Can't install Subversive SVN Connectors release (2.0.7 or 2.0.8?) [message #40972] |
Thu, 05 February 2009 03:54  |
I try to install latest release version of Polarion SVN connectors with
Eclipse 3.4.1 and after having installed Subversive 0.7.6 successfully.
When using the URL
http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/
as described on
http://www.polarion.com/products/svn/subversive.php?src=ecli pseproject,
the update manager fails with the following message:
An error occurred while collecting items to be installed
Problems downloading artifact:
osgi.bundle,org.polarion.eclipse.team.svn.connector,2.0.7.I2 0081222-1900.
Downloaded stream not a valid archive. Check the server.
Error closing the output stream for
org.polarion.eclipse.team.svn.connector/org.eclipse.update.f eature/2.0.7.I20081222-1900
on repository file:/D:/Java/dev/eclipse-3.4.1/.
Error unzipping
D:\Profile\ams00585\LOKALE~1\Temp\org.polarion.eclipse.team. svn.connector_2.0.7.I20081222-190061302.jar:
Invalid zip file format
The mentioned file contains the following:
<H1>Multiple Choices</H1>
The document name you requested
(<code> /projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector_2.0.7.I20081222-1 900.jar </code>)
could not be found on this server.
However, we found documents with names similar to the one you
requested.<p>Available documents:
<ul>
<li><a
href=" /projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.javahl.sources_2. 0.8.I20090202-1500.jar "> /projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.javahl.sources_2. 0.8.I20090202-1500.jar </a>
(common basename)
<li><a
href=" /projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.javahl.win32_2.0. 8.I20090202-1500.jar "> /projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.javahl.win32_2.0. 8.I20090202-1500.jar </a>
(common basename)
<li><a
href=" /projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.javahl15.sources_ 2.0.8.I20090202-1500.jar "> /projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.javahl15.sources_ 2.0.8.I20090202-1500.jar </a>
(common basename)
So, it seems the site contains version 2.0.8 of these plugins, but Update
manager thinks there should be files of version 2.0.7 which he can't find.
What can I do?
Christoph
Re: Can't install Subversive SVN Connectors release (2.0.7 or 2.0.8?) [message #41062 is a reply to message #40972] |
Thu, 05 February 2009 09:16   |
Hello Christoph,
It seems strange. What version do you see for SVN Connectors in "Software
Updates and Add-ons" dialog? Do you have an enabled "Show only the latest
versions of available software" option?
Also as a quick resolution you can install connectors from archived update
site:
http://www.polarion.org/projects/subversive/download/eclipse /2.0/builds/
> When using the URL
> as described on
> on repository file:/D:/Java/dev/eclipse-3.4.1/. Error unzipping
> <ul>
> <li><a
> (common basename)
> <li><a
> (common basename)
> <li><a
> (common basename)
> What can I do?
> Christoph
Re: Can't install Subversive SVN Connectors release (2.0.7 or 2.0.8?) [message #41184 is a reply to message #41062] |
Thu, 05 February 2009 10:38  |
The version I see is exactly what is listed in the error message:
2.0.7.I20081222-1900. The checkbox "Show only the latest" does not change
the listed items, nor does pressing Refresh button.
BTW, I tried both with an existing Eclipse 3.4.0 installation (having
version 2.0.3 of connectors installed) as well as with a fresh 3.4.1
installation. Neither restarting Eclipse nor rebooting the system did help.
I just tried to use the URL you gave me but recognized this is not an
update site but providing the ZIPs. I will probably download and use that
now.
Thanks for your help,
Christoph
> Hello Christoph,
> site:
>> When using the URL
>> as described on
D:Profileams00585LOKALE~1Temporg.polarion.eclipse.team.svn.c onnector_2.0.7.I20081222-190061302.jar:
>> <ul>
>> <li><a
>> (common basename)
>> <li><a
>> (common basename)
>> <li><a
>> (common basename)
>> What can I do?
>> Thanks,
>> Christoph
FUDForum. Page generated in 0.04096 seconds
