html widget - voice your comments [message #40571] |
Tue, 20 May 2003 12:36 |
As many of you here already know there is a plan [1] to introduce html
widget in eclipse platform past 2.2 release.
I started using eclipse only a few weeks ago and a component that caught my
attention was html-like widgetry(forms, buttons, dropdown menus) in PDE
editor. If you are not familiar with PDE editor turn on PDE plugin view by
selecting Window->Show View->Other->PDE->Plug-ins and then double-click
plugin.xml in any plugin (org.eclipse.jdt.ui for example). Plugin metadata
opens up in an editor view. Here you can view all these html-like
components.
Below is the excerpt from a discussion with Nick Edgar on a platform-ui-dev
list directing further discussion to this forum. I would very much like to
see all these components "opened up" in a public API and included in eclipse
release ASAP. What are your opinions, comments and concerns?
Vladimir
>For R3.0 we are planning on making use of a common embedded HTML widget in
>areas like the Welcome Page, Help, Update and other areas.
>Whether PDE ends up using this, and what role this leaves for PDE's forms
>layout, remains to be seen.
>We should move this discussion to the eclipse.platform newsgroup, since it
>involves several components in the platform, and others in the community
>may also be interested in voicing their requirements for an embedded HTML
>widget and/or forms support.
>Regards,
>Nick
[1] http://www.eclipse.org/eclipse/development/eclipse_project_p lan_2_2.html
FUDForum. Page generated in 0.23470 seconds
