 1.1.12 and now all works fine.
Thanks Thomas
Re: Plugin and Fragment with AspectJ [message #583302 is a reply to message #40981] Wed, 29 September 2004 12:03 Go to previous message
thomas wrote:
> Hallo,
> All works fine.
> Thanks for help.
Thanks, Helen
Re: Plugin and Fragment with AspectJ [message #583318 is a reply to message #40981] Wed, 29 September 2004 16:44 Go to previous message
Thomas,
Andrew Hammer
> Hallo,
> All works fine.
> Thanks for help.
Re: Plugin and Fragment with AspectJ [message #583331 is a reply to message #41043] Thu, 30 September 2004 06:43 Go to previous message
> Thanks, Helen
Re: Plugin and Fragment with AspectJ [message #583362 is a reply to message #41106] Thu, 30 September 2004 09:32 Go to previous message
1.1.12 release).
Thanks, Helen
Re: Plugin and Fragment with AspectJ [message #583413 is a reply to message #41167] Fri, 01 October 2004 04:09 Go to previous message
Hi !
Thanks.
Thierry
Re: Plugin and Fragment with AspectJ [message #583429 is a reply to message #41291] Fri, 01 October 2004 05:43 Go to previous message
problems there.)
Matt.
Re: Plugin and Fragment with AspectJ [message #583442 is a reply to message #41322] Fri, 01 October 2004 07:48 Go to previous message
> 3.0.1?
> problems there.)
> Matt.
Thierry.
Re: Plugin and Fragment with AspectJ [message #584269 is a reply to message #41167] Mon, 18 October 2004 03:09 Go to previous message
Thanks Thomas
Previous Topic:CodeAssist auto activation does not work.
Next Topic:AJDT 1.2.0M1 released
Current Time: Sun Aug 31 05:53:54 EDT 2025
Powered by FUDForum. Page generated in 0.06086 seconds
