Home » Archived » XML Schema Definition (XSD) » CVS / Bug-Fixing-Process
CVS / Bug-Fixing-Process [message #3510] |
Tue, 22 October 2002 12:17  |
Originally posted by: dims.yahoo.com
We are researching using Schema Infoset Model in Apache Axis. Here are a
few questions related to administrative stuff...
#1. The main page says that the CVS repoistory is "to be populated"...Any
idea when?
#2. What's the process if we find a bug?
#3. Who does one get commit access to the cvs? (After it is populated, of
course :)
dims
Re: CVS / Bug-Fixing-Process [message #4099 is a reply to message #3609] |
Thu, 24 October 2002 09:33   |
Ed,
I'd like to see xsd to be part of the Gump build (see
http://jakarta.apache.org/builds/gump/latest/ and
http://jakarta.apache.org/gump/) Please talk to Sam Ruby (IBM) if you need
more information.
If we have to use XSD for Apache Axis, we need to get a daily build of XSD
for continuous testing. This is possible ONLY if your code is available
via a public cvs.
dims
Ed Merks wrote:
> The build and development processes we've used over the last few years, and
> our tight integration with EMF, make migrating the "master image" to CVS
> problematic. All the source code is currently in CVS, but only as part of
> the "source-linked" Javadoc. It is also available with each driver.
> Committing changes to the base code is something we'd have to look at
> carefully. Bugs should be opened in bugzilla, and I'll try to be very
> responsive to fixing them.
> Thanks for your interest!
> Davanum Srinivas wrote:
> > Hi,
> > idea when?
> > course :)
> > Thanks,
> > dims
> Ed Merks
Re: CVS / Bug-Fixing-Process [message #4153 is a reply to message #4099] |
Thu, 24 October 2002 11:23   |
Davanum,
This implies that you would have to reproduce the EMF build as well? And parts
of the Eclipse build? I can't simply commit to that without involving a whole
heck of a lot of other people; reproducing complex build processes doesn't sound
like a great starting point since it would seem to involve a massive coordination
effort. Why can't packaged builds be tested? Perhaps we need to have a
conversation about this when you've finished your evaluation work...
> Ed,
> more information.
> via a public cvs.
> dims
> Ed Merks wrote:
> > Hi,
> > > Hi,
> > > idea when?
> > > course :)
> > > Thanks,
> > > dims
> > Ed Merks
Ed Merks
Re: CVS / Bug-Fixing-Process [message #4223 is a reply to message #4099] |
Thu, 24 October 2002 11:26  |
Well, actually GUMP *can* use a precompiled, posted daily build somewhere, which would be much easier to arrange in the short
term. 8-)
And indeed the EMF jars will be required, although from an external perspective you may or may not want to simply lump them
together in the short term for simplicity. Unfortunately I'm far from an EMF or XSD build expert so I can't help much more.
- Shane
On Thu, 24 Oct 2002 13:33:38 +0000 (UTC), dims@yahoo.com (Davanum Srinivas) wrote:
> Ed,
> more information.
> via a public cvs.
> dims
Re: CVS / Bug-Fixing-Process [message #563225 is a reply to message #3510] |
Tue, 22 October 2002 14:34  |
> idea when?
> course :)
> dims
Ed Merks
Re: CVS / Bug-Fixing-Process [message #563356 is a reply to message #3609] |
Ed,
more information.
via a public cvs.
dims
Ed Merks wrote:
> > Hi,
> > idea when?
> > course :)
> > Thanks,
> > dims
> Ed Merks
Re: CVS / Bug-Fixing-Process [message #563383 is a reply to message #4099] |
Davanum,
> Ed,
> more information.
> via a public cvs.
> dims
> Ed Merks wrote:
> > Hi,
> > > Hi,
> > > idea when?
> > > course :)
> > > Thanks,
> > > dims
> > Ed Merks
Ed Merks
Re: CVS / Bug-Fixing-Process [message #563406 is a reply to message #4099] |
term. 8-)
- Shane
> Ed,
> more information.
> via a public cvs.
> dims
Current Time: Mon Jul 14 16:26:09 EDT 2025
Powered by FUDForum. Page generated in 0.34225 seconds
