Home » Eclipse Projects » SWTBot » UI deadlock when typing character with SWTKeyboardStrategy
UI deadlock when typing character with SWTKeyboardStrategy [message #40829] Fri, 26 June 2009 13:23 Go to next message
Hi again,
As you know, I'm using the typeText methods to simulate real user input
and with the AltGr problem we are having, I started using the EN_US
keyboard layout for the tests. I found out that the layout couldn't
write the ' character with AWTKeyboardStrategy, so I started using
SWTKeyboardStrategy; problem is, I'm getting UI deadlock.
First, Display.post synchronize on the Device class (Display, line 2900)
then obtains the display pointer with OS.GDK_DISPLAY() (Display, line
2904). This method then lock on a field of the OS class and that's where
the WorkbenchTestable thread (SWTBot's thread) holds.
Meanwhile, in the UI thread, a paint event has been dispatched by SWT
using OS.gtk_main_do_event (OS, line 5783) which holds the lock on the
OS field. During the paint event handling, the widget being painted
tries to access something (could be the GC, system color, anything, I
got the deadlocks at different places) in the Display class: the class
check for validity and tries to synchronize on the Device class before
doing so, but this lock is hold by Display.post, on another thread. DEADLOCK
I tried wrapping up the calls to my calls to typeText into syncExec and
the text that was typed only appeared at the end of the exec. If a
problem happens (and it did) then the UI is frozen.
For now, I have fallen back to a custom AWTStrategy which map ' to
KeyEvent.VK_QUOTE, but if anyone has any ideas about this issue, I would
appreciate it.
P
Re: UI deadlock when typing character with SWTKeyboardStrategy [message #40860 is a reply to message #40829] Fri, 26 June 2009 13:45 Go to previous messageGo to next message
I'd recommend opening a bug against SWT if you're sure that's the case.
I'm not on GTK and can't reproduce this.
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
On 26/6/09 22:53, Pascal Gelinas wrote:
> Hi again,
> DEADLOCK
> appreciate it.
> P
Re: UI deadlock when typing character with SWTKeyboardStrategy [message #40891 is a reply to message #40860] Fri, 26 June 2009 13:58 Go to previous messageGo to next message
> appreciate it.
I'm considering using a composite strategy that switches between awt and
swt implementations for these kind of quirks across swt and jvm versions.
I don't have any concrete ideas on how to implement this, but I'm open
to suggestions on how this can be improved for better.
Ketan
Re: UI deadlock when typing character with SWTKeyboardStrategy [message #40922 is a reply to message #40860] Fri, 26 June 2009 14:42 Go to previous messageGo to next message
damn you're right, I forgot it might be platform specific... I'll pay a
visit to the SWT team ;)
Re: UI deadlock when typing character with SWTKeyboardStrategy [message #40952 is a reply to message #40860] Fri, 26 June 2009 16:19 Go to previous messageGo to next message
Solved the issue :D
I wrapped each individual call of Display.post in the
SWTKeyboardStrategy in a syncExec: Display.post then executes on the UI
Thread preventing the deadlocks.
Re: UI deadlock when typing character with SWTKeyboardStrategy [message #40982 is a reply to message #40860] Mon, 29 June 2009 08:39 Go to previous messageGo to next message
I found a bug entry in Eclipse about this one. It was fixed on 20080926
so I should probably get a newer build.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=247069
Re: UI deadlock when typing character with SWTKeyboardStrategy [message #41013 is a reply to message #40982] Mon, 29 June 2009 09:45 Go to previous messageGo to next message
This was fixed in Nov 2008, are you still on an M-build ?
-- Ketan
Re: UI deadlock when typing character with SWTKeyboardStrategy [message #41075 is a reply to message #41013] Mon, 29 June 2009 13:24 Go to previous message
Weird enough, I am. This is the full version given by eclipse:
Version: 3.4.2
Build id: M20090211-1700.
That is, up until this morning where I switched to 3.5.
Previous Topic:MultiPageEditor Support
Next Topic:How to relaunch a single test within Eclipse
Current Time: Fri Oct 31 04:16:07 EDT 2025
Powered by FUDForum. Page generated in 0.03941 seconds
